Toyo AT3 coming March 1st
Discussion in 'Wheels & Tires' started by Spakylpm, Jan 23, 2020.
  1. Nov 1, 2020 at 8:18 AM
    #391
    Ltaco17
    Ltaco17 New Member
    NC
    2023 TRD Pro
    285/75/18 Falken Wildpeak R/T color matched handles and mirrors.
    Not much difference. The AT3 maybe slightly quieter but not much.
  2. Nov 1, 2020 at 8:21 AM
    #392
    Ltaco17
    Ltaco17 New Member
    NC
    2023 TRD Pro
    35x12.50x18 D rated AT32BA50653-E6B7-49B4-819E-933F98192DA3.jpg0E2EAA9C-BFE3-4BAE-BFA7-81FD165C0E0A.jpg 2BA50653-E6B7-49B4-819E-933F98192DA3.jpg 0E2EAA9C-BFE3-4BAE-BFA7-81FD165C0E0A.jpg
  3. Nov 1, 2020 at 9:49 AM
    #393
    Tundra_power
    Tundra_power New Member
    Was their any performance loss. You are affecting the overall final gear ratio but it might be to little to tell.
  4. Nov 1, 2020 at 9:53 AM
    #394
    itsmerh85
    itsmerh85 New Member
    Gilbert, AZ
    2020 Black TRDPro
    I know you've posted this before but couldn’t find it - did you have to modify anything other than the front flaps to fit the coopers @ 285/75? I have a pro so already have a minor front lift.
  5. Nov 1, 2020 at 10:45 AM
    #395
    Zero One Actual
    If the pro lift is close to three inches like the Bilstein 6112s on top setting then you will be fine. I also have total chaos UCAs as well. But I didn’t have to trim or remove anything with my setup. I now have the Toyo MTs in the same size and still have no issues. Did a realignment to adjust the caster and everything and all is still good.
    itsmerh85[QUOTED] likes this.
  6. Nov 1, 2020 at 4:12 PM
    #396
    somecrazyguy
    somecrazyguy New Member
    Steven
    New Braunfels TX
    2020 Limited 4x4 Crewmax Silver Sky
    Since they're p-rated and not too heavy at this size, they drive a lot like stock except: 1) a little louder and 2) a little slick when wet. For me, no noticeable performance loss.
  7. Nov 1, 2020 at 7:35 PM
    #397
    Highsierraguy
    Highsierraguy New Member
    Nor Cal
    Swapped my bfg 285/70r17's for these in 285/75r17 load C. They are definitely louder than the BFGs and have a high pitched hum, even with Load C. They look way better on my truck in this size though.
  8. Nov 4, 2020 at 4:59 PM
    #398
    wiretwister
    wiretwister Sorta new guy
    NJ
    '22 SR5 CM
    Has anyone had a chance to test these in some deep snow and/or icy conditions?
  9. Nov 17, 2020 at 1:35 PM
    #399
    Tundra_power
    pulled the trigger on some p285/55r20 at3 they look nasty I love the sidewall really agressive for a p rated tire..
    somecrazyguy and Flyinryank like this.
  10. Nov 17, 2020 at 1:37 PM
    #400
    Flyinryank
    Flyinryank New Member
    Las Vegas, NV
    White 2015 CM 4x4
    Looks good. What wheels are those?
  11. Nov 17, 2020 at 9:17 PM
    #401
    Highsierraguy
    Nor Cal
    Thanks. Method 313, +25 offset.
    Flyinryank[QUOTED] likes this.
  12. Nov 19, 2020 at 7:48 PM
    #402
    Green Thunder
    Green Thunder Smooth in the Cruise
    Washington
    2020 Burnt Green TRD Pro
    Food crumbs and dog fur
    I need to stop reading this thread...didn’t know they offered a load D rating... that’s a good compromise...
    Correction...only E in 275/70-18. Lame
  13. Nov 20, 2020 at 7:48 AM
    #403
    1794x4
    1794x4 New Member
    Gary
    2019 Tundra 1794 4x4
    Just purchased LT 265.60.20 's load range E I like their looks but not many miles yet. They drive great just came from KO2's 8 ply 275.60.20.
  14. Jan 2, 2021 at 11:39 PM
    #404
    16TRD
    16TRD New Member
    Norcal
    2016 White crewmax
    As far as ride comfort and road noise what do you like better between the cooper and at3?
  15. Jan 3, 2021 at 3:12 AM
    #405
    Zero One Actual
    They are identical. The Cooper has a longer warranty but other than that it’s a draw. You can’t go wrong with either one.
  16. Jan 3, 2021 at 9:24 PM
    #406
    16TRD
    16TRD New Member
    Norcal
    2016 White crewmax
    Would you guys say a 275/65 or 275/70 safe to run on 18x9 wheels?
  17. Jan 3, 2021 at 9:58 PM
    #407
    16TRD
    16TRD New Member
    Norcal
    2016 White crewmax
    Do you have a side photo?
  18. Jan 3, 2021 at 10:43 PM
    #408
    BayRunner
    BayRunner I’m here, except when I’m not
    2017 Tundra Platinum
    275/70R18
    Flyinryank and Green Thunder like this.
  19. Jan 3, 2021 at 10:55 PM
    #409
    16TRD
    16TRD New Member
    Norcal
    2016 White crewmax
    Are you lifted in the front? Im looking at the same size or maybe stay stock size
  20. Jan 3, 2021 at 11:02 PM
    #410
    BayRunner
    when this pic was taken, the front was leveled with 6112’s at the 1.9” notch. I have since gone up to a 3/1.75 lift with 295/70R18 Toyo’s.
  21. Jan 4, 2021 at 6:49 AM
    #411
    PhysicZ
    PhysicZ 1g3
    Robert
    2013 MGM Tundra crewmax
    16TRD[QUOTED] and Green Thunder like this.
  22. Jan 4, 2021 at 12:13 PM
    #412
    16TRD
    16TRD New Member
    Norcal
    2016 White crewmax
    Are you stock in the front? I have the same wheels and seeing if I can run the same size 275-70-18 stock.
  23. Jan 4, 2021 at 3:19 PM
    #413
    PhysicZ
    PhysicZ 1g3
    Robert
    i have 6112s at 1.9 setting up front, not sure bout stock but there are plenty of threads about that
  24. Jan 5, 2021 at 4:29 PM
    #414
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    65 for sure - that's standard on Tundras. And on Toyo's website they recommend 8.0 to 9.5 for 65, 7.0 to 9.0 for 70. So you're all good with both
    16TRD[QUOTED] likes this.
  25. Jan 15, 2021 at 5:34 PM
    #415
    belanger9
    Edmonton, AB
    A bunch
    Good news for us Canucks :canada:- the AT3's are now available on Integra Tire's website. Just put in a request for reserving them so we'll see when I can actually get them.
    Wrongside, Patch999 and Green Thunder like this.
  26. Jan 15, 2021 at 6:17 PM
    #416
    Patch999
    Kyle
    2017 Bad@$$ TRD Pro
    Just got mine last week. Great tires.
  27. Jan 16, 2021 at 4:44 PM
    #417
    drhntr
    drhntr New Member
    Derrick
    New Hampshire
    2017 Cement Pro DC
    GoRhino 2.0 MX4 295/70/18 TOYO AT3 TRD CAI Window Tint
    what sz did you end up with? currently looking or a new set for my pro
  28. Jan 16, 2021 at 7:33 PM
    #418
    Patch999
    Kyle
    2017 Bad@$$ TRD Pro
    295/70/18.
    drhntr[QUOTED] likes this.
  29. Jan 31, 2021 at 7:10 PM
    #419
    TheBeast
    TheBeast The Beach
    D vs F load in 35"s..what say you ? :)
  30. Feb 1, 2021 at 6:59 AM
    #420
    BayRunner
    Got to play in the snow this weekend. The Toyo AT3 handled it beautifully.
    Skey44 and Casper3 like this.
