Make up my mind
Discussion in 'Wheels & Tires' started by Jonross227, Nov 5, 2020.
  1. Nov 5, 2020 at 7:53 AM
    Jonross227
    Jonross227 [OP] New Member
    I'm getting ready to make a change on my wheel/tire setup and I cannot for the life of me make up my mind. Currently have 20" fuels with +1 offset on 305/55r20 leveled at 1.9 with 6112's.
    Im wanting to run a 295 width tire. First thought is 295/60r20 but with my offset I'm not sure they'll fit without having to chop the cap mount. If I'd just need to move the fender liners or shim the front bumper I'd go that route as it's the easiest.
    My next thought is drop to 17's with a 0 offset and run 295/70r17's. Same height as my 305's so no rubbing to worry about and will fit flush with my flares.
    My last thought, thanks to the 295 thread, is to get a 25-30 offset 18" wheel, and run 295/70r18's.
    So help me out, which way would you go?
  2. Nov 5, 2020 at 8:42 AM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Do you use your truck off-road? If so, switch over to the 17"
  3. Nov 5, 2020 at 9:29 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Personally I would go with 18s. 17s can have caliper clearance issues. 18s are great off road and on and there is a good number of tires available in many sizes and loads. 20s- dislike them. I dont like how they ride and think more tire vs rim looks better too.
    Tundra234 and GODZILLA like this.
  4. Nov 5, 2020 at 9:32 AM
    18" TRD Off Road Wheels
    X2
  5. Nov 5, 2020 at 10:20 AM
    jalam321
    jalam321 New Member
    2018 Tundra CM Platinum 4x4 and Sequoia Platinum 4x4
    Just curious, what's wrong with the wheel/tire setup you have now? Why do you want to change to 295 width tire?
  6. Nov 5, 2020 at 10:31 AM
    mountainpete
  7. Nov 5, 2020 at 2:06 PM
    Jonross227
    There's nothing wrong with the setup I have now. It's just time for tires and and the 305s look too wide for my liking at 33". Almost like skateboard wheels.
    35's look good but that's not an option at my lift height
  8. Nov 5, 2020 at 2:09 PM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax, 07 reg cab
    just cut the cab mount
  9. Nov 5, 2020 at 2:57 PM
    jalam321
    jalam321 New Member
    Ok. I understand. I have 20x9 +18 with LT305/55/R20 on my Tundra now. I like the way it looks but I have considered maybe going with 18x9 with 295/70/18 in the future. I also have 20x9 +50 with LT295/55/R20 on my Sequoia, it fits and looks great.
  10. Nov 5, 2020 at 3:28 PM
    Jonross227
    The +18 makes a difference. My stance is pretty wide with the +1. I'm running flares so it helps alot but a little more height to fill out the wheel well looks better imo.
    Im starting to lean more towards going 18's with 295's the more I look at pictures posted here
