2019 Tundra Tranny Temps 225-235F
Discussion in '2.5 Gen Tundras (2014-2021)' started by 2019CementTRD, Nov 25, 2020.
  1. Nov 25, 2020 at 1:21 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    I hear you. I too hit the same temps driving 80+ on my 2020 as well (according to Scan gauge).
    As far as I know the oil hasn't been reformulated but I'm not too concerned based on the reports shared so far. I will likely end up getting the cooler put on at some point. For now I'll change the fluid at earlier intervals as a precaution.
  2. Nov 25, 2020 at 1:27 PM
    Nomoredomestics
    Nomoredomestics New Member
    GA
    2023 TRD Sport 4x4
    Welcome to the forum. . .while this topic has been beat. . .literally. .to death. . .this still is a forum for discussion. . .if we don't wanna discuss, we don't have to chime in . I'm new here too. . .and there's a wealth of knowledge here. .
    Those Temps do sound high. . .is it extremely hilly in the area you were driving? Only thing I see possible is maybe the constant back and forth between gears :confused:
    Jaypown likes this.
  3. Nov 25, 2020 at 1:34 PM
    2019CementTRD
    2019CementTRD [OP] New Member
    Flat ground, on I-80 in Northern California. No constant gear shifts.....
  4. Nov 25, 2020 at 1:47 PM
    ....and 70 too. The more input the better. Ambient temps too.
  5. Nov 25, 2020 at 1:47 PM
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    Towing a boat in drive and my transmission pan tracked the oil pan temps. Nothing I was concerned about.
    Water boils at 212 and I find it concerning people are panicked over oil temps a little above boiling water.
  6. Nov 25, 2020 at 1:51 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    No issues from this well used ATF sample.
    GODZILLA and Saltyhero13 like this.
  7. Nov 25, 2020 at 1:56 PM
    Saltyhero13
    Yes but oil can break down at high temps diminishing its properties to protect the transmission components. What that threshold is I don't know offhand.
  8. Nov 25, 2020 at 1:57 PM
    2019CementTRD
    I'd have to re-read dozens upon dozens of threads, but I believe it was about 250-260F.
  9. Nov 25, 2020 at 2:03 PM
    Saltyhero13
    Sounds about right. Every 10 degrees above degrades the oil life by a factor of 2 from what I remember.
  10. Nov 25, 2020 at 2:16 PM
    Try driving in Fl. You have to drive fast to keep from getting ran over lol. Ha....have you seen the number of black Friday sales threads? Lol
  11. Nov 25, 2020 at 2:16 PM
    Kanobi13
    Kanobi13 New Member
    Where are the 2022 spied pics at? And welcome
    Jaypown likes this.
  12. Nov 25, 2020 at 2:35 PM
    timsp8
    NY
    I remember reading that some 19+ were seeing 230s not towing. Toyota says the fluid is good to 280 or so and the overheat light doesn’t come on until 302. 230 is nothing and you probably hit that cause you were driving 80 mph. It’s a heavy truck.
    Theoretically, a stock 19+ will never stay at 180-190 as the “warmer” will be carrying coolant through it that is hotter than that.
  13. Nov 25, 2020 at 2:37 PM
    Dragracer_Art
    Dragracer_Art New Member
    Dawsonville, GA
    2020 Crewmax 4x4
    5100's/+2.5" Eibachs, 18x9 +25 Methods,37x12.5 BFG KM3's
    Mine is a 2020 and 220's-230's was avg trans temp during normal driving, no towing.
    Adding the cooler dropped temps a solid 50 degrees.
    Before cooler:
    After cooler:
  14. Nov 25, 2020 at 2:39 PM
    2019CementTRD
    I understand that "a stock 19+ will never stay at 180-190" as my coolant temperature is a constant at 205F. Optimal though, is quite different than what is realized through this application as opposed to theoretical engagements.
  15. Nov 25, 2020 at 2:39 PM
    2019CementTRD
    THIS^ is what I am after. Thank you sir.
  16. Nov 25, 2020 at 2:46 PM
    timsp8
    NY
    I think you’re looking for a problem that doesn’t exist. If towing, get a cooler. If not, there hasn’t been any proof of cooked transmissions. The original post is full of misconceptions and facts that have been disproven. 230 isn’t the death of current transmissions.
  17. Nov 25, 2020 at 2:50 PM
    2019CementTRD
    Dispoven because Toyota states that WS is okay until 280F? Right. Aisin makes very robust transmissions. That is not to say that their life can't be extended substantially by lowering the temps 20-30F. As stated here and on other forums with fluid engineers/tribologists- HEAT is the main factor in whether the transmission can go 100K or 400K.
  18. Nov 25, 2020 at 2:53 PM
    2019CementTRD
    If "I was looking for a problem that doesn't exist" then why even have Nick offer the tranny cooler? Why is the lack/omission of it such a big deal to some, dude? Seems counterintuitive.
  19. Nov 25, 2020 at 2:57 PM
    timsp8
    NY
    Cause some people tow.
    I’m not going to point out everything that’s wrong with your original post cause your mind is made up and it’s clear you are just looking for others to reinforce your opinion. You’ll never get a stock 19+ 20-30 lower than 230 while going 80mph.
    Good luck in your endeavors. Happy thanksgiving. Dude.
  20. Nov 25, 2020 at 3:11 PM
    #50
    2019CementTRD
    Please point out "everything that is wrong." Other than my speculative conjecture based on circumstantial supposition (from relevant VOA/UOA's of WS) that the fluid is spent, I am all ears.
  21. Nov 25, 2020 at 3:14 PM
    #51
    Saltyhero13
    Post your oil analysis.
    14burrito and Cpl_Punishment like this.
  22. Nov 25, 2020 at 3:14 PM
    #52
    2019CementTRD
    BTW, I would be willing to wager that when a fluid exchange is done with a top quality synthetic, that the temps would be reduced. Yes, that is an "assumption" that I would be willing to make.
  23. Nov 25, 2020 at 3:15 PM
    #53
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    So make the swap and let us know how it goes.
  24. Nov 25, 2020 at 3:17 PM
    #54
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    And here we go again.
  25. Nov 25, 2020 at 3:17 PM
    #55
    2019CementTRD
    I will absolutely do that. However, it is not the basis of this thread. The premise was to illicit responses from folks who may have seen the same temperatures. While the fluid may be "serviceable" as is, it has been concluded, that it is an inferior fluid and there are much better choices out there.
  26. Nov 25, 2020 at 3:20 PM
    #56
    2019CementTRD
    I appreciate the input all. Happy Thanksgiving.
  27. Nov 25, 2020 at 3:29 PM
    #57
    tttrdpro
    SWGA
    2024 GMC 2500 AT4
    In progress…
    What’s the biggest tire I can run without a transmission cooler?
    GODZILLA, JLS in WA, RPO 579C and 9 others like this.
  28. Nov 25, 2020 at 3:31 PM
    #58
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Well I have 35s and my fluid hit 285 this weekend and the transmission doesn't work now, and I have a cooler. Maybe that'll help you :D
  29. Nov 25, 2020 at 3:32 PM
    #59
    2019CementTRD
    This is one way to increase your post count in aspiration of becoming a forum veteran, but without adding value to the discussion it only diminishes your credibility.
  30. Nov 25, 2020 at 3:35 PM
    #60
    tttrdpro
    SWGA
    2024 GMC 2500 AT4
    In progress…
    Thanks man! Right back at you! (BTW I don’t give a shit about post count or credibility.) Have a nice Thanksgiving!
