Norcal Newbe
Discussion in 'New Member Introductions' started by Mitchc, Dec 7, 2020.
  1. Dec 7, 2020 at 9:45 AM
    Mitchc
    Mitchc [OP] New Member
    Mitch
    Hello to all,
    I'm one of the lurkers at this point, and do not have a Tundra at this time. I am a pro-Toyota guy and owned may over the years including a 1980 SR5 pickup, an '88 Supra with great luck!
    And I don't mind wrenching - just did Timing belt/ idlers, water pump and several other service jobs on my daughters 99 4Runner to help her out.
    I was looking for a first gen Tundra 6 years ago when looking for a new truck to pull our 20' travel trailer (4,000 lbs) and after 2 years of Price gouging sellers and dealerships I bought a new Ram 1500 hemi 4x4 with a warranty.
    I'm back again looking for a Tundra and trying to learn more about the newer generations and not limit myself to 1st gen only... So I'm looking for comparo's between the various generations to gain some insight into what will break, what to look for when buying, etc. But haven't seen one here.
    Apologies if I just didn't search deep enough, looking forward to the combined experience here and really hope to find the right truck to pursue with your help!
    Mitch C
    Auburn CA
    Prostar 190 and YardBird like this.
  2. Dec 7, 2020 at 9:59 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    Welcome from So Cal
  3. Dec 7, 2020 at 10:06 AM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  4. Dec 7, 2020 at 10:27 AM
    Welcome from Ohio
  5. Dec 7, 2020 at 5:01 PM
    Rgross2112
    Rush
    2020 Silver TRD Limited
    Welcome from Pennsylvania
  6. Dec 7, 2020 at 5:14 PM
    Welcome from NY.
  7. Dec 7, 2020 at 5:14 PM
  8. Dec 7, 2020 at 5:16 PM
    Blue Thunder
    Washington
    Welcome from WA
  9. Dec 7, 2020 at 5:39 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Welcome from Nevada
  10. Dec 8, 2020 at 9:39 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Welcome from the wet side of WA. Lots of info on here. You'll find there's not a lot of difference mechanically between the "Gen 2" and the "Gen 3" - they are the same engine/transmission/frame/suspension/etc. Others on here have a lot more experience on things like towing, etc.
    Grab a drink, and browse through the various sub-forums. Use the search bar in the upper right. You'll find lots of info on your questions. And post up specific questions if you don't find what you are looking for. :pccoffee:
    Me, personally, I had 298k on my 2008 without any drama when I traded it in. On the Gen 2 trucks, the Air Induction Pump seems to be a fairly common gremlin that is expensive to get fixed (I had it happen around 200k miles) - Toyota did extend the warranty on it (not enough for it to help me), and you can also research an alternative solution produced by Hewitt Tech. Cam Tower leaks are something others post on here, though I never noticed it on my 2008 (never looked that hard either - it never lost oil and I did 10k changes the entire life of the truck). You'll find a whole debate on external transmission coolers that were deleted with the most recent couple of model years (2018 or 2019 and newer). The 2016 model year added an option for a 38-gallon fuel tank, which makes your wallet hurt a little more at each fill up, but does extend your range (when you account for the notoriously large 6-gallon reserve that Toyota builds into the Tundra fuel tank, that 38-gal tank give you a little more than 50% more useable volume before the gage says "FILL!"). You'll find some differences in how the back seat in the larger cab folds between the three generations - my brother's 2005 he can flip the back down or the seat up. On the 2007-2013, the Crewmax rear seat back folds down (and the seats can slide forward/back). On the 2014+ Crewmax, the bottom of the seat folds up and the back angle is fixed. Double-cabs for 2007+ all have the same seat setup (bottom folds up), but there is a mod you can do to make the back flip down (though there isn't much room back there to use).
  11. Dec 8, 2020 at 11:03 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Welcome from Nor Cal
  12. Dec 9, 2020 at 9:41 AM
    mattgecko
    mattgecko The LED Light Guy... MattGeckoLEDs.com
    South San Jose, CA
    2011 Tacoma, Off road, super charged 4x4
    Welcome!
  13. Dec 10, 2020 at 2:13 PM
    Mitchc
    Mitch
    Thanx to you all, especially RainMan for the generation comparison to help me get started... I go thru periods of time when I prowl around most forums and sometimes get caught up with other stuff that life throws my way! I'm only 20K miles into the 2017 Ram Hemi 4x I bought because I mostly ride my motorcycle so I hope to be able to do okay on the value when I resell it, which I would like to use on personalizing whatever model Tundra I end up with. I'm also planning to replace a small travel trailer I sold with another one in the future and hope to make the Tundra a capable tow'er
    Looking forward to more time with you all in the future for sure! ;)
  14. Dec 10, 2020 at 3:39 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  15. Dec 10, 2020 at 4:09 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    welcome from Sacramento
