  1. Nov 30, 2020 at 2:18 PM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    NW Georgia
    Wait, what?
    They're replacing the ball joints under a recall? That's still a thing??
  2. Nov 30, 2020 at 3:07 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Thanks for the link. I'll stick this in my notepad thread for future reference.
    Most of these kits have the water pump WITH the oil cooler nipple. As far back as I can remember, or at least since I've been doing the maintenance all the water pumps I've seen on my truck haven't had that extra nipple.
    Maybe I've got the wrong water pump which knowing pops is entirely possible. I glanced at the field service manual for oil cooler location/diagram. I'm not saying its not there, but I was skimming. I'll look again when I have more time.
    The only oil cooler I know for sure i have is the one for the ATF.
  3. Nov 30, 2020 at 4:30 PM
    Thrussn
    Thrussn Plastidip Hoe
    Gabe
    NM
    Silver 2005 4.7L 4WD Access Cab
    Bilstein 5100s, SickHIDs projector housings, Plastidip everything, TRD Pro style rims, LEDs everywhere, SUPERBUMP bumpstops. Firestone Riderite air bag springs, Deaver G57s, Onboard VIAIR system, Backup Camera, light bar behind the bumper, CGS catback, Exhaust cutout after cats, JBA Shorty headers, JBA Y-Pipe, pioneer deck, pioneer speakers, kicker 10" sub w/ amp, door sound deadening, Dirtydeeds 12 pin injectors, UniChip, Skid Row Skidplate, EZ Oil Drain valve (Better than Fumoto), Oil Catch Can, & 4WD Conversion
    Guess what happened to the same weld on the same side header yesterday
    I'm gonna have this one welded by a really good welder I know and see if he'd be able to reinforce that bend.
    What else can I do to prevent this from happening ever again? Shorten the nearest exhaust hanger by a tiny bit?
    TX-TRD1stGEN likes this.
  4. Nov 30, 2020 at 4:56 PM
    Is that the same side JBA just replaced? That really sucks.
    Thrussn[QUOTED] likes this.
  5. Nov 30, 2020 at 5:42 PM
    What brand are those bad boys?
  6. Nov 30, 2020 at 5:55 PM
    Thrussn
    Gabe
    NM
    It's JBA. They replaced the first one about 2 months ago and then this new one cracked in the exact same place as the first.
  7. Nov 30, 2020 at 6:05 PM
    That sucks dude. And are they the longs or shorts? I hope mine don’t do the same!!
  8. Nov 30, 2020 at 6:52 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Do you park outside? I'm wondering if its a stress crack due to high heat, and then really cold cold?
    NUDRAT and FrenchToasty like this.
  9. Nov 30, 2020 at 8:12 PM
    bassman417
    bassman417 "Tundra Time". My favorite time of day...
    Paul
    Las Vegas
    2004 DC 2wd Imperial Jade
    it is if it never got done?
    i think someone other than toyota replaced them already?
    theblurry1 likes this.
  10. Nov 30, 2020 at 10:10 PM
    Thrussn
    Gabe
    NM
    Hmm. Maybe. It happened both times while driving on a bumpy road. Nothing crazy at all this time though. I recall reading about how a cracked manifold was pretty common due to poor design resulting in too much weight on the driver's side or something. I wonder if I can add an extra hanger or cut and shorten/tighten the one that's closest to where it cracked .
    Tundra2[QUOTED] likes this.
  11. Nov 30, 2020 at 10:50 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Darkness[QUOTED] likes this.
  12. Dec 1, 2020 at 6:30 AM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    Are your engine mounts good? Engine bouncing around too much?
  13. Dec 1, 2020 at 6:51 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Damn I can't believe that happened again.
  14. Dec 1, 2020 at 10:32 AM
    Thrussn
    Gabe
    NM
    Yeah they're solid. The engine doesn't even budge when I rev it.
    You're telling me haha. I found a guy on facebook selling just a driver's side JBA manifold for $200 and he took my offer of $100. It has that ceramic or chrome finish unlike my passenger side so that will be funny looking lol.
    I'm going to inspect the exhaust hangers and stuff later tonight to see if something clearly wrong is up
  15. Dec 1, 2020 at 11:03 AM
    In November of 2019 I started a thread saying I thought I was losing a small amount of coolant. The advice given was to get it to operating temp and fill to the full line which is what I did. 13 months later and this is the amount I've lost. Or so it appears. I've only driven around 9,000 miles.
    I remember reading it's not uncommon for even new water pumps to leak. I wouldn't be able to see that unless I remove the timing cover right? My water pump has 31k miles on it.
    There are no visual leaks and no obvious signs of head gasket issue. Should I just keep an eye on it and not worry too much?
  16. Dec 1, 2020 at 11:07 AM
    speedtre
    speedtre New Member
    Inland Northwest
    It's diluted with 1/2 water right? If yes, then that could simply be evaporation...even in a "closed" coolant system there is an opportunity for a little evaporation. I wouldn't sweat that....no pun intended.:thumbsup:
    theblurry1, chrisb and Darkness like this.
  17. Dec 1, 2020 at 11:08 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I haven't looked at mine lately but I know coolant shrinks when weather gets cold enough. Might just be that.
  18. Dec 1, 2020 at 11:13 AM
    Yes I bought the pre mixed 50/50 Zerex. I didn't dilute it myself.
    I noticed it even this summer that it was lower but it has gotten a bit lower in the past few weeks when the temperature dropped.
  19. Dec 1, 2020 at 12:40 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    I've got a leaky rear wheel oil seal on my 01 Sequoia. I've looked through the FSM for the oil seal depth and the page doesn't help much. It looks like I just drive it in until flush, does that look correct? (FSM attached)
  20. Dec 1, 2020 at 1:11 PM
    Arringtonpalmer
    Arringtonpalmer New Member
    Sam
    New Hampshire
    2004 Limited Double Cab
    ARB Bumper, Warn Evo, UTE H66 tray, OME 2884 and Nitrochargers.
    Fixed this:
    For $80 (not 101 as I previously posted) Donovan Spring made me a replacement leaf, including U-Bolts, center pin, and silencer pads. Great to deal with, and a local business.
    The U-Bolts didn't budge with the impact, so I hit 'em with the grinder, center pin as well. Rest of the old pack came out easy:
    Spent a little time wire wheeling, oiling, and painting things while in there.
    The sole PITA in this job was getting the axle to line up directly under the new center pin so it could drop into its home. This is definitely a result of working on a soft surface, a wheeled floor jack on concrete would have made that part a cake walk. I used a high lift at an angle and a BFH to find the right spot, with the truck's weight on jack stands of course. Great video on the subject, he doesn't say it, but we all know what the truck is.
    All together, added the spring clamps @chrisb suggested:
    I'd taken it for one drive between greasing up the driveshaft slip joint and doing this leaf repair, and the driveshaft had completely eliminated my clunk. With the spring fixed, clamps in, and shaft all greased up (just slipped that in there didn't I?) the truck is solid no matter how hard I mash the skinny or the fat pedal. Real happy with it.
    I popped the drum off while waiting for some paint to dry and found that the reason my parking brake won't work is a broken cable in there. Looks like I'm going to be in the drum rebuild club, but I'm soon going to run out of Important Maintenance and have time for cosmetic and upgrade things. Looking forward to it, but this one might be my last truck project before an upcoming deployment.
    Voss, jpink, Kimosabe and 10 others like this.
  21. Dec 1, 2020 at 1:16 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Nice work @Arringtonpalmer
    Ratchet straps also do the trick for centering the axle. I had to loop one from the axle to my tow hitch to get it centered when I replacement my leaf springs. If you have to pull it forward the cross members work.
    Love seeing work get done at home. :thumbsup:
    NUDRAT, des2mtn, FirstGenVol and 3 others like this.
  22. Dec 1, 2020 at 2:17 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Yes. I used a 2” PVC fitting as the drive to tap the seal flush into the hole. Get it started lightly with your thumbs then lightly tap with a short handled wide hammer/maul. Tap until you hear a different ‘sound’ indicating you’ve hit the rim.
    Thrussn and NUDRAT like this.
  23. Dec 1, 2020 at 2:24 PM
    Fred
    Hand Protectors
    You can remove your skid plate and look up to the WP bottom to obtain a good angle of the ‘designed weep hole’. If no leaky crusties, then you are losing fluid somewhere else (assuming your engine is at operating temp as of that picture). A little over one year and my fluid never budged through all seasons.
    Top it off again to the F (when hot) and monitor it.
  24. Dec 1, 2020 at 2:40 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    I'd look at adding flex pipes after the manifold and before the cats.
    There probably is a bevel where the seal goes in, you want it flush with the rear or inside edge of the bevel typically. Usually only about 2mm deep.
    The bevel is there to allow easier installation of the seal.
  25. Dec 1, 2020 at 3:44 PM
    Now I need to add flex pipes to my cart!
    Darkness likes this.
  26. Dec 1, 2020 at 4:03 PM
    Fred
    Hand Protectors
    Anyone consider those Doug Thorley Headers?
  27. Dec 1, 2020 at 5:20 PM
    Siebler
    Siebler Taco Tow Vehicle
    CJ
    Eastern Oregon
    01 AC 4x4,07 Sequoia 4x4, 99 Tacoma Long Travel
    Monstaliner, Kings and Camburg UCA, projector retros, DD injectors, homebuilt bumper/ sliders
    I have had Thorleys on my Tacoma for over a decade, 100% route im going should I ever discover a cracked manifold. I keep checking/ hoping! Haha
  28. Dec 1, 2020 at 5:31 PM
    Siebler
    CJ
    Eastern Oregon
    No action yet but guess this means I can finish my bumper and move on to some sliders
    Darkness and chrisb like this.
  29. Dec 1, 2020 at 5:57 PM
    NWPirate
    Zach
    WA
    Hey all, did a little preventive maintenance today. New fuel filter, pcv valve and diff breathers on our 04 Sequoia.
    Got a question for you 2UZ pros, 140k miles on her. Looking over the engine I noticed some coolant crust built up on something in the valley just in front of the starter, drivers side. Hoping this isn't a freeze plug failing?
    Engine bay shot, if you're in to that sort of thing.
  30. Dec 1, 2020 at 6:52 PM
    912
    912 @best_gen_tundra
    Fulltime RV traveler
    2005 DC 4x4
    Did a trans drain and fill today. Was exactly 3qts. Hardest part was waiting for the trans temp to get up to 115F to check the level. Old fluid didn’t look too bad considering it’s been about 85k as best I can tell.
    9EA30EFE-1469-46CA-B65C-8208A5BF10AE.jpg 755AEF26-945D-4849-A844-56D4B0BD35F8.jpg 533C9325-67CE-451C-A00C-41B5D05D6770.jpg
    Old
    New
    Finished in around an hour so got talked into replacing the old kitchen sink afterward
    Weather’s gorgeous so I ended the day with a few IIPAs on the lanai. A pretty good day overall.
    Talking now with jhuey about getting a katzkin kit. Should be an awesome upgrade.
