Get that Pro stance
Discussion in '2.5 Gen Tundras (2014-2021)' started by MDmid14, Nov 4, 2020.
  1. Nov 4, 2020 at 9:29 AM
    MDmid14
    MDmid14 [OP] New Member
    2023 Capstone
    I currently have the limited nightshade and want to get the stance of the stock TRD Pro. I know that it’s a 2” lift in the front but my question is how you all achieved that. I don’t do much off-roading, except for the OBX beaches, so something cost effective is just fine.
    Thanks!
  2. Nov 4, 2020 at 9:54 AM
    cctxquicksand
    cctxquicksand IG - TRDistheWrd
    If you don’t take your truck off-road spacers should be fine, others will say buy once cry once and replace your suspension but since your truck is so new I doubt that is an option.
    I rode on spacers for over a year and had no issues. I didn’t off-road though.
  3. Nov 4, 2020 at 9:58 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    6112s set at 1.9 would be perfect. No need to touch the rear suspension and no need for UCA.
  4. Nov 4, 2020 at 9:59 AM
    MDmid14
    2023 Capstone
    I get spacers, but this is a foreign language to me. Sorry!
    Rica25 likes this.
  5. Nov 4, 2020 at 10:04 AM
    PlatinumPro
    PlatinumPro New Member
    2015 PlatinumPro Crewmax
    Bilstein 6112+5100s, Rigid Lighting, Fuel 20x9 Bronze Blitz
    to make the best choice for you it pays to learn it. if you go under the sub forums and look under 3rd gen suspension you will learn enough to make that decision.
    Huckwheat, BravoDeltaRomeo and Rica25 like this.
  6. Nov 4, 2020 at 10:07 AM
    Kanobi13
    Kanobi13 New Member
    Not true each truck is different i hit my uca at full droop ar 1.9 i will be looking into uca. I would also suggest lifting the rear if you ever have anything in bed will have u nose high
    Rica25 likes this.
  7. Nov 4, 2020 at 10:13 AM
    frichco228
    Frank
    Virginia
    Sorry to hear you needed adjustable UCA for 1.9 lift. I have run lifted suspensions on many trucks, 4runners, and have never heard of that happening with just 2 inches of lift. But I suppose its possible.
    As far as the rear, if he wants the stance of the Pro, it is 2 inches higher in front than the other Tundras, no lift in the rear. The Pros sit level. But you are correct, if towing any real weight a Pro will squat some in the rear, looking nose high by an inch or two.
    Rica25 likes this.
  8. Nov 4, 2020 at 10:19 AM
    TrucksRCool
    TrucksRCool New Member
    Jordan
    UT
    2021 CM Limited Nightshade
    Hey. I am not speaking as any type of suspension technical expert. Just from my personal experience:
    1. I had a 2016 TRD Off Road that I wanted to go faux Pro without doing the TRD Pro suspension. I did that with Bilstein 5100s all around. My front 5100s were set at the middle (I think that’s around 1.75” lift) setting. No lift on the back. It got me pretty close to the leveled look of the Pro with a slight rake. No other work was done on it except for an alignment. I did not change the tires either. Worked great and for my limited towing (less than 5k pounds) also worked great. Cost was appx. $950 including struts, shocks, install and suspension. It was done by an affiliate of a local Toyota dealer.
    2. I just bought a 2021 Limited Nightshade a month ago. I went back to the 5100 setup. But this time I had the front struts set at the top (I think that’s 2.5” lift) setting and I added spacers front and back so I netted a total lift of 3 in the front and 1.5 in the back. I did this so I could clear 34” BFG tires. It did that. It also only required an alignment with no other changes to the suspension. Total cost for me here was slightly over $1000 including all parts and install and alignment. Same shop did the work.
    The reason I went this route instead of leveling kit is I had read that leveling kits reduce the overall suspension travel of the stock shocks. Again, I’m not technically learned in suspension works so I chose to go with the replacement strut setup that kept full travel and gave me the leveling effect. Plus Bilstein is a pretty well known brand with quality products and this was a great value for the dollar in my mind.
    Hope this helps. And I will upload pics of my two trucks later.
    AlaskanAssassin and panicman like this.
  9. Nov 4, 2020 at 10:47 AM
    Rngr188
    Rngr188 Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    My truck with Bilstein 6112 coilovers at the 1.9" setting and nothing in the rear.
    Edit: I did add Bilstein 5160 rear shocks but no rear lift.
  10. Nov 4, 2020 at 12:00 PM
    MDmid14
    2023 Capstone
    Looking forward to the pics! This sounds right up my alley.
  11. Nov 4, 2020 at 12:00 PM
    MDmid14
    2023 Capstone
  12. Nov 4, 2020 at 12:09 PM
    AlaskanAssassin
    AlaskanAssassin I now walk into the wild
    Alaska
    2020 DC TRD-OR, Cement
    #picsplease
  13. Nov 4, 2020 at 12:17 PM
    Rngr188
    Chad
    Harrison AR
    I'd say ride is better but that's subjective and let's be honest it's a truck not a Lexus it's a truck.
    MDmid14[QUOTED][OP] likes this.
  14. Nov 4, 2020 at 6:26 PM
    TrucksRCool
    Jordan
    UT
    The white was my 16 TRDOR and the MGM is my 21 Nightshade. Sorry for the delay. Long day!
  15. Nov 4, 2020 at 6:50 PM
    Blueknights75
    Ron
    Clayton, NC
    Order some Billstein 5100 shocks. Set the front to the top setting and you will be perfectly level.
  16. Nov 16, 2020 at 1:37 PM
    Balrz
    Balrz New Member
    Ryu
    New 2020 Tundra crewmax off-road premium
    So all you need are front shocks to achieve that pro look?
  17. Nov 16, 2020 at 2:29 PM
    Blueknights75
    Ron
    Clayton, NC
    Yes sir.
  18. Nov 16, 2020 at 2:41 PM
    glowblue
    glowblue From time to time
    VA
    Bilstein 6112s @ 1.9” plus 2 shims drivers side/1 passenger and Toytec shackles at 1.5”, 1” of slight rake to avoid squatting when loaded.
    biebs96 and InsaneAuto86 like this.
  19. Nov 16, 2020 at 2:45 PM
    HummBaby!
    HummBaby! New Member
    Rob
    What size tires are you running Balrz?
  20. Nov 16, 2020 at 4:33 PM
    InsaneAuto86
    InsaneAuto86 New Member
    SE PA
    2020 Tundra SR5 TRD
    Another vote for 6119 @ 1.9 and 1" shackle in rear
    glowblue likes this.
  21. Nov 16, 2020 at 5:00 PM
    biebs96
    PA
    5100 on the middle setting and 1” lift in rear.
    Before the rear lift, truck was within 1/4” all around, but I wanted to add some rake back.
  22. Nov 16, 2020 at 5:30 PM
    Tundra-in-Cement
    Tundra-in-Cement Truck Chump
    2021 Tundra CM-OR
    Scanguage-II, Decked Systems, Leitner Rack, CaliLED lights, Firestone Air Bags, Trans-cooler kit, 2017 Pro grille and bulge, S-Tech 6 way switch, Corse Evo Darks w/ Stock Tires, 17-inch Alpha Equip Delta w/ Wildpeaks, Falcon Suspension, Coachbuilder +1 Shackle, Valhalla Cat Protectors.
    Not trying to Hi-Jack, but who has the best price on 5100/6112's? ....on that, any BF discounts already known?
  23. Nov 16, 2020 at 5:35 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Or add airbags.
  24. Nov 16, 2020 at 7:02 PM
    Balrz
    Balrz New Member
    Ryu
    I have the stock 18” at the moment.. would like to upgrade to the same 18” but with a +25 offset. This looks like it sits just on the edge of the fenders or just out side.
  25. Nov 16, 2020 at 7:06 PM
    Balrz
    Balrz New Member
    Ryu
    What did you use at the back? Also what are UCA’s?
  26. Nov 16, 2020 at 7:10 PM
    biebs96
    PA
    stock UCA and a 1” block in the rear
  27. Nov 16, 2020 at 7:14 PM
    Balrz
    Balrz New Member
    Ryu
    Excuse my ignorance but what is the definition of UCA?‍♂️
  28. Nov 16, 2020 at 7:15 PM
    Balrz
    Balrz New Member
    Ryu
    Did you see a difference in the ride?
  29. Nov 16, 2020 at 7:16 PM
    Balrz
    Balrz New Member
    Ryu
    Ride looks sweet..
    biebs96[QUOTED] likes this.
  30. Nov 17, 2020 at 6:48 AM
    Kanobi13
    Kanobi13 New Member
    Upper control arms
