Power Steering too stiff
Discussion in '1st Gen Tundras (2000-2006)' started by Elsinore, Nov 22, 2020.
  1. Nov 22, 2020 at 5:04 PM
    Elsinore
    Elsinore [OP] New Member
    Edwin
    Toyota Tundra 2002
    Hello everyone, i'm new at the forum and need your help.
    my toyota tundra 2002 v8, has this issue with the power steering, it is too stiff, specially in the morning when cold. gets better when warm but still doesn't feel right, it kind of pulsates when turning. previews owner put a new rack and pinion and I put a new power steering pump and problem is still there.
    I'm new at Tundras and I love it, i will appreciate any suggestions.
    Thanks.
    YardBird likes this.
  2. Nov 22, 2020 at 7:37 PM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    Welcome to the club... what fluid are you using and what was the replacement pump? New or rebuilt?
  3. Nov 22, 2020 at 9:45 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    I’m suspecting your lower steering shaft U-joint is binding up. It is located just above the steering rack, and if you soak it down with penetrating lube you should notice an improvement. This is not a fix in itself though, and the lower shaft with U-joint must be replaced for lasting / safe results.
    jpink, Elsinore[OP], Glock 40 and 2 others like this.
  4. Nov 22, 2020 at 9:53 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  5. Nov 23, 2020 at 10:11 AM
    N84434
    Milwaukee WI.
    2001 Limited TRD
    Ohh... Good thought...
  6. Nov 23, 2020 at 2:47 PM
    Professional Hand Model
    Fred
    Hand Protectors
    I think I may oil and grease this u-joint tomorrow after a few cups of coffee just because. Snap a few pics and report the findings.
    jpink, landphil and N84434 like this.
  7. Nov 23, 2020 at 5:46 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    While not rampant, this is a common-enough issue with 2nd gen Tacomas.
    Now, the u-joint is sealed and not serviceable, but I’d still coat the outside if mine with Fluid Film every fall to ward off the evil...
    ...salt and water. :mad:
    As I said before, if the u-joint has gotten to the point of binding, it should be replaced as the seals have failed, and the cross, needles, and cups of the u-joint are corroded. No spray lube will change that, even if it feels better for the short term.
    But, if your u-joint is still working as Momma Toyota intended, then some sort of lube on the outside might just help it stay that way. :thumbsup:
  8. Nov 23, 2020 at 7:31 PM
    Elsinore
    Edwin
    Toyota Tundra 2002
    thank you all, i'm impressed by your help, i will work on that lower U Joint and i will keep you posted.
  9. Dec 6, 2020 at 1:32 PM
    Elsinore
    Edwin
    Toyota Tundra 2002
    Thank you all, took me a couple of days to find the U joint but after proper lubrication, problem was solved before driving out of the driveway.
  10. Dec 6, 2020 at 1:36 PM
    Glock 40
    Glock 40 I'm here to break shit
    Yukon Cornelius
    Way up thar
    2000 AC Limited 4X4 4.7L
    Deadpool Edition
    hmmmmm... I'm gonna have to inspect this on mine.
  11. Dec 6, 2020 at 3:13 PM
    Stuck in the '00s
    Stuck in the '00s Experienced member
    Mikey
    SE Wisconsin
    2004 Phantom Gray DC 4X4 Limited Tundra
    Western plow, custom bed
    Was just catching up on this thread and thought about your problem and was gonna link it, but you're already there, G.
    Hope it does the trick!
    Tundra2 likes this.
  12. Dec 6, 2020 at 3:20 PM
    Fred
    Hand Protectors
    Never hurts to lube your stuff. Shoulda thought about this one while I had the grease out today.
  13. Dec 6, 2020 at 3:21 PM
    FirstGenVol Brake Czar
    2002 AC
    That's right before the firewall? Didn't realize it could be greased
  14. Dec 6, 2020 at 3:24 PM
    Stuck in the '00s
    Mikey
    SE Wisconsin
    This proves you're never too old to learn something new..now if I can remember it... :homer:
  15. Dec 6, 2020 at 3:28 PM
    Fred
    Hand Protectors
    I was going to do it last week and forgot. :annoyed:
    Think I was more into enjoying the Dark Roast Coffee that day. :rofl:
  16. Dec 6, 2020 at 3:36 PM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    Is there a grease zerk on the thing?
    Stuck in the '00s likes this.
  17. Dec 6, 2020 at 5:04 PM
    Stuck in the '00s
    Mikey
    SE Wisconsin
    I gotta feeling not, but should.
  18. Dec 7, 2020 at 3:57 AM
    Fred
    Hand Protectors
    The vision of jacking the front of the truck up and slathering grease on that u-joint came to me last night. A couple shots of 3in1 Oil for the Joint Primer and MolyB as the Grease Wad. Turn wheels. Slather. Repeat until full lube.
  19. Dec 8, 2020 at 3:31 PM
    Wingryder
    Wingryder New Member
    Hello.. landphil.. I have the same year 2002 Tundra and the only U-joint on the steering shaft is right at the firewall. (this might be what you meant when you said right above the rack) There is a coupler called the rag coupler right above the rack but it is in line with the steering shaft and no angle change is needed at that point. I do have one question.. how do you get that lower shaft out?. I understand how to remove the rag coupler and assume the shaft comes out up and under the steering wheel. Banging on the upper steering shaft to remove lower makes me nervous. And you are right .. Lubrication of the u-joint is only a indication you found the problem.
    corrections welcome.
    dm
  20. Dec 8, 2020 at 5:30 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Hmm, that proves that my memory of what a 1st gen looks like from underneath is a wee bit foggy. It’s been a while, but :facepalm:. My bad! I was thinking of how my 2nd gen Tacoma was, and (I think, not even sure now) my 2nd gen Tundra, and thinking the 1st gen Tundras were the same.
    I haven’t changed a steering shaft in any gen. Tundra myself, but maybe another member like @empty_lord can chime in with the right knowledge.
  21. Dec 8, 2020 at 5:42 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Youve got stiff steering? Check all the suspension. I’ve never seen a 1st gen shaft cause this issue. There’s no u joint on the external shaft on the 1st gens, the joint is on the interior column on these
    Stuck in the '00s and landphil like this.
  22. Dec 8, 2020 at 9:12 PM
    Wingryder
    Well here is what I know. 160k Stiff and heavy to steer at slow speed. Not real noticeable on the highway. No pulling or wobbles. No noise. Two pumps did not help. About ready to order a rack when saw a post about binding steering shafts. Yes these were on vehicles with exposed u-joints. However.. I gave my "in the cab" joint a heavy dose of PB blaster and it changed the truck. No doubt it was binding. Smooth as can be now. I will have a replacement ready when the binding returns. (that dust seal was shot also which would let the elements into the joint in question.) I know that pen. oil is temp. Any suggestions of a spray product that would lubricate a non greaseable u-joint and last?
    Also so.. as said it could still be partially related to suspension.
  23. Dec 9, 2020 at 4:26 AM
    Fred
    Hand Protectors
    Man I’m chomping at the bit to get to this u-joint lube job. Maybe get to it Friday if my ass of a boss gives me a day off.
    No problems currently other than when cold (like always) the steering is a little stiff(er) before warm up.
    Tundra2 likes this.
  24. Dec 11, 2020 at 5:19 AM
    Fred
    Hand Protectors
  25. Dec 12, 2020 at 12:43 PM
    Fred
    Hand Protectors
    Lubed those u-joints with MolyB Grease on a toothbrush. I put a few drops of 3in1 Oil on first.
    The u-joints looked fine and actually still had plenty of grease in and around them as best as could be seen. I turned the steering wheel whilst inspecting for any play in them and nothing. Looked good in there. Tightened up the 10mm bolts a hair. The larger 14mm bolt was rock solid.
    Conclusion: No improvement. Felt same as before which has been a perfectly fine steering wheel for years. 45 minute job tops.
    No after pics of the greasings, but I loaded it up.
    Glock 40 and YardBird like this.
  26. Dec 12, 2020 at 4:24 PM
    Wingryder
    Hand Model..quote "Conclusion: No improvement. Felt same as before which has been a perfectly fine steering wheel for years. 45 minute job tops." If you were not having problems not sure what improvement you were expecting
  27. Dec 12, 2020 at 4:46 PM
    Fred
    Hand Protectors
    Good point. I did it as a case study. I wasn’t expecting any improvement but did it anyway to see if it did any improvement. At worst I wasted 45 minutes and about 1oz of U-joint MolyB grease. At best, I added some Silglyde down the Steering Donut for lube and sound deadening purposes. Win win and nothing got Mangled. :D
  28. Dec 30, 2020 at 7:50 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Mine looks like the pic in post #9 with the boot over the joint. Did you remove the boot when you did yours and if so, does it just slide up?
  29. Dec 30, 2020 at 9:50 AM
    Wingryder
    Yes remove the boot. Held on by four (I think) small bolts . (pull carpet and insulation back) It is a split arrangment and you are removing the rear.. cover.... Review the pics provided by "hand model " in post 25
  30. Dec 30, 2020 at 9:55 AM
    Wingryder
    Hand models Post 24 shows the cover and bolts
