  1. Dec 1, 2020 at 6:54 PM
    04 Tundra
    04 Tundra New Member
    Albert
    2004 Toyota Tundra 4x4 AC Limited
    DIFF Breather, Painted Rims, Interior Wrap, Tint,
    I know alot of people rave about the JBA I'm sure they are good. And Dirty deeds sounds great too just not affordable for most people. I got the Gipson headers nickle plated and they are sweet. Time will tell if they hold up but I'm very happy with them.
    The walls seem much thicker then the JBAs but could just be an illusion.
    Thrussn[QUOTED] likes this.
  2. Dec 1, 2020 at 6:59 PM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    Is there a chart like this for the 5 speed?
  3. Dec 1, 2020 at 9:08 PM
    Thrussn
    Thrussn Plastidip Hoe
    Gabe
    NM
    Silver 2005 4.7L 4WD Access Cab
    Bilstein 5100s, SickHIDs projector housings, Plastidip everything, TRD Pro style rims, LEDs everywhere, SUPERBUMP bumpstops. Firestone Riderite air bag springs, Deaver G57s, Onboard VIAIR system, Backup Camera, light bar behind the bumper, CGS catback, Exhaust cutout after cats, JBA Shorty headers, JBA Y-Pipe, pioneer deck, pioneer speakers, kicker 10" sub w/ amp, door sound deadening, Dirtydeeds 12 pin injectors, UniChip, Skid Row Skidplate, EZ Oil Drain valve (Better than Fumoto), Oil Catch Can, & 4WD Conversion
    I leak about that much every 5000 miles, but it's that super common o-ring leak that's attached to the thermostat housing.
    NUDRAT likes this.
  4. Dec 1, 2020 at 9:49 PM
    jImmegart
    Jonah
    California
    2003 Tundra TRD Sport
    Replaced my snugtop glass bolts with oem ones. The old rubber seals left these marks though, anyone have any tips to get rid of them?
    Jerry311SD likes this.
  5. Dec 1, 2020 at 9:58 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    No chart, but the info is in the FSM.
  6. Dec 2, 2020 at 4:20 AM
    Professional Hand Model
    Fred
    Hand Protectors
    Try some rubbing compound (for wax and finishing). Try a test spot before going all in. The grit should ‘cut’ the layer off the top of glass.
    jImmegart[QUOTED] likes this.
  7. Dec 2, 2020 at 4:43 AM
    I've used a product called Glass-X that I believe was made by Maguire's or Mother's. It's basically a rubbing compound for glass. Worked great at getting water spots off the windows. Looks like they have a product called Glass Clarity now, whole kit.
    jImmegart[QUOTED] and oscardog86 like this.
  8. Dec 2, 2020 at 5:16 AM
    Hard to say in the pictures but it kind of looks like that. We had another member recently discover a leak in that area and it was his head gasket.
    NWPirate[QUOTED] likes this.
  9. Dec 2, 2020 at 5:17 AM
    Is this the same gasket I would have replaced when I did the thermostat or another one? You can see it leaking I guess?
  10. Dec 2, 2020 at 6:24 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    @FirstGenVol
    How do your hoses look around the throttle body and around the heater control in the engine bay?
    Could you be checking the level at different times; like after the engine has run and when it's completely cold?
  11. Dec 2, 2020 at 6:35 AM
    I'll take another really good look and see if I can find anything. So far I've not seen any leaks
    No I've been sure to only check it when the engine is up to operating temp. I've used that as my baseline.
  12. Dec 2, 2020 at 6:50 AM
    speedtre
    speedtre New Member
    Inland Northwest
    It's also the pursuit of power/speed. A 2020 Honda Accord family grocery getter does 0-60 in about 7 seconds. A 1986 Porsche 944 (non-turbo) did 0-60 in about 8 seconds.
    More emissions restrictions and more power, something has to give...that something is MPG.
  13. Dec 2, 2020 at 7:31 AM
    You have Gibson headers on a 1st gen? I don't even see them listed on their website.
  14. Dec 2, 2020 at 10:22 AM
    NWPirate
    Zach
    WA
    Looks like it's a freeze plug next to the starter from a picture I found on the internets.
    Has anyone heard of these being replaced? @Professional Hand Model @empty_lord @FirstGenVol
  15. Dec 2, 2020 at 10:30 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Never seen that leak on a 4.7. But it shouldn’t be too hard to replace it since it’s easily accessible with the other plenum off.. assuming the bore is still good clean it like hell and find some nice brass freeze plugs
  16. Dec 2, 2020 at 10:38 AM
    NWPirate
    Zach
    WA
    Appreciate it. I'll keep an eye on it and if starts getting worse, might be a good opportunity to throw in a new oem starter while I'm in there.
    theblurry1 likes this.
  17. Dec 2, 2020 at 11:05 AM
    I didn't realize freeze plugs could be replaced. Do you just push the old one out from the backside?
  18. Dec 2, 2020 at 11:09 AM
    NWPirate
    Zach
    WA
    I hope from the top, I would think you could carefully pry the lip inwards and get a pair of needle nose on it.
    Darkness and lamboboy732 like this.
  19. Dec 2, 2020 at 11:14 AM
    Yes that would make a lot more sense than what I wrote. Otherwise he wouldn't have said it shouldn't be too difficult.
  20. Dec 2, 2020 at 1:18 PM
    Jerry311SD
    Jerry311SD New Member
    Jerry
    Ramona San Diego CA
    05 Tundra
    Picked up a shell for 80$ today
    Going to be painting it soon.
  21. Dec 2, 2020 at 1:24 PM
    Damn that's a steal. Good find. It looks like the same color as your truck in the 2nd picture. Is it not?
  22. Dec 2, 2020 at 2:34 PM
    Fred
    Hand Protectors
    Do the Heavy Duty Denso 2.0Kw Starter. Its less $$$$ than the 1.4Kw weaker one and is an upgrade if yours didn’t come with the ‘Cold Package’.
    Win win.
  23. Dec 2, 2020 at 3:25 PM
    Jerry311SD
    Jerry
    Ramona San Diego CA
    05 Tundra
    No it's silver.
  24. Dec 2, 2020 at 3:31 PM
    Cummins3500
    Logan
    Collected some more parts today:
    All pro spindle gussets
    All pro UCA gussets
    All pro swag bar centering collar
    * little note about the collars, they’re sold individual. My dumb a*s missed that part and have got to order another one
  25. Dec 2, 2020 at 5:02 PM
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    Installed a Hellwig 7697 front sway bar and Suspension Maxx extended end links today.
    The Hellwig is significantly heavier (listed as 25lbs) and 1-1/4" in diameter. The stock bar is a smidge over 7/8" (23mm). That's 38% larger than stock!
    Difference in bushings.
    Here's a comparison between the stock sway bar end link vs the extended Suspension Maxx.
    I raised the truck with ramps and had plenty of room for the removal/installation.
    I was only able to manage a short test drive but the front suspension feels a bit more firm and steering input results in a quicker turning response. I was hoping to also install my recently ordered Addco 2181 rear sway bar kit but it's backordered and likely wont ship to me until early January. Maybe by then I'll be able to order the heavy duty rear leaf springs and do it all at once.
    Tundra2, MS22, imDementeD and 6 others like this.
  26. Dec 2, 2020 at 5:06 PM
    Fred
    Hand Protectors
    Nice! Whats the dia. on the Addco Rear Bar?
  27. Dec 2, 2020 at 5:28 PM
    Lil Steve
    Gilbert, AZ
    The Addco rear is 1". The Hellwig 7700 is 1-1/8" in diameter but more than double the price. I got a BF deal on Big Gurl for the Hellwig front, it was $178. As soon as I purchased it I went back to the listing and it was over $250. The box arrived in pretty bad shape (seemed opened/returned) yesterday but everything was intact and the hardware was still in the box. I'm guessing since it was previously opened/returned that's why I got such a good price. I was ready to buy the Addco front (1-1/16" diamter) but I checked Big Gurl first (it was in my saved list) and it wound up being less expensive than the Addco. :yes:
  28. Dec 2, 2020 at 8:02 PM
    Thrussn
    Gabe
    NM
    I'm gonna put the big girl (not to be mistaken with big guurll) out of commission for the next week or so.
    I'm going to rip out that rear end again so the shop can redo it and install a solid pinion spacer. I'm glad they're honoring their word to redo the gears since it makes noise.
    Since I have to remove the brake lines, I figured it's a better time than any to install some wheelers SS lines.
    If I get the new flange gaskets in time, am going to try and replace that header again while I have it sitting. Is there anything I can do to take some stress off of that header flange? That 05 cat is too chonky for the header and I will drive off a cliff if it cracks again. :mad:
    Here are some pics of those chonky cats for reference
  29. Dec 2, 2020 at 8:14 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Add an extra exhaust hanger before the cat and a flex pipe.
    NUDRAT and Thrussn[QUOTED] like this.
  30. Dec 2, 2020 at 8:23 PM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    Man, you stole that sucker. Picked mine up for $120. Been blocking it for the past week.
