Cause of annoying creaking sound in back seat
Discussion in '2.5 Gen Tundras (2014-2021)' started by Mad Max, Nov 22, 2020.
  1. Nov 22, 2020 at 12:08 PM
    Mad Max
    Mad Max [OP] New Member
    Max
    2021 Tundra Limited
    When someone sat in my back seat I would get a horrible creaking sound. I lubed the hinge, no success. I finally determined if I loosed the front bolt it went completely away. So I put electrical tape under the washer and reinstalled. Creaking sound returned, put grease between seat track and body, creaking sound returned, put electrical tape between washer and bolt, creaking returned. Solution I left the bolt loose or finger tight. Unbelievable it makes so much noise when tightened. hope this helps
  2. Nov 22, 2020 at 1:01 PM
    timsp8
    NY
    Do you have leather? Mine creaked and it was the back rubbing on the rear wall of the truck. I put some furniture sliders on it and the noise went away.
  3. Nov 22, 2020 at 1:05 PM
    Mad Max
    Max
    2021 Tundra Limited
    Yea i had that sound but quickly solved with some felt between leather and truck. This is a creaking vs rubbing. Thanks anyways!! Didn't make any noise unless someone sitting in it and moving around as truck bounces.
