Pedal Commander: Tell me Pros & Cons
Discussion in 'Performance and Tuning' started by MedicRN, Nov 15, 2020.
  1. Nov 19, 2020 at 8:55 PM
    #91
    MedicRN
    MedicRN [OP] You can't fix stupid... but you can sedate it.
    2014 5.7L V8 SR5 CrewMax 4x4
    I think because if you’re stock height or barely lifted like 1” and want a vehicle that feels more stuck to ground during power delivery it could be a fun feeling. But at the end of the day I think many people lift or plan of lifting their truck enough to not have a sway bar.
    also another member mentioned that the increased throttle response helps his truck feel less sluggish now that it is lifted and has larger tires. But if you can slap a sway bar on there... why not?
  2. Nov 20, 2020 at 1:17 AM
    #92
    maxdriver
    maxdriver New Member
    ‘23 GRolla, sans ‘19 Tundra
    I should have added an emoji as I can see I wasn't clear with what I wrote. I have read quite a bit about the PC and it appears to be a solid performance enhancement...!
  3. Nov 22, 2020 at 5:48 PM
    #93
    Saltyhero13
    Saltyhero13 Throbbing Member
    @MedicRN @andnyleswillriot
    I tried ECO +4 today cruising around, its not too bad getting around. Its a setting I could live with on a daily basis. ECO -4 is a NoGo for my needs however. As far as gas savings its something that would need to be tested long term.
    MedicRN[OP] likes this.
  4. Dec 22, 2020 at 7:27 AM
    #94
    1rebmem
    1rebmem New Member
    Jef
    TN
    2018 SR5 4x4 Inherited from my dear dad RIP 4/21/2020
    Two years old and 5200 miles when I took ownership
    I just got around to installing the Sprint booster. I paid $232 total for it. And like everyone else who bought this or the Pedal Commander, I'm loving it. Totally changes the feel of the truck with the very snappy throttle response. I will experiment and compare the Sprint Booster to the Tundra Tow Haul function and report back.
    This controller is detachable, leaving the main device connected to your gas pedal so you don't have anything attached to your dash:
    Has a switch to select if you have a manual trans or automatic:
    Gets installed inline with the gas pedal circuitry:
    You set the mode by pressing the silvery "Sprint" button and the left/right arrow buttons. You can also press the Sprint button to shut the Booster off, restoring the truck to original:
    chugs and Saltyhero13 like this.
  5. Dec 22, 2020 at 8:03 AM
    #95
    Saltyhero13
    @1rebmem Make sure you have the proper safety equipment on:
    1rebmem and Bakershack like this.
  6. Dec 22, 2020 at 8:53 AM
    #96
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Thanks for the pics and writeup! If I get everything I expect for Christmas, this will be on my birthday list (March b-day)!
  7. Dec 23, 2020 at 5:09 AM
    #97
    1rebmem
    1rebmem New Member
    Jef
    TN
    Right! It came shipped on "Race 5" mode. I had to lower it, kept spinning the tires everytime!
    Saltyhero13[QUOTED] likes this.
  8. Dec 25, 2020 at 6:12 PM
    #98
    bjohnson425
    bjohnson425 New Member
    Brandon
    I’m going to sell my pedal commander. I bought it for my 4Runner and loved it. I can’t seem to find a setting I like with it in the Tundra . It’s either too sensitive or too sluggish IMO. I know I’m on the minority on the issue but the tow/haul button satisfies my go fast needs.
    BravoDeltaRomeo likes this.
  9. Jan 5, 2021 at 11:59 AM
    #99
    rbros
    rbros New Member
    2021 White Limited TRD
    Returning mine today. Doesn't seem to be compatible with the 21's or I got a defective unit. Worked ok but had surging on multiple levels. Tried to update it and couldn't because it would only powerup when the engine was running, not under the ACC like it should. I'll wait another year until they get the bugs worked out for the 21's I guess.
  10. Jan 8, 2021 at 7:02 PM
    #100
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    I have a 2021 and it works as designed.
  11. Mar 31, 2022 at 4:44 AM
    #101
    MALIBU1794DC
    MALIBU1794DC New Member
    2019 Double cab 1794
    Got one for my dad's 19.
    He's not a car guy what so ever.
    But he had a 2007 5.7 DC limited, and that thing had the most awesome throttle. You would feather it off the line. 1%, 2%,3%,4%,5% .....barely touching the throttle , and you'd get to 40 mph at a nice smooth rate.
    Anyone who drove that truck for the first time , would not expect it to have that sharp a throttle, with the torque the motor can make off idle, it would buck and jump.
    I'd have to tell everyone to relax, and barely feather it.
    The pedal commander on sport 3 feels like what the stock throttle felt like on the 2007.
    I just set the pedal commander to that
    And tucked it by the pedal, there's a carpet flap by the transmission tunnel.
    I just leave it on that one setting , sport 3.
    Been working just fine. I'm expecting the pedal commander to hiccup eventually. But it hasn't.
    The pedal commander and TRD rear sway bar, made the tundra feel half as big, because of the added agility.
    My dad the non car guy, keeps saying how these mods made it so much easier to drive.
    I'd recommend those 2 mods to anyone. Toyota should have sold all the tundras like that stock.
    I guess they figured if someone wants a rear sway bar, they'll just buy it from them.
    Good mods
    dirtydeeds likes this.
