How’s it look
Discussion in '1st Gen Tundras (2000-2006)' started by NEKyota, Nov 26, 2020.
  1. Nov 26, 2020 at 6:58 PM
    NEKyota
    NEKyota [OP] New Member
    Thanks in advance all! Looking at a 05 trd limited with 149k for 11,500 that’s had a professional undercoating. How’s it look to you fellas? sorry I don’t have pics of it on a lift.
  2. Nov 26, 2020 at 7:01 PM
    Lake.Life24
    Lake.Life24 New Member
    Shawn
    Upstate, NY
    2021 GMC Sierra 3500HD Gasser
    It appears clean. What type of undercoat? If they used a certain undercoat like zeibart stay clear. It traps moisture and will rot from the inside out
  3. Nov 26, 2020 at 7:37 PM
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    Looks great. So do the shocks. Is that woolwax on there? Or some rubber "stuff"
  4. Nov 26, 2020 at 7:42 PM
    Hi06silver
    Hi06silver Fat. Thumbs.
    2006 DC 4x4 Waltrip
    Kinda looks like they may have went over existing rust. Looks like some flakes or what have you. Where the metal basically separate and sheets apart. Hard to tell from pictures. I'd be concerned with the boxed in portion/ front of frame. There's evidence of rust in that picture. I'd poke around at it if they let ya. If not walk away. Doesn't look as smooth as I think it should if the metal was good before the application.
    N84434 and MS22 like this.
  5. Nov 26, 2020 at 7:51 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Those bubbly areas huh. There seems to be hints of orange peeking through here and there as well.
    FirstGenVol, Hi06silver and MS22 like this.
  6. Nov 26, 2020 at 9:33 PM
    Hooptytrix
    Hooptytrix Squeaky Chicken
    Dirty South
    2000 AC 4x4, 2001 AC 4x4 Sold. 2005 DC SR5 2WD
    The undercoat was put on for a reason which we truthfully cannot know. If you want a good truck, travel to the southern states. Last time I checked there were a few good trucks in Texas, New Mexico and Florida.
    I know it’s difficult for some to make such a journey to buy a truck but investing hard earned money on so-so vehicle will cost you more cash in the long run and not to mention the frustration.
  7. Nov 26, 2020 at 9:55 PM
    bassman417
    bassman417 "Tundra Time". My favorite time of day...
    Paul
    Las Vegas
    2004 DC 2wd Imperial Jade
    Pass. Like @Hooptytrix said. better and for cheaper 1st Gen tundras are plenty elsewhere in the usa. i see 2 here in las vegas right now rust free and cheaper than this.
    this one here is only 9k with 177k. 06 DC darryl waltrip ver..& NO RUST. Where are you at?
    Hooptytrix, FrenchToasty and N84434 like this.
  8. Nov 26, 2020 at 9:57 PM
    Hooptytrix
    Dirty South
    That’s a Waltrip wannabe :rofl:
    I know, my truck is 2 :rofl:
  9. Nov 26, 2020 at 10:11 PM
    Hooptytrix
    Dirty South
    Just a quick look around to see what’s around me. I usually avoid miami but this thing appears clean and they claim it to be garage kept
    But there are others,
  10. Nov 26, 2020 at 10:13 PM
    bassman417
    Paul
    Las Vegas
    here is another pic of it. not sure what the diff is.
  11. Nov 26, 2020 at 10:21 PM
    Hooptytrix
    Dirty South
    Actually from that pic I can see the red stripe, there should be a badge also. The waltrip came in 2 colors, silver sky metallic and blue (can’t remember name of the blue).
  12. Nov 27, 2020 at 4:11 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    I can't say the frame has any rust penetration issues, but it definately has rust on it that they simply covered over with that undercoating. And it appears to be "paint-type" vs a "fluid/oil" type of coating -- which is a problem. If you're going to paint something, you have to remove all the rust.
    Hooptytrix and N84434 like this.
  13. Nov 27, 2020 at 6:46 AM
    NEKyota
    Thanks all, I’m from northern Vermont and the truck is in NY and 5 hrs away. The undercoat was put on in 2018. I’ve asked for a few more pictures to see the other side of the frame and the rocker panels. Owner has said there is some surface rust but no rot. Only way to get a clean frame around here is if it has a new frame, but the last two new frame tundras I looked at had body rot... if this one is a no go I may wait till the summer when I can travel across country to get one.
    gotta have the double cab for our family too
    bassman417 likes this.
  14. Nov 27, 2020 at 6:53 AM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    It is a DW Tundra... You can just make out the signature decal on the left rear corner of the bedside... Tell tale grill, Red strip, and the decal on the rear
    Looks just like this VVV
    Hooptytrix[QUOTED] likes this.
  15. Nov 27, 2020 at 6:57 AM
    Hooptytrix
    Dirty South
    Now with that information, you definitely want to go south. These trucks are notorious for rust, you can find a clean DC 4x4 with no rust history, then spend a little and have the undercoating applied to protect your investment. Try and look in rural areas, stay away from the larger cities.
  16. Nov 27, 2020 at 7:22 AM
    Professional Hand Model
    Fred
    Hand Protectors
    Like @Hooptytrix says. He posts Tundras from S. Fla all the time with good condition at really good prices. Coolifornia is mostly overpriced from what I can see.
    Hooptytrix likes this.
  17. Nov 27, 2020 at 7:58 PM
    NEKyota
    Thanks again all! I got some more pictures from the seller and it looks like he’s spray painted everything, and the rust is still showing through. I don’t think it’s worth a day drive just to be disappointed
    Hooptytrix, Blue Thunder and N84434 like this.
  18. Nov 27, 2020 at 8:02 PM
    NEKyota
  19. Nov 27, 2020 at 8:08 PM
    N84434
    Milwaukee WI.
    2001 Limited TRD
    Keep looking... you're better off without that truck. Especially at the price he's asking. Mine was rough, but I got it cheap, and was confident in repairing it.
  20. Nov 29, 2020 at 2:45 PM
    NEKyota
    So...I had to go see it, went with cash just in case but with no intention to buy unless I was pleasantly surprised. And it will be no surprise to any of you it was a complete rust bucket underneath. The rest of the truck was pure mint and it was so hard to stomach. Owner let me spot check and peel off some undercoating, which turned out to be a rubberized undercoating. With the undercoating came layer after layer of frame. I could not find a single exposed piece of metal that was not rusted.
    For the life of your trucks please don’t use rubberized undercoating. There was one or two spots where the owners application of undercoat did not cover the Toyota recall spray and those spots were just fine. In 4 years that rubber undercoat has destroyed the truck.....(assuming the recall undercoat service did its job.
    the trip wasn’t a full waste of time as I know feel more confident in quickly passing on vehicles
  21. Nov 29, 2020 at 3:09 PM
    tvpierce
    Maine
    Yeah, folks learned in the 80s & 90s that rubberized undercoating was a disaster. Unfortunately, it still persists.
    The Toyota spray was not a legitimate solution -- they should have been sued over that. They knew they had a problem, and the spray just bought them a few years.
  22. Nov 29, 2020 at 5:11 PM
    lonedrake
    lonedrake New Member
    Minnesota
    2020 TRD sport
    Good call.
  23. Dec 1, 2020 at 4:08 PM
    Hooptytrix
    Dirty South
    I'm not sure if or when you may decide to try going south but let me know, I live 3 minutes from FTL airport and the poolside cabana room is private, you are welcome to stay. My house is for sale so that offer is for as long as I am here.
