2004 Tundra Rear Shift Actuator Inspection Now Won't Go Into Any Gears
Discussion in '1st Gen Tundras (2000-2006)' started by junk4cash, Jan 14, 2020.
  1. Jan 14, 2020 at 12:20 PM
    junk4cash
    junk4cash [OP] New Member
    Removed my rear shift actuator to inspect the other day and after re installing it, the truck now wont go into any gears. The engine revs but nothing will grab. I took it apart again and made sure the gear was "clocked correctly" but still nothing. Does anyone know if I need to have something re set with the trucks computer? It drove fine before I did this. I took it apart because I was wanting to make sure it wasn't full of water since the vent tube had rotted away a bit. There was no water or signs of water inside. Now I'm wishing i never would have messed with it. Any help is much appreciated. I've unhooked the battery to allow it to reset.
  2. Jan 14, 2020 at 1:24 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    When you go into 4Hi, do you get a light indication on dash and on 2WD/4HI button indicator, if that’s what kind you have ?
    Have you rechecked that all 3 cables click in place good ?
    Blown fuse ?
  3. Jan 14, 2020 at 1:29 PM
    junk4cash
    This is the light that is on. The center round light blinks
  4. Jan 14, 2020 at 10:04 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    thats a sequoia cluster isnt it? i dont think tundras ever had the AWD case
  5. Jan 15, 2020 at 11:30 AM
    PCJ
    PCJ New Member
    State of Jefferson
    2004 DC Limited 4X4
    Lift, Rims, Bigger Tires, Nerf Bars, Black Out Emblems
    If it is indeed a Sequoia, are you sure the transfer case is not in neutral?
  6. Jan 15, 2020 at 11:31 AM
    junk4cash
    Fixed today. Transfer case shaft was all the way in. Pulled it all the way out and it’s moving now
  7. Nov 12, 2020 at 7:43 PM
    Non.mechanic
    Non.mechanic New Member
    2006 tundra limited
    Empty_Lord, I’ve seen your post a couple of times and believe you may be the only one that can help me.... I just joined last night and have a post on actuator post.... kinda long description but I’m NOT a mechanic but looked as if I could fix myself as YouTube.... BUT TO MY SURPRISE MY ACTUATOR was nothing like the one on 2007 ... I have 2006 4.7 limited.... anyway my actuator only has three bolts to separate bottom half ... w/ worm gear and a separate encased motor with small worm gear that you can see after the three bolts off... took motor apart everything was not corroded but now all in pieces... brushes magnets etc.... just got together and have not put on truck yet..... my question is in my previous post I wrote last night....didn’t know there was a front ADD actuator too?? I believe now it may be it or knock on wood the fork that shifts... with the two hookups ..... is front same as back and how do you get to it???
    thx
    torino69 likes this.
  8. Nov 12, 2020 at 8:04 PM
    empty_lord
    05 rollover special
    The front actuator is on the differential tube. It’s a different actuator. I’ll see if I can grab a pic tomorrow, out at the farm right now doing some work.
  9. Nov 13, 2020 at 5:17 AM
  10. Nov 13, 2020 at 7:52 AM
    torino69
    torino69 The old guy
    West Fargo, North Dakota
    2004 Toyota Tundra Limited
    None worth mentioning
    I certainly don't. But then I'm old what your excuse
    Larry
  11. Nov 13, 2020 at 8:11 AM
    Professional Hand Model
    Fred
    Hand Protectors
    Slipping on decoder ring...
    bmf4069, KNABORES and torino69 like this.
  12. Nov 14, 2020 at 12:02 AM
    empty_lord
    05 rollover special
    This is the location. Wasn’t around the truck much today, but got the picture
  13. Nov 17, 2020 at 7:45 AM
    Non.mechanic
    2006 tundra limited
    Thank you !!! I’ll take a look and see how to disassemble... if I’m able to do so!! Thx again!!!
