Dirty water drips out of Toyota bedliner after wash
Discussion in '2.5 Gen Tundras (2014-2021)' started by Merkopac661, Nov 18, 2020.
  1. Nov 18, 2020 at 11:52 AM
    Merkopac661
    Merkopac661 [OP] New Member
    White 2018 Tundra Sport 4x4
    Anyone else have this problem? Im gonna ditch it and get a spray in. Is stock bedliner easy to remove?
    Sunnier and Rica25 like this.
  2. Nov 18, 2020 at 4:27 PM
    Corrosivetendency
    Corrosivetendency New Member
    Nate
    2016 plain-jane d-cab
    Very easy. Drop in berliners are the worst. Pop the sides from under the bed rail, pop the front edge up over and pull up and back. They are notorious for holding debris and rotting holes in the bed.
    They are useful as a bed slider. Cut the sides off and use it as a sled to drag materials out of the bed easier.
  3. Nov 18, 2020 at 5:05 PM
    Bucks04
    Bucks04 New Member
    2013 TRD Tundra
    Working on it
    Agree , worst thing ever put on trucks. Whenever you buy used , you should always lift the bed liner, 95% of time you'll find rust. Had old s-10 with one and whole front of bed seperated and fell. Got my Tundra sprayed with bullet liner and still use the bed rug, easier on the knees.
    NewImprovedRon and pro2amendment like this.
  4. Nov 18, 2020 at 5:47 PM
    Merkopac661
    Thanks for the reply. I'm gonna go mess with it in a minute. Hopefully its not bad. 14,000 miles used 2018 but is been kept up.
  5. Nov 18, 2020 at 6:58 PM
    GeoJoe
    GeoJoe 2018 Tundra SR 4x4 5.7L Looooooooong Bed
    3/1 lift on 20" OZs with KOs, LED fogs, steps and a handle
    HA - my buddy with an F150 took his truck into the dealer thinking it had some kind of oil leak. Turns out it was the black ink stained rain water from some black mulch he was hauling around leaking through the drop in bed. He's an idiot.
    (for buying a Ford, that is)
  6. Nov 18, 2020 at 8:10 PM
    Merkopac661
  7. Nov 18, 2020 at 8:14 PM
    Merkopac661
    I'm glad I did that.
  8. Nov 18, 2020 at 8:16 PM
    Dceclipse
    Dceclipse New Member
    NORCAL
    I removed mines last week, rust start building up and I'm glad i removed it
    TheBeast, BravoDeltaRomeo and Rica25 like this.
  9. Nov 18, 2020 at 8:31 PM
    Merkopac661
    Crazy how many leaves and sticks were under there.
    pro2amendment and Rica25 like this.
  10. Nov 18, 2020 at 8:33 PM
    Dceclipse
    NORCAL
    found a bottle cap probably dated way back 2014 .....:rofl:
  11. Nov 18, 2020 at 8:57 PM
    Blue Thunder
    Washington
    Bed looks good. The shop will scuff up the bed before they apply the spray-in liner so it will all get cleaned up.
    BravoDeltaRomeo and Tundyfundy like this.
  12. Nov 18, 2020 at 11:10 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Spray in is the way to go. Had mine done a few weeks ago but it wont help your initial issue which was water leaking out after a wash. I have two large wood block pieces, 6x10 that I drive up on with my front tires when I wash my truck so the water runs out immediately and then you can dry the truck and not have to worry about ruining the finish with water after you do the detail work. I hated that i would dress the trim and dry the truck to eliminate water spots and then you drive and water splashes all over the bumper and below tailgate.
    TheBeast likes this.
  13. Nov 19, 2020 at 5:13 AM
    Bammer
    Monroe, CT
    I used Herculiner on my bed, then put the drop in liner in. I need a drop in for impact resistance.
    Boerseun likes this.
  14. Nov 19, 2020 at 5:19 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    Agreed. I had a drop in liner in my Tacoma - I had it for 16 years and no issues with rust or debris, and I liked it for the impact resistance - I never misused it, but I knew that I could technically drop cinder blocks in there and it would not bend the bed. But having the herculiner under the drop-in is a good idea.
    Bammer[QUOTED] likes this.
  15. Nov 19, 2020 at 4:33 PM
    Corrosivetendency
    Nate
    I am curious as to why there aren't any drain holes in the front of the bed though. Considering adding a couple myself.
    Tundyfundy likes this.
  16. Nov 19, 2020 at 5:42 PM
    TheBeast
    TheBeast The Beach
    line-x + toyota bed mat works pretty good.
  17. Nov 19, 2020 at 5:49 PM
    Tundyfundy
    Bay Area, CA
    That’s the route I went and for once the tundra bed mat from Toyota is the cheaper option!
    TheBeast[QUOTED] likes this.
  18. Nov 19, 2020 at 6:19 PM
    Merkopac661
    Thanks for the input. I cant wait to get some more mods done. The list is growing lol. I need more cash. A lot more. Hehehe
  19. Nov 20, 2020 at 3:18 AM
    Bammer
    Monroe, CT
    Don't we all, this site just keeps me opening up my wallet ! :spending: I LOVE IT !
