Poll- What tire size are you running on your stock TRD Pro?
Discussion in '2.5 Gen Tundras (2014-2021)' started by L_S_SHOE, Nov 17, 2020.
What tire size are you running on your stock TRD Pro? All choices assume an 18" stock rim.
  1. 33x12.5
    0 vote(s)
    0.0%
  2. 34x12.5
    1 vote(s)
    2.1%
  3. 275/65 (stock Michelin)
    15 vote(s)
    31.9%
  4. 275/70
    15 vote(s)
    31.9%
  5. 285/65
    0 vote(s)
    0.0%
  6. 285/70
    4 vote(s)
    8.5%
  7. 295/65
    0 vote(s)
    0.0%
  8. 295/70
    6 vote(s)
    12.8%
  9. 305/65
    0 vote(s)
    0.0%
  10. Other
    6 vote(s)
    12.8%
  1. Nov 17, 2020 at 11:41 AM
    L_S_SHOE
    L_S_SHOE [OP] New Member
    SE Louisiana
    2021 MGM TRD Pro
    I suspect there are Pro owners who are cool running 33s or pizza cutters to save on gas. I'm also interested to see if tire brand affects the likelihood of rub (I'm sure it does).
    ***Please don't reply if you're running spacers or shims, unless these mods were required to alleviate rubbing.
    ***Please don't reply if you're running aftermarket wheels.
    ***Pics are always good.
    Please also respond to the thread with the following info in the following format:
    Tire size:
    Brand:
    Did it rub and, if so, where? (front mud flap, UCA, body mount, etc.):
    If applicable, what did you do to fix the rub? (removed front mud flap, heat gun, trimmed something, added spacers, added shims, etc.):
  2. Nov 17, 2020 at 12:28 PM
    FISHN43
    FISHN43 New Member
    Ohio
    2020 Super White TRD Pro
    275/70 Falken Wildpeak AT3W. No rubbing whatsoever.
  3. Nov 17, 2020 at 12:40 PM
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    My truck came with Ridge Grapplers. When they need to be replaced, I’ll go to 275/70 probably in Toyo Open Country AT III’s or Cooper ST Maxx.
  4. Nov 17, 2020 at 12:41 PM
    te37_daniel
    te37_daniel New Member
    Lunar Rock TRD Pro
    18 TE37 large PCD, KM3s
    295/70 seems to be very popular with Pros on stock suspension.
    That's the size I'm going with and @RainMan_PNW just got his installed.
    TelemarkTumalo likes this.
  5. Nov 17, 2020 at 12:47 PM
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    I like the 285/75s, you get bit more OD which is great for clearing stuff, and most weight around 55lbs to 63lbs range not to mention no trimming of anything is needed.
  6. Nov 17, 2020 at 12:48 PM
    Patch999
    Kyle
    2017 Bad@$$ TRD Pro
    I have 295/70 Toyo AT3's ordered. Running 285/65 RG's now.
  7. Nov 17, 2020 at 1:06 PM
    Supawhite_trdpro
    Supawhite_trdpro New Member
    2020 trd_pro
    -TRD Cold Air Intake -TRD Oil Filler Cap -TRD Radiator Cap -TRD Shift Knob Black -TRD PRO Insert Badge -Tundra Tailgate Insert Badge -Toyota Tundra Bed Step ‪-Toyota Tundra Wireless Charging Tray ‬ -Toyota Tundra Grab Handle Kit -Toyota Tundra Bed Extender -Pedal Commander Throttle Response Controller PC27 -Nitto Ridge Grappler 285/70R18 -BORA (Bulletproof Off Road Adapters) 1.25 Wheel Spacer -SDHQ Built Billet ABS Guards -Bushwacker Pocket/Rivet Style -Go Rhino RB20 Running Boards with Textured Black Bed Liner Coat -EGR In-Channel Window Visors -Husky Liners X-act Contour - Front and 2nd Row Floor Liners -AJT Design - Chrome Delete Kit and Injection Key Fob V2 -Headlight Revolution Interior: Toyota Tundra LED Interior Bulb Upgrade Kit with Vanity Light -Headlight Revolution Exterior: Cargo Light, 3rd Brake Light, License Plate Light and 1000 Lumen Reverse Light
    Running 35’s ko2
    Elduder likes this.
  8. Nov 17, 2020 at 1:47 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    That's the cleanest shop floor I've ever seen. :eek2: Up here, that wouldn't last 30 seconds from early November until about late June...
    Here’s the Falken 295/70’s
  9. Nov 17, 2020 at 1:54 PM
    FISHN43
    FISHN43 New Member
    Ohio
    What pressure you running in those? Look a tad low?
    netranger6 likes this.
  10. Nov 17, 2020 at 1:58 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Haven't started even messing with them yet for that. It was way after dark when they got put on last night, and it was still dark when I left for work this morning. I'll probably push them up to 40-ish and start chalk-testing if I can get a break in the rain.
    FISHN43[QUOTED] likes this.
  11. Nov 17, 2020 at 2:00 PM
    DIYDad
    DIYDad New Member
    2020 Tundra 1794
    is that on stock pro suspension, or is that lifted? brand? specs?
  12. Nov 17, 2020 at 2:38 PM
    MNTX TRDPro
    MNTX TRDPro New Member
    '17 White TRP Pro
    Rolling Tonneau
    These are the Cooper Discoverer AT3 XLT - 275 75R18. Had them for 2.5 months now. Hunting elk & deer in Montana dirt & mud, pheasant in MN snow & ice.
    They are better off-road than the stock Michelins (of course), which were of no use in minimal snow/mud combinations on dirt roads. (but I was too cheap to dump them before the tread wore out) Visually they were pitiful on the truck as well!
    So far the AT3 are performing well in the snowy weather I have come across on and off road.... but honestly, never had a better tire on the road in rain/snow/ice than those stock Michelins.
    I have just under 10k on them since Sept 1, but the addition of the camper on the back has totally changed the truck profile, and as such the feeling of the truck in inclement weather. It will take a bit yet to fully assess my likes and dislikes of the tire.
  13. Nov 17, 2020 at 2:44 PM
    Trunk Monkey
    Trunk Monkey Truck's
    Steph
    2019 Tundra TRD PRO - VooDoo Blue
    Retrax One MX, NFab Predator Pro steps, Husky X-Contour mats
    +1 on those stock Michelin, I want to hate them but honestly the only thing I don’t like about them is the look.
  14. Nov 17, 2020 at 3:25 PM
    DIYDad
    DIYDad New Member
    2020 Tundra 1794
    I don't mind the look so much as the size. They'd look just fine in a 285/75R18 !
  15. Nov 17, 2020 at 3:40 PM
    Supawhite_trdpro
    2020 trd_pro
    Yes still the Stock pro suspension with westcott design trd pro front kit and coachbuilder +3 rear shackles.
  16. Nov 18, 2020 at 7:54 AM
    DIYDad
    DIYDad New Member
    2020 Tundra 1794
    Looks great! How do you find those Westcott preload spacers affect the ride of the Pro shocks? Is it noticably stiffer?
  17. Nov 18, 2020 at 9:22 AM
    worktruckwhite
    worktruckwhite bryceCtravels.com
    Charleston, SC
    2010 White Crewmax
    Exact same on my truck. Not a pro, but it’s leveled just like a pro. I will probably stick with 275/70 next time as well. Looks really good.
    Trunk Monkey and FISHN43[QUOTED] like this.
  18. Nov 18, 2020 at 9:36 AM
    TrenThom86
    TrenThom86 New Member
    Trent
    NW Louisiana
    2021 TRD Pro Lunar Rock
    Same here. 275/65 ridge grapplers. I’d like larger tires but I can’t justify buying them till these need to be replaced.
    te37_daniel likes this.
  19. Nov 18, 2020 at 9:47 AM
    tttrdpro
    SWGA
    2024 GMC 2500 AT4
    In progress…
    The Ridge Grapplers haven’t been a bad tire for me. The reason I’m looking for a different tire next time is 95% of my off-roading involves red clay mud and that is definitely their weak point. Other than that they’ve been great for me. I don’t want to go to an all out mud tire. From the research I’ve done it seems the Tokyo’s or Cooper’s may be a bit better in mud.
  20. Nov 18, 2020 at 11:21 AM
    jfisher256
    jfisher256 New Member
    Huntsville, AL
    2019 Super White Tundra TRD Pro
    I'm running these 275/70 KO2s on my stock TRD Pro. No rubbing
  21. Nov 29, 2020 at 5:34 AM
    L_S_SHOE
    SE Louisiana
    2021 MGM TRD Pro
    I’m thinkin there’s more folks running a 285/70r18 than the poll suggests.
    If Nitto’s specs are correct, then the Ridge Grappler is only 0.33 inches shorter and 0.27 inches narrower than the 295/70r18, but 10 lbs lighter. Seems like a good compromise.
    Anyone get away with running a 12.5 inch tire on the stock TRD Pro rim?
  22. Nov 29, 2020 at 6:30 AM
    TelemarkTumalo
    TelemarkTumalo New Member
    Mark
    Bend, OR
    Falken Wildpeak 295/70 R18 on OEM set up. This tire measures out at 34.3" diameter and 11.9 width. 10 ply E rated. No mods. All flaps remain. No rubbing. Tires currently at 40 psi F&R and will experiment with pressure as the winter weather increases.
    BBTorCA, FISHN43 and TrenThom86 like this.
