2020 Tundra Crew Max sub woofer box
Discussion in 'Audio & Video' started by JcGc, Nov 19, 2020.
  1. Nov 19, 2020 at 4:11 PM
    JcGc
    JcGc [OP] New Member
    2020 Crewmax 4x4
    4/2 Ready lift Kenda Klever 35 x 12.50 x 20 XF Off road wheels
    Hey all,
    I just pulled the trigger on all my stereo system upgrade components, except my subwoofer box. I found a box for 10's, but I don't know if it will fit behind the back seat. Here are the measurements:
    • 15-1/4" Tall
    • 20-1/4" Long
    • 7-1/2" Wide
    • 5-3/4" Mounting Depth
    If this will fit, I plan on buying two of them for behind the back seat.
    As always, thanks in advance!!!!!
  2. Nov 19, 2020 at 9:06 PM
    preacher35
    preacher35 RIGHTEOUS MEMBER
    2018 MGM Platinum Crewmax 4x4
    When you say: 7-1/2" wide, are you referring to how deep it is from front to back at the bottom of the box? If so, it will not fit. I do not exactly remember the dimensions of my Tech12Volts sub box, but I know it was no deeper than 6" at the very bottom. And mounting depth was no deeper than 4.75". Not to mention that James (@ Tech12Volts) has to cut a rectangular relief, just to the left of the right side sub hole, to enable the box to clear one of the rear seat brackets. AND, in addition, to give an extra .25" of sub-magnet clearance, he actually cuts holes in the back of said box, and covers them with a much thinner wood to seal it all up. Bottom line is, you had better be very confident on the measurements before you drop money. Or, better yet, just purchase your box from James @ Tech12Volts and save yourself the trouble. Mine rocks. Glad I took the advice from those before me!
  3. Nov 20, 2020 at 12:08 AM
    TXTundra2722
    2015 Black Tundra
  4. Nov 20, 2020 at 2:28 PM
    JcGc
    2020 Crewmax 4x4
    See this is why you ask questions first before spending money. Now I know the box will not fit. Thanks for the info
