Rust Prevention
Discussion in 'Detailing' started by xk49, Nov 2, 2020.
  1. Nov 2, 2020 at 5:45 AM
    xk49
    xk49 [OP] New Member
    Jerome
    2012 Tundra
    Leveling Kit
    I just bought a 2012 Tundra. Living in the NorthEast the undercarriage is pretty rusty already. Is there a business(kind of like a Ziebart) that does a full under coating. IE. frame, rear axle, leafs, etc. basically everything underneath?
    What has your experience been after applied? Does it flake off. What did it cost you?
    YardBird likes this.
  2. Nov 2, 2020 at 5:55 AM
    Northern Toyota
    Northern Toyota New Member
    2023 Tundra TRD Off Road, 2022 Tacoma TRD off road premium
    Tires and bilstein
    I use rust check. Have used krown in the past. A lot of people use fluid film, basically you want something that doesn't dry out and harden. The ones I mentioned will creep into all the seems and areas where rust will start. Google search and if you're in the north east I'm sure you'll find a place near you that applies one of these products
  3. Nov 2, 2020 at 6:24 AM
    Rotaryphoneuser
    Rotaryphoneuser New Member
    Ontario. Canada
    2018 Cement CrewMax
    Anything oil spray is good. Ziebart......not good.
    Luckydog likes this.
  4. Nov 2, 2020 at 8:29 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    WFD473, TTund16 and TILLY like this.
  5. Nov 2, 2020 at 9:21 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
  6. Nov 3, 2020 at 12:06 PM
    Northern Toyota
    Tires and bilstein
    Just an FYI for people watching this video in regards to rust check. He used the inner panel aka red can kind of rust check. It isn’t meant to stand up to the blasting of a pressure washer. The coatAnd protect aka green can version of rust check is meant for exposed metal parts. This version better withstand the harsh elements but isn’t as thin and runny as the red can version. This 2 version application of rust check is what makes it good imo.
  7. Nov 4, 2020 at 2:06 PM
    xk49
    Jerome
    2012 Tundra
    Leveling Kit
    Protecting future and fixing current rust issues sounds like it's going to be a royal pain in the arse.
  8. Nov 4, 2020 at 2:11 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  9. Nov 5, 2020 at 4:29 PM
    Northern Toyota
    Tires and bilstein
    It’s an uphill battle
  10. Nov 6, 2020 at 6:16 AM
    Megaman
    Megaman New Member
    2020 Tundra Limited DC 4X4 TRD Silver Sky Metallic
    I've heard frame rust was a huge problem years ago on the Toyota trucks, but is it still a huge problem now? Do the Toyotas rust out quicker than other brands of trucks?
    -Only reason I ask is because I have a '04 Pontiac Vibe.....the best Pontiac Toyota ever built.....and after 16 years of WI winters and brine, and the car is 90% outdoors all the time - the underside of the car has done awesome overall. Only the heat shields are beginning to rust at the mounting points like they always do, but the floors, frame etc. is in great shape and no rust.
  11. Nov 6, 2020 at 6:38 AM
    Dabutcher
    Dabutcher New Member
    D
    Twin Cities
    2022 Tundra 1794 Supersonic Red
    Nitto Ridgegrapplers 175/60/20
    0F3549FE-7A18-4C80-AA21-14C29A3222E1.jpg BF7BA9AD-BCFD-4E20-9144-6BB833919A20.jpg 0F3549FE-7A18-4C80-AA21-14C29A3222E1.jpg BF7BA9AD-BCFD-4E20-9144-6BB833919A20.jpg 4D77D1EB-882E-4450-9F04-F08353A38C28.jpg 6FACAD9D-AD52-4271-8B3A-47366515783E.jpg 0788F07F-F44F-4207-A000-092B61CBB624.jpg I bought my 2008 in 2018 from Nashville. No rust underneath . Like new looking. I live in the Twin Cities where they blanket the street with salt. Gotta keep the traffic flowing ya know. Started using Fluid film after being on this forum. Every fall. I use the gallon and a paint brush on big stuff and spray cans x two on the little or hard to reach areas. On third year with same gallon. So far, still looks awesome underneath! Just don’t spray outdoors when it’s windy. Don’t ask me how I know. Like painting, wear clothes you do not care about ruining. My truck is leveled so I can crawl under with my 228 lb fat ass easily!
    Good luck. D
    jrquist likes this.
