Wiper issues
Discussion in '1st Gen Tundras (2000-2006)' started by Champ6262, Dec 5, 2020.
  1. Dec 5, 2020 at 7:03 AM
    Champ6262
    Champ6262 [OP] New Member
    Hi all. 06 limited here. I'm having issues with my wipers. After I start up my truck and put the wipers on they will work from anywhere from 5-10 minutes then stop completely. If I leave them on, occasionally they will work again but not for very long. Any help is much appreciated!
    YardBird likes this.
  2. Dec 5, 2020 at 8:17 AM
    Professional Hand Model
    Fred
    Hand Protectors
    Might have a bad wire connection. Start looking under hood. Press in the connectors to make sure. Look around under hood with the wipers in ON postion and jiggle wires and see how the wipers react. Feel motor to see it its hot. Watch your fingers!
    Stuck in the '00s likes this.
  3. Dec 5, 2020 at 8:18 AM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  4. Dec 5, 2020 at 8:21 AM
    Stuck in the '00s
    Stuck in the '00s Experienced member
    Mikey
    SE Wisconsin
    2004 Phantom Gray DC 4X4 Limited Tundra
    Western plow, custom bed
    Yup...prolly wiper motor.
  5. Dec 5, 2020 at 8:23 AM
    Fred
    Hand Protectors
    If your motor is bad, then buy the ‘Heavy Duty Cold Package’ Denso one. IIRC, they cost the same or less than the standard duty. Win win.
  6. Dec 5, 2020 at 9:32 AM
    Champ6262
    Great, Thanks everyone. Fingers crossed it's just a bad connection. In the middle of a blizzard here in Mass ;)
  7. Dec 5, 2020 at 12:26 PM
    Stuck in the '00s
    Mikey
    SE Wisconsin
    Long-handled snow brush, driver window down..I gotz solutions!
    Darkness likes this.
  8. Dec 5, 2020 at 12:32 PM
    Champ6262
    Update: Wipers are still stopping but I can get them going again by banging on the motor lol. I think I'll be buying a new motor
  9. Dec 5, 2020 at 1:05 PM
    Stuck in the '00s
    Mikey
    SE Wisconsin
  10. Dec 5, 2020 at 1:53 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I uses to do this on rainy days in one of my cars, but with a squeegee
  11. Dec 7, 2020 at 10:08 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Mine were sticking and when I unhooked the motor, it was the wiper arms (It's called a transmission) one of them was really hard to turn and so it was overheating the motor. Something else to check.
  12. Dec 7, 2020 at 2:56 PM
    Fred
    Hand Protectors
    I thought we installed a new motor and then the blades were not lining up properly? Did a see this somewhere else?
  13. Dec 10, 2020 at 10:19 AM
    Champ6262
    I did! I replaced the motor but now the blades aren't parking properly when I shut them off, they're stopping in the middle of the windshield
  14. Dec 10, 2020 at 8:28 PM
    My wiper arms (transmission?) wore out. The plastic bushings disintegrated. They do not sell new bushings. Had to replace the whole arm arrangement. Factory part is like $200+. For some metal arms. Ridiculous. Ordered an aftermarket replacement. Bolted right up. Wipers rest to low and throw too far. But they don't get stuck and they don't stop in the middle of the windshield. Would recommend the factory replacement if possible.
  15. Dec 10, 2020 at 8:35 PM
    YotaBro
    YotaBro This forum will make me broke
    Calvin
    FL
    2017 Cement Grey Tundra TRD PRO
    Lots of shenanigans.
    Had something similar happen with my old dodge but I took the getto route and drilled a hole through both of the bushings and grabbed some spare nuts and bolts and never had issues again.
