Hertz or kenwood components?
Discussion in 'Audio & Video' started by BrandonL812, Nov 24, 2020.
  1. Nov 24, 2020 at 8:36 PM
    BrandonL812
    BrandonL812 [OP] New Member
    Brandon
    2021 Tundra Platinum
    I am looking for opinion between these two brands. I would like to upgrade my stock jbl speakers to something better, component set. From research on here, quite few have the Hertz k170, k165 set. Some said they are too "bright", other likes them just fine.
    I will be powering them with a pioneer 5 channels amp gm-d9705. Android headunit.
    Looking for opinion between the
    Hertz k170, k165
    Vs.
    Kenwood kfc-p710s
    Why one over the other?
    Any experience with the kenwood component or how they sounds?
    T.I.A
    jonjolie likes this.
  2. Nov 24, 2020 at 9:07 PM
    jonjolie
    jonjolie New Member
    Monrovia, CA
    2015 MGM Tundra SR5 4X4
    Gonna follow this post. I've been wanting to upgrade my system as well.
  3. Nov 25, 2020 at 8:49 PM
    BrandonL812
    Brandon
    Anyone?
    Bueller, Bueller, Bueller
    Comparing specs. Hertz looks to have slight edge over frequency response and sensitivity.
    Hertz:
    Freq resp: 55-23,000 Hz
    Sensitivity: 93.5dB
    Kenwood :
    Freq resp: 63-24,000 Hz
    Sensitivity: 86dB
    So the hertz can play lower frequency. Louder for having higher sensitivity dB.
    Dont know bout the tweeter though, really dont want too "bright" of a tweeter.
    Rica25 likes this.
  4. Nov 26, 2020 at 1:37 AM
    jwatt
    jwatt I heart men
    Jack
    Oregon
    Salsa Red 2007 Tundra DC @91k.
    7" BDS Coilover Suspension Lift/BDS UCAs/XB LED Headlights/Nitto trail Grappler tires on Black Rhyno Armory wheels
    Just curious, but why just those two brands? There are many brands that are good.
    Rica25 likes this.
  5. Nov 26, 2020 at 5:21 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Rica25 and BrandonL812[OP] like this.
  6. Nov 26, 2020 at 5:37 AM
    BrandonL812
    Brandon
    It's within the price range of "i'm cheap". Plus seems like what most people on here ran the Hertz and kenwood seems "similar" in specs.
    Honestly I dont know much bout audio speakers. I know sounds is subjective to each person, but really trying to avoid the "buying and returning" process if end up not liking them.
    Budget wise i guess if i can get away with $100 and under a set with decent sound. I'd stick with it.
    Rica25 likes this.
  7. Nov 26, 2020 at 10:02 AM
    jwatt
    jwatt I heart men
    Jack
    Oregon
    Well I can respect that. Being cheap can have it s advantages, but when it comes to quality sound, I have to say, good luck with that. My problem has always been a dis satifaction with the result when I try to go the cheap route, which in turn, causes me to go with something different. Now a days, for me, being frugal is secondary. Quality, and specs are what really matters, but I guess as long as one can live with the results, it s all good.
  8. Nov 26, 2020 at 10:54 AM
    BrandonL812
    Brandon
    Honestly, i rarely get to turn up the volume in this truck. Every time we take it out, we have our 2.5yrs old with us. So that usually mean kids movies or youtube nursery songs. Every once in awhile im on my own. So, i can live with sub-$100 price range. I do know I'd like more than factory sounds
    Rica25 likes this.
  9. Nov 27, 2020 at 6:10 AM
    zach_attack4
    zach_attack4 New Member
    Zach
    York, PA
    21 Army Green CM
    I installed the K165 component speakers all around using the same 5 channel pioneer amp you specified and a Kenwood headunit. I'm also running two Rockford R2D2-10 subwoofers off the fifth channel. Overall it sounds waaaaaaay better than factory. I did put deadening material on all the doors while doing the install to help clean up the sound a bit but haven't yet bothered with the rear wall, floor, or roof.
    I'll agree with some people who say its very bright. I initially thought the same but after time and some adjustment on the EQ, I can say I'm very happy with where the sound is at. Even at volumes where you can hold a normal conversation, nothing is overbearing. When listening to just the Hertz speakers, don't expect a lot of thump. While adjusting the EQ I turned off the subs and played with just these since I haven't replaced any of the dash speakers yet. Again, they're very clean but require other speakers to give you that full sound.
  10. Nov 27, 2020 at 6:17 AM
    BrandonL812
    Brandon
    When you adjust the EQ, did you have to retune your amp's gain?
    I have replaced the dash speakers with some kicker 2.75" 47ksc2704. I am also running an 8" polk subwoofer in the factory plastic box. Just ordered some kilmat 80mip 36yrd.
    Did the sound deadening help with the mid bass at all?
    Thanks
    Rica25 likes this.
  11. Nov 27, 2020 at 6:27 AM
    zach_attack4
    Zach
    York, PA
    21 Army Green CM
    I adjusted my amps gain to get my volume balanced the way I wanted and then adjusted the EQ to get the sound I wanted.
    I can't say that the sound deadening helped with the mid bass since I didn't compare before and after, however, the deadening certainly helped cut out external noise. That in itself helps more than people tend to realize. I did use the foam rings and baffles on the components as well to try and get the most out of them.
    Rica25 likes this.
  12. Nov 27, 2020 at 6:30 AM
    BrandonL812
    Brandon
    I have the foam rings sitting here waiting to get install when everything comes in. Still trying to decide on speakers.
    Rica25 likes this.
  13. Nov 29, 2020 at 6:04 PM
    jwatt
    jwatt I heart men
    Jack
    Oregon
    Not me. When I took out the back seats, and applied deadener to the area under the back windshield, and behind the seatbelt trim my mids bass got noticably lower. The first time I noticed it I was looking at other cars around me to see where the bass was coming from. Then I realized it was me:D
  14. Dec 1, 2020 at 7:47 PM
    BrandonL812
    Brandon
    I decided to go with the CDT CL-61 component set.
    We wil see how it does. Price was good. $120 shipped.
  15. Dec 2, 2020 at 10:16 AM
    jwatt
    jwatt I heart men
    Jack
    Oregon
    Good deal. 50% off makes a big difference.
  16. Dec 2, 2020 at 10:31 AM
    jwatt
    jwatt I heart men
    Jack
    Oregon
    Something I noticed . The crossover image for that set shows what I think is the EX 530, but if you look in the crossover section, the EX 430 crossover, which comes with the CL 61 set. looks different.
    Rica25 likes this.
  17. Dec 2, 2020 at 10:33 AM
    BrandonL812
    Brandon
    Yeah. Strange. The description said EX-430 but the photo is of something else?
    I dont know??
    I send them an email. Will see what they say.
    Rica25 likes this.
  18. Dec 2, 2020 at 10:43 AM
    BrandonL812
    Brandon
    Got a respond back. That was super quick. Bout 10mins.
    Here's what they said.
    "Hi,
    We are out of EX-530 so we will ship an upgrade to EX-560CDiX"
    So i guess im getting an upgrade?
    Rica25 likes this.
  19. Dec 2, 2020 at 1:16 PM
    jwatt
    jwatt I heart men
    Jack
    Oregon
    I can t find that model on the site. If it s anything like this it s a major upgrade. The better models of CDT s crossovers usually include image tweeter outputs. This allows you to add a second set of tweeters to your sound stage. Mine are affixed to the top corners of the windshield pointing to center of dash. This site explains.
  20. Dec 2, 2020 at 1:26 PM
    BrandonL812
    Brandon
    Yeah, that's the exact one that i could find on their website. Not sure why they said "iX" at the end. Can't find it on google either. Well, I'll report back once it gets here. Upgrade would be sweet.
    Thanks for the read. Pretty interesting information on that site.
    Rica25 likes this.
  21. Dec 2, 2020 at 1:28 PM
    jwatt
    jwatt I heart men
    Jack
    Oregon
    Yea. These dudes are old school audio. You can tell the site is dated, but in my experience they are a solid brand, and you can get some beastly wattage speakers.
  22. Dec 2, 2020 at 1:33 PM
    BrandonL812
    Brandon
    I wanted to get away from the main stream brand a little and try something different. I think the cdt will fit the bill quite nicely.
    Website definitely needs a little work. Some info are slightly off, not much but a little, between the pdf tech sheet vs the product descriptions. I've read on diymobileaudio.com that the owner is pretty cool and knowledgeable but he also ran the website by himself. Which explains why it's needed update. He's super busy also.
  23. Dec 2, 2020 at 1:39 PM
    jwatt
    jwatt I heart men
    Jack
    Oregon
    This tread it an interesting read. It talks about CDT
  24. Dec 2, 2020 at 2:27 PM
    BrandonL812
    Brandon
    That's the exact thread i read before. Seems like he's a 1 man show majority of the time. Language barrier doesnt help. But people seems to be quite satisfied with his products.
  25. Dec 10, 2020 at 5:29 PM
    BrandonL812
    Brandon
    Ups dropped these off today. They DID upgrade me to the better 2way crossover like they said they would. It looks real nice and quality speakers.
    Next step is to find time to sound deaden the doors and mount these puppies up.
    Ordered the CL-61 but the slip said it's the CL-61Pro. Not sure if they are the same thing or not. But im not complaining.
    20201210_201222.jpg 20201210_201250.jpg 20201210_201729.jpg 20201210_201739.jpg 20201210_202245.jpg
  26. Dec 28, 2020 at 8:41 AM
    BrandonL812
    Brandon
    Front: Cdt cl61
    Rear: Hertz k165
    Corner dash: cdt
    Finished.
    20201227_140719.jpg 20201227_135027.jpg 20201227_135014.jpg 20201221_231020.jpg 20201222_164304.jpg 20201227_200216.jpg
