Pro stance
Discussion in 'General Tundra Discussion' started by Balrz, Nov 16, 2020.
  1. Nov 16, 2020 at 7:21 PM
    Balrz
    Balrz [OP] New Member
    Ryu
    New 2020 Tundra crewmax off-road premium
    Hey guys,
    I’ve had my Truck for the better part of a year now and I would like to get it lifted to the height of a Trd pro. Can you guys give me some options?
  2. Nov 16, 2020 at 7:25 PM
  3. Nov 16, 2020 at 9:18 PM
    Bullet Proof 12" kit
    Medic343 and Hbjeff like this.
  4. Nov 16, 2020 at 9:20 PM
    GIN•OKUMA
    GIN•OKUMA Can’t get to SSEM from there. RGBA1
    Fish
    26.57°
    Noun; a machine, usually with wheels and an engine, used for transporting people or goods, especially on land
    So Pro bro
  5. Nov 16, 2020 at 9:21 PM
    Sup
  6. Nov 16, 2020 at 9:22 PM
    Buy a PRO or Pro Fox shocks
    GIN•OKUMA likes this.
  7. Nov 16, 2020 at 9:25 PM
    GIN•OKUMA
    Fish
    26.57°
  8. Nov 16, 2020 at 9:27 PM
    :fistbump:
    GIN•OKUMA[QUOTED] likes this.
  9. Nov 16, 2020 at 9:27 PM
    GIN•OKUMA
    Fish
    26.57°
    Bilstein 6112 set at 1.9, 5160 with coach builder shackle to level it out.
  10. Nov 16, 2020 at 10:08 PM
    Balrz
    Ryu
    What does the shackles help with? Can I not just use the shocks alone?
  11. Nov 17, 2020 at 4:31 AM
    GIN•OKUMA
    Fish
    26.57°
    Lift to level. The shocks won’t lift it alone.
  12. Nov 17, 2020 at 8:04 AM
    Balrz
    Ryu
    Ok cool.. I just didn’t want to go more that the standard pro height
  13. Nov 17, 2020 at 9:48 AM
    GIN•OKUMA
    Fish
    26.57°
    The pro is typically 2” higher in the front from other trim models and it’s level. Meaning the front and rear are the same height. Most other trim models have a rake to the rear up to 2”. Meaning the rear is higher than the front by about 2”. Lift the front 2” (ie bilsteins 6119 set at 1.9”) see if your trucks level. If it’s not level then add a shackle as needed for desired results. All results may vary.
  14. Nov 17, 2020 at 1:12 PM
    Balrz
    Ryu
    Thanks buddy that makes things much clearer..
