Undercoating: krown vs ziebart vs the rest
Discussion in 'General Tundra Discussion' started by Yota18, Aug 30, 2018.
  1. Oct 20, 2020 at 5:10 AM
    #121
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE; previous 02 AC 323k
    Eibach pro suspension Nitro 4.88 with Auburn Pro LSD and PTFE diff bushings Level 8 MK6 18x9 SAIS bypass JBA cat back Scangauge 2 Diode dynamic fogs. LED heads
    this might be a viable option for the 342
    https://www.cosmolinedirect.com/not-factory-new-rp-342-aerosols/
  2. Oct 22, 2020 at 4:03 PM
    #122
    broadwayjoe15
    broadwayjoe15 New Member
    2013 Red Tundra CrewMax Platinum
  3. Oct 22, 2020 at 4:04 PM
    #123
    broadwayjoe15
    thanks!
  4. Oct 22, 2020 at 4:22 PM
    #124
    MEWaters
    MEWaters New Member
    Maine
    read the disclaimer... some cans may not work as new.. Still worth it imo
  5. Dec 12, 2020 at 2:16 PM
    #125
    cajunworm
    cajunworm New Member
    New York
    So I got caught in the new vehicle dealer Ziebart trap. I lost sleep the next couple of days after getting my brand new truck due to the mistake I made and how that A-hole car dealer told me "its good shit, everyone gets it". I researched Ziebart and the horrible reviews of it and its not "good shit". So to try to fix this problem I went ahead and fluid filmed over the Ziebart, I mean everywhere, even under the skid plate because Ziebart obviously did not take the time out of their day to spray that. Im only in NY for 2 more winters and when I finally get out of the salt state, I will just go ahead a pressure wash it off. I should be fine, I hope!
  6. Dec 12, 2020 at 4:55 PM
    #126
    rebmo
    rebmo 2020 Crewmax Limited 4wd Silver/Black
    Rural SE Wisconsin
    2020 CM LImited 5.7L V8 4WD
    Did you make those wheel well liners?
  7. Dec 13, 2020 at 9:54 AM
    #127
    Covert
    Covert New Member
    Gary
    2012 Rock Warrior
    none
    1) Corroseal, 2) cosmoline, 3) fluid film in areas not reachable with cosmoline. Search my posts for details and photos.
  8. Dec 13, 2020 at 3:42 PM
    #128
    teamtlr
    teamtlr New Member
    Denver Colorado
    2020 Sequoia TRD Pro
    For us still under factory warranty has anyone received any feedback from the technicians when you take it in for oil changes or check ups. I would imagine this makes for a mess when doing any maintenance, alignments, or removing the skid plates with the wool wax coating on everything you touch.
    BravoDeltaRomeo likes this.
  9. Dec 14, 2020 at 9:45 AM
    #129
    ZPMAN
    ZPMAN 2nd place is the 1st looser
    Minnesota
    2016 Black Platinum Supercharged
    4" lift, 35s, Magnuson Supercharger
  10. Dec 14, 2020 at 10:45 AM
    #130
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    I'm pretty sure they'd not enjoy it, but can't really tell you that you can't do it. It's a service that is readily available everywhere, safe for vehicles.
    I plan on DIY mine in the spring. I missed getting my compressor up and running before the snow flew.
  11. Dec 14, 2020 at 10:58 AM
    #131
    FlyingWolfe
    FlyingWolfe Wolfie
    Crystal
    Maine
    2018 TRD Off-Road Inferno
    Spent several hours woolwaxing the underfluffies of my truck a few weeks back. Went on great with the pro-gun and 80psi or so and was able to get my tiny hands into all the nooks and crannies. I've since driven on wet roads and two fairly heavy rainstorms and the water just beads on the surface, the WW sticks like a mofo. Time will tell when spring rolls around but I'm sure it'll be better than nothing in the Maine winters..
  12. Dec 14, 2020 at 11:02 AM
    #132
    BravoDeltaRomeo
    Bruce
    MB Canada
    Wanna drive up to MB and do mine? You look like a pro at it. :yes:
    Just out of curiosity, how much did you end up using to do your truck?
  13. Dec 14, 2020 at 11:39 AM
    #133
    FlyingWolfe
    FlyingWolfe Wolfie
    Crystal
    Maine
    I didn't even want to do my own truck so.. no.:rofl: Plus, the last time I was up there I dislocated my damned shoulder so I've sworn the entire country off. Even though it was my fault. o_O
    I ended up using about 3/4 of a gallon and got the black colored WW. Heard people that get the clear 'straw' WW have a hard time telling what's been sprayed and what hasn't once they get into it and I will say the black def helped with that.
  14. Dec 14, 2020 at 1:29 PM
    #134
    G10dra
    G10dra Not a New Member
    I just wanted to add this Guy from youtube who does comparison testing different products but here is a video pertaining to car undercoating.
    Project Farm
  15. Dec 14, 2020 at 6:02 PM
    #135
    teamtlr
    teamtlr New Member
    Denver Colorado
    Agree. Really won’t hold me back from doing it but agree they will probably not make a fuss about it. I actually started mine a few days ago with the spray cans of FF and it really sucks. The spray can nozzle just gums up and the spray gets clogged. Definitely need the compressor next time. One spray can only did the hitch and a little of the rear end.
  16. Dec 14, 2020 at 6:53 PM
    #136
    Are you keeping the cans somewhere cold by chance? I've used the spray cans for a few years now without issue. The only time I've seen it get clogged is when I left the can in the cold. I typically use the straw that comes with them.
    Luckydog likes this.
