5.7L Transmission Cooler Kits
Discussion in 'Genuine Cooling Systems' started by Genuine Cooling Systems, Jan 19, 2020.
  1. Oct 31, 2020 at 7:58 PM
    #91
    Genuine Cooling Systems [OP] New Member Vendor
    Not sure of the price just yet, but it will just be an upgrade. I will still have the Hayden 778HD as the standard.
  2. Nov 1, 2020 at 3:45 AM
    #92
    PWMDMD
    PWMDMD New Member
    Worcester, MA
    2020 Tundra Platinum
    Ok in 2-weeks of driving temps went over 175F once and hit 197F after driving for an hour and a half in mixed town/highway driving. My point...an external cooler certainly makes sense for some, slow trail driving and frequent heavy towing, but it's not absolutely necessary if you have a glam-truck like mine.
  3. Nov 2, 2020 at 9:08 AM
    #93
    BamaJoe
    BamaJoe New Member
    Joe
    2020 white Tundra Double Cab SR5 4wd
    Received my Transmission Kit today from UPS. Packaged nicely. Thanks Nick. I will see if I can install this week and post my results. Nick does an professional job with the packing and the cooler mounting bracket is very well done.
    Joe
  4. Nov 2, 2020 at 10:13 AM
    #94
    pgrn1
    pgrn1 New Member
    Southern New Jersey
    2020 limited trd
    Thanks Nick
    Received my kit today. If I hadn’t ordered this myself and instead received it as a gift, I would have thought it was an OEM kit. Great job.ED4C0473-16DF-41D1-91E0-90393FEAD65B.jpg
    BR73, bulldog93, KC.Tundra and 4 others like this.
  5. Nov 2, 2020 at 12:32 PM
    #95
    palehorse
    palehorse @grey_ghost_trdpro
    Mount Pleasant, SC
    2020 TRD PRO
  6. Nov 3, 2020 at 8:13 PM
    #96
    All kits will ship 10-Nov. The shop I have fabbing the brackets took a couple days longer to make than what they were entisipating and they are estimated to arrive 9-Nov.
    Sorry for the delay.
    Wallygator likes this.
  7. Nov 4, 2020 at 3:41 AM
    #97
    Bammer
    Monroe, CT
    Got mine yesterday, and although my situation has changed and wasn't going to install, after seeing the kit, it's going in.. Kudos to Nick..:thumbsup:
  8. Nov 4, 2020 at 4:02 AM
    #98
    ssls6
    ssls6 Dr. Awesome
    Richard
    South Park, CO
    2020 TRD Pro CM
    Bakflip, Bedstep, Gulfstate stuff
    Thanks for the heads up
  9. Nov 6, 2020 at 12:29 PM
    #99
    FRZNTundraSouth
    FRZNTundraSouth New Member
    Are there any experiences towing without a transmission cooler with out issues? I plan on towing my 17 boat and have my ATV in the bed.
  10. Nov 6, 2020 at 12:36 PM
    #100
  11. Nov 6, 2020 at 1:01 PM
    #101
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    tl;dr
    If your Tundroid is 2019 or newer and you attach ANYTHING to your hitch then you are screwed. The popular opinion is add a vapor-to-liquid heat exchanger. Liquid-to-liquid systems are to be avoided at all costs.
  12. Nov 6, 2020 at 1:41 PM
    #102
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Your the only one that should decide that. Monitor your transmission temps with the fussion app and decide.
    Blue Thunder and hagrid like this.
  13. Nov 6, 2020 at 1:41 PM
    #103
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    :goingcrazy:
    hagrid[QUOTED] likes this.
  14. Nov 6, 2020 at 1:43 PM
    #104
    It's not too long. You just don't like stuff that isn't written in Olde English. :p
  15. Nov 6, 2020 at 2:13 PM
    #105
    Clemsonman14
    Clemsonman14 New Member
    2020 SR5 Crewmax 4x2
    @Jtundra81 i believe has towed a good bit without the cooler and had pretty decent results
  16. Nov 6, 2020 at 3:54 PM
    #106
    Melikeymy beer
    Melikeymy beer No cooler for you!
    Muscogee Nation
    2019 Platypus Tundra
    Or don't monitor and just send it, like me, lol.
  17. Nov 6, 2020 at 3:58 PM
    #107
    Melikeymy beer
    Muscogee Nation
    I tow a 6k pound trailer often without issues. But I'm guessing maybe you mean transmission temps under a certain threshold?
  18. Nov 6, 2020 at 5:30 PM
    #108
    Jtundra81
    Jtundra81 Just a member
    Joe
    2019 cement tundra crewmax
    Here is a collected data from me towing a 4000lb trailer in MA mostly flat with some rolling hills . I tow on s4 with tow haul on and I keep it at 60 mph . I average 215 on pan . The sample has an hour of towing each direction
  19. Nov 6, 2020 at 6:56 PM
    #109
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    That's the thing, you can put it in 4S and it does help control the temps on flat land but run up a mountain and when the trans shifts to 3 and the converter unlocks watch the temps reach 250f and higher. Also 4S sucks for fuel mileage. With the cooler put the truck in D and push the tow haul button and drive. Better fuel mileage and you dont even have to think about trans temps.
    BR73, Bammer, rebmo and 1 other person like this.
  20. Nov 6, 2020 at 7:13 PM
    #110
    Jtundra81
    Joe
    Right , if you tow heavy and year long , would put a cooler for sure . I tow like 8 times tops a year when we go camping , been to Vermont and new hamshire and honestly it kept temps around 218 on pan for me unless I stop on tolls and accelerate, torque c would go to upper 230 and comes back down once it locks .
    Thinking of adding the cooler myself maybe at a later stage as i plan to keep the truck
    Ruggybuggy[QUOTED] likes this.
  21. Nov 6, 2020 at 7:25 PM
    #111
    Melikeymy beer
    Muscogee Nation
    How much difference will you get between D and S4 pulling a 6k lb trailer? Maybe 9 mpg vs. 8 mpg?
  22. Nov 6, 2020 at 7:59 PM
    #112
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I've tested that on out last trip out west. Pulling a 5.5K RV about 1-2mpg. I was getting between 10 and 12mpg if I kept my speed around 65mph. 2mpg makes a big difference towing for 5,000 miles on an extended trip and not having to worry about what the temps are getting to is another big plus.
  23. Nov 6, 2020 at 8:25 PM
    #113
    Melikeymy beer
    Muscogee Nation
    You get much better mpg than I do in either D or S4 at 60-65. I'll quit now and let OP get back to selling cooler kits.
  24. Nov 6, 2020 at 8:28 PM
    #114
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I'm running stock size tires and stock suspension height. :thumbsup:
  25. Nov 6, 2020 at 8:39 PM
    #115
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    TFL just did a video on this in CO I believe. Check their Youtube site.
    Ruggybuggy likes this.
  26. Nov 6, 2020 at 9:52 PM
    #116
    2020Platinum
    2020Platinum www.youtube.com/NitroZ18Fishing
    Patrick
    Northeast PA
    2022 TRD Pro (Lunar Rock)
    A lot. See my channel for all installs/mods!
    Hey guys, spoke with OP and I’m going to be doing an install/review video of his kit on my channel if anyone wants to check it out...waiting to receive it from him and I’ll be doing video asap...I tow my boat a lot so looking forward to seeing what kind of difference this makes...if you’re interested in following along or checking out any of my other Tundra videos, my channel is www.youtube.com/NitroZ18Fishing
    BR73, Bammer, Saab95v6 and 11 others like this.
  27. Nov 7, 2020 at 6:36 PM
    #117
    TheBigTimpin
    TheBigTimpin New Member
    An external cooler is a must. I have a 2020 Tundra and the warning light came on towing our 5700 lb trailer. I bought the OBD 2 sensor and driving without the trailer hit 222 degrees in under 20 min. I did fight with Toyota over the non-existent cooler. Long story short they didnt do much. I did get one installed. Rated at 18000 lbs of towing. I cant break 200 degrees now even after hours of driving.
  28. Nov 8, 2020 at 8:27 AM
    #118
    I was wondering when you would be getting to this. :rofl: Can't wait to see the video!
    2020Platinum[QUOTED] likes this.
  29. Nov 8, 2020 at 10:21 AM
    #119
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    Since installing cooler I haven't seen a pan temp above 196F, Pulling 5Klb boat at 75mph or hauling ATV's. I beginning to think there is ZERO advantage to even a thermostat to get trans temp up, but I could be wrong. My 2001 Lexus transmission fluid is 110F after 45 minutes of interstate driving. I doubt it ever sees 160F. I had a solenoid go out at 168K miles and when I dropped the pan the fluid appeared NEW, original owner. I not monitoring trans temps anymore, no reason to. Again this is a GREAT kit!!
    TheBigTimpin, betotundra and rebmo like this.
  30. Nov 9, 2020 at 8:36 PM
    #120
    2020Platinum
    Patrick
    Northeast PA
    Hahaha...yea I was most likely adding a trans cooler anyway, so when I saw his post asking for someone to make a video, it was a win win...word on the streets is I’ve been known to do a couple “how to” videos here and there...lol!
