295/70R18 with 3/1 Level kit
Discussion in '2.5 Gen Tundras (2014-2021)' started by rznhales, Oct 29, 2019.
  1. Oct 29, 2019 at 4:59 PM
    rznhales
    rznhales [OP] New Member
    Randy
    Southern Utah
    2014 Tundra Crewmax Limited TRD
    Bilstein 5100's
    Just had my 295/70’s installed today on my CrewMax. No rubbing front or rear and no spacers needed. They’re Toyo Open Country R/T’s and cannot believe how quiet they are compared to the BFG MT’s they replaced. First time I’ve heard my dual exhaust while driving in quite some time.
    ajaxv2000, KnoxHog22, dpast88 and 2 others like this.
  2. Oct 29, 2019 at 5:00 PM
    rznhales
    Randy
    Southern Utah
    Bilstein 5100's
  3. Oct 29, 2019 at 5:08 PM
    bossgobbler32
    bossgobbler32 New Member
    That looks very nice! Very clean look. I like it!
    rznhales[OP] likes this.
  4. Oct 29, 2019 at 5:09 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Perfect size!
  5. Oct 29, 2019 at 5:22 PM
    Blueknights75
    Ron
    Clayton, NC
    Beautiful truck!
    Pinay and rznhales[OP] like this.
  6. Oct 29, 2019 at 5:33 PM
    rznhales
    Randy
    Southern Utah
    Bilstein 5100's
    Thank you!
  7. Nov 8, 2020 at 12:53 PM
    Derf77
    Derf77 New Member
    Fred
    South Chesterfield VA
    2020 Crewmax SB SR5 TRD Off Road
    TRD rear sway bar, Ready lift 3/1, 4 window auto up/ down.
    Love it! They should have all came this way!
  8. Nov 8, 2020 at 3:14 PM
    Mxvet90
    Mxvet90 New Member
    Looks great
  9. Nov 9, 2020 at 5:48 AM
    TundraPJ
    TundraPJ New Member
    JP
    DFW, Texas
    '19 SR5 TRD Off-Road
    Fox TRD Pro Shocks BFG KO2’s Dirty Deeds 14” BAMF n-fab nerf bars
    Tires look great! Glad to hear no rubbing - when I get my next set of tires I’ll probably go up to that size.
  10. Nov 9, 2020 at 9:31 AM
    hkspwrsche
    hkspwrsche Old guy with lots of car toys
    Harold
    Richmond, VA
    2014 Tundra limited TRD CrewMax
    Working on it
    Nice! Which level kit?
  11. Nov 9, 2020 at 2:11 PM
    Derf77
    Derf77 New Member
    Fred
    Just installed falken wildpeak 295/70r18s with 1.25 spidertrex spacers. Have readylift 3/1.5 lift. Rubs at full lock in reverse will need to do trimming and possible CMC.
    tundra121 likes this.
  12. Nov 9, 2020 at 3:25 PM
    DIYDad
    DIYDad New Member
    2020 Tundra 1794
    Does it rub without the spacers? I read of at least one truck that only rubbed with the spacers.
  13. Nov 9, 2020 at 3:44 PM
    Tundraman479
    Tundraman479 New Member
    2024 Tundra Crewmax TRD Sport Lunar Rock
    TRD Pro Suspension 275/60r20 Wildpeaks
    I have read this also. I am running 295/70 Cooper Discoverer on my truck with stock TRD offroad wheels with no wheel spacers and it doesn't rub.
  14. Nov 9, 2020 at 5:57 PM
    tundra121
    tundra121 New Member
    I installed the same tire's a few weeks ago with 3/4" spacers and had minor rubbing in reverse. Solved that tonight with adding a small screw in the back of the flap into the plastic inner fender.
    Derf77[QUOTED] likes this.
  15. Nov 9, 2020 at 6:03 PM
    Derf77
    Derf77 New Member
    Fred
    Nice Truck! Send thanks Im gonna try that!
    tundra121[QUOTED] likes this.
  16. Nov 9, 2020 at 6:07 PM
    ajaxv2000
    ajaxv2000 New Member
    Nice setup!
    Are those stock 18" wheels?
    Did you use a 3/1 leveling kit?
    Thanks.
  17. Nov 30, 2020 at 11:21 AM
    The great white
    The great white New Member
    2020 White Tundra Sport
    2020 blacked out Tundra sport crew max , blacked out
    What lift kit if you dont mind?
  18. Jan 9, 2021 at 12:01 PM
    CCLJ03
    CCLJ03 Tundra forever
    Craig
    2018 TRD Off-Road - Cement
    @rznhales normally wouldn’t bug you, but these guys ^ asked some good questions and your truck looks too good for us to not have answers man.
    NumberOfTheDay likes this.
  19. Jan 9, 2021 at 12:03 PM
    CCLJ03
    Craig
    @tundra121 did you end up have to grind down the studs to get them not to poke out with those 3/4” spacers on?
    youngDUMP and NumberOfTheDay like this.
  20. Jan 10, 2021 at 5:37 PM
    tundra121
    There are pockets in the back of the factory wheels between the existing studs so machined a 5x150 bolt pattern recessing approx 2 mm into the pockets to line up with the studs. Worked perfectly Wheel specialist ensured it wasn't compromising the integrity of the factory wheels.
    CCLJ03[QUOTED] likes this.
