Now that you have done your lower ball joint, when will you do it again?
Discussion in '1st Gen Tundras (2000-2006)' started by onesojourner, Dec 9, 2020.
  1. Dec 9, 2020 at 6:57 AM
    onesojourner
    onesojourner [OP] Here, let me derail that for you
    SW MO
    06 DBLcab LTD 4x4
    PN
    04006-62134
  2. Dec 9, 2020 at 7:00 AM
    Glock 40
    Glock 40 I'm here to break shit
    Yukon Cornelius
    Way up thar
    2000 AC Limited 4X4 4.7L
    Deadpool Edition
    Just installed MOOG greaseable lower balls. I'm expecting about 150K... so probably change em when the odo hits 500K.
  3. Dec 9, 2020 at 8:16 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Either when they appear damaged, or when something else gets damaged, or when I have another 60k miles on my truck.
  4. Dec 9, 2020 at 9:00 AM
    Arringtonpalmer
    Arringtonpalmer New Member
    Sam
    New Hampshire
    2004 Limited Double Cab
    ARB Bumper, Warn Evo, UTE H66 tray, OME 2884 and Nitrochargers.
    @Darkness, what drives the 60,000 mile decision for LBJs?
  5. Dec 9, 2020 at 9:03 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Nothing scientific, just for preventative on my truck. I have heard recommendations for 75k or 100k miles before but my truck is a bit lifted and I drive it pretty rough.
  6. Dec 9, 2020 at 9:53 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Be careful with those, the way Toyota designed our lower ball joints there is downward and upward tension on them. Most of the aftermarket weren't designed for the upward tension and so the sleeve around the ball doesn't cover as much or is as strong, so they can separate.
  7. Dec 9, 2020 at 10:21 AM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    I ran a few high level searches on this site and TS, and ball joint failures don't seem as common as they are made out to be. All the title specific failures seem to be aftermarket ball joints. I am still looking for post recall failures.
  8. Dec 9, 2020 at 11:07 AM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    Thanks! I'll keep an eye on that. They're so easy to replace it's not really a big deal to me.
  9. Dec 9, 2020 at 11:33 AM
    I would change the moogs at 10k mile intervals.
    Or just buy the Oem and be done with it, they aren’t that much more expensive for the ease of mind.
  10. Dec 9, 2020 at 12:04 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    For this gen of Tundras, every 100K is advisable, more advisable is to use Only Toyota OEM parts, moog might last 25K if you're lucky.
    Ask me how I know!
  11. Dec 9, 2020 at 12:55 PM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    OK gentlemen, we'll see how she goes. I'm good tester. :bananadead:
