Hello....HELP NO HEAT
Discussion in '1st Gen Tundras (2000-2006)' started by Dmage, Nov 17, 2020.
  1. Nov 17, 2020 at 10:06 AM
    Dmage
    Dmage [OP] New Member
    2004 Blue Toyota Tundra
    My good people, can anyone explain where in tf is the a/c blend door actuator?? Ive troubleshot everything else. Seems my blend door is stuck to Cold . Any advice from experience is a much appreciated!!!!!
    -Dmage
  2. Nov 17, 2020 at 10:10 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Damn... priced out of the market.
    GODZILLA and bmf4069 like this.
  3. Nov 17, 2020 at 4:02 PM
    Stuck in the '00s
    Stuck in the '00s Experienced member
    Mikey
    SE Wisconsin
    2004 Phantom Gray DC 4X4 Limited Tundra
    Western plow, custom bed
    I once had a '78 or '79 F150 that got stuck on 'cold' so I pulled the lever to 'hot' and left it...so I'm experienced.
    But it was on the fenderwell and our Tundras have them on the firewall engine-side. Not much else there...
  4. Dec 2, 2020 at 2:32 PM
    nu2tundra
    nu2tundra New Member
    Oscar
    2010 SR5
    Check out this video. I have a '10 SR5 with the same issue(s); select knob doesn't do squat, plus no heat even though heater core checks ok.
    https://youtu.be/_udGpW7QKHk
    blackdemon_tt likes this.
  5. Dec 2, 2020 at 2:53 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Nice find... Imma have to subscribe, just in case... LOL...
    nu2tundra likes this.
  6. Dec 9, 2020 at 9:04 AM
    synackattack
    synackattack New Member
    Bradenton, FL
    2018 Cement Limited CM TRD Offroad 4x4
    I just fixed my son's 2004 Tundra that had no heat, so I thought I'd share my steps in case it helps. The vehicle isn't at the house right now, so I'll do my best to describe it.
    When you turn the knob on the heat there's a valve on the top of the firewall driver side that turns. I verified that the cable turned the valve before I started any of this. If it doesn't, you can see the cable turning something under the glove box...maybe check to see if that is broken.
    The first thing I did was back flush the heater core with water. There are 2 hoses going in to the firewall on the passenger side of the vehicle. I removed the hoses from each and attached a garden hose with a piece of 5/8" ID hose on the end of it to the left port, and another piece of hose to the right port led to a 5gal bucket to catch what came out of it (pics of the hose I made below). When I turned on the water a LOT of sludge that came out of it. I ran about 5gal worth of water through it before the water was clear, and the chunks stopped coming out.
    I cranked it and got it to operating temp, and the heat still didn't work.
    I then checked the hoses that were before and after the valve that the heater control turns. It's in line with the same hose that went in to the firewall, further towards the drivers side. Both of the hoses before AND after the heater valve were 100% clogged with what can best be described as a 15" long dog poop. I ran water through each of them until they were clear.
    After that I decided to flush and replace all of the coolant. I drained and added distilled water to it twice, and filled it back up with the Red antifreeze mix...not sure if that matters, but I wasn't taking any chances after seeing all the crap in there.
    Heater works great now. The clogged lines coming out of the engine going towards the heater core and clogged heater core were the culprit.
    Hope this helps.
    I can post pics of the engine hoses and mixer valve mentioned if anyone needs them after my son gets home from school. Just let me know.
    YexI6kcySlDHFRqqdYQeX8pzAkR11WW30TP-0SDR_9ecf4e56e6d60c23845c14136f26639cca92232b.jpg
  7. Dec 10, 2020 at 4:39 AM
    Professional Hand Model
    Fred
    Hand Protectors
    You have any action pics? Post them please.
