collision radar question
Discussion in '2.5 Gen Tundras (2014-2021)' started by preacher35, Nov 2, 2020.
  1. Nov 2, 2020 at 1:09 AM
    preacher35
    preacher35 [OP] RIGHTEOUS MEMBER
    2018 MGM Platinum Crewmax 4x4
    I am getting ready to install multiple LED pods on my 2018 CM but I need to figure if I am going to have an issue with the bumper LED's creating any obstruction to the collision radar sensor in the grill "T" emblem. I am looking at some pods that are 7.6" tall:
    After measuring, it looks like I will have about 3/4" of gap between the top of the pods, to the "T" emblem. Those of you whom have experience with this, do you think that I will be in the "clear"?
  2. Nov 2, 2020 at 2:34 PM
    preacher35
    C'mon, somebody must have some knowledge on this.
  3. Nov 2, 2020 at 2:44 PM
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    Bilstein 5100 2.3/1.5, TRD sway bars ft/rr, Cooper Tires Discoverer AT3 XLT 295.70.18, Vision Manx 2 18x9 +12, APS side armor steps, TRD-Pro Grill and Bulge, de-chromed, blackout emblems, OEM mirror caps and flares, TRD shift knob, Leather wrapped steering wheel, All weather mats
    I have seen some 18's with TSS/Radar installed with bull bars and lights mounted close to it. From some of what I read, the radar signal angle was narrow enough to go between the obstruction. It's going to be a trial and error in my opinion. Do not do anything permanent, if you have to duct tape and zip tie everything first do it.
    Check out expedition overland's build.
    https://www.xoverland.com/videos/truck-builds/2018-toyota-tundra/
    and Victory 4x4
    https://youtu.be/Fv9YAYpBMac
    ARB
    https://arbusa.com/toyota-tundra-2014-2018/bumpers-protection-equipment/
    If you place your lights where their bull bar is at, it will clear the view. anything above that , might have some issues.
    mountainpete likes this.
  4. Nov 2, 2020 at 2:48 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    There is no way to guarantee until you try it, but I expect you will be fine. It only needs a few inches around the emblem with the honeycomb grill. The TRD Pro is different though.
    The closest I have seen is the ARB bumper (which works fine with the lights shown).
    Black Wolf and SprinterAE86 like this.
  5. Nov 2, 2020 at 3:34 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    As long as there isn’t anything directly in front of the emblem you shouldn’t have any issues.
  6. Nov 2, 2020 at 3:52 PM
    November Sun
    November Sun New Member
    Huntsville, Alabama
    2018 Limited Crew Max
    Pro Comp 7" Stage 1 Lift, 20" Fuel Wheels, Nitto Terra Grapplers, Bak Flip Tonneau Cover, King 2.5's, Custom Alcan Leafs, Coachbuilder Steering Kit, CBI Baja Front Bumper, NSV Light Bar, TRD Pro Intake, Southeast States Wireless Phone Charger Coachbuilder Plus 3 Shackles, Wheeler's Bumpstops, BAM 8" Exhaust, BAM Bomb Tip, Headlight Revolution LEDs everywhere, Warn EVO 12K Winch, Diode Dynamics SAE Fogs and Combo Light Bar
    I just ordered a bumper and am having the same concerns.
    I have the Limited grill, we shall see in about a week. Not my truck in the pic.
  7. Nov 2, 2020 at 4:12 PM
    Danman34
    Danman34 New Member
    Danny
    That will intefere, most likely.
  8. Nov 2, 2020 at 4:15 PM
    November Sun
    Huntsville, Alabama
    I did some measuring, I'll find out, if so, Ill just swap grills and relocate the sensor. CBI, whose truck is in the pic said it did not interfere with the Pro's sensor location.
  9. Nov 6, 2020 at 6:55 AM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    Exterior: Toytec ultimate 3" lift level, Total Chaos Uniball UCA's, Total Chaos Cam Tab Gusset kit, AcanII smoked headlights, AcanII smoke Tail lights (2.5 gen style), DV8 front winch bumper , Badlands 12k winch with Apex Synthetic, White AUTMATCH Shackles 3/4" D Ring Shackle, Apex Winch shackle, Trail Ridge mirrors ,Icon Rebound Pro 17"x8.5" +25, Cooper Discovery STT Pro 285/70R17, PowerStop drilled n slotted rotors W/Carbon pads, Rigid flood flush mounts rear bumper , WeatherTec rain guards , OEM black side badges , Rigid Amber Radiance Pods. Energy Suspension Red Rack and Pinion Bushings, EAG front mesh Grille, RCI HighLift bed mounts. Rough Country DS2 Steps, A.R.E OverLand Canopy with Ascend basket, Stickers: ToyTec lifts windshield banner, Red Strange Music window sticker(back cab), White Strange Music sticker(back canopy), White Rigid sticker x2 (canopy sides), white Official BigFoot Research Team (Back Canopy) Interior: Alpine double din touch iLX-650 , JL C5-653's (front) JL C1-650x (rear) , JL JX400 4 channel amp , JL JX500 mono amp , 2 JL 12" subs , WeatherTec floor mats, Kenwood F/R Dash Cams, Black steering wheel emblem overlay, Tekonsha P3 Brake controller, ToyTec "Fresh" Scent coilover air freshener, Under the Hood: Koyo all aluminum radiator, Mishimoto red silicon hoses , XS Power 3000 amp battery , LAlectric 300 amp Alternator , K&N replacement filter. Online LED store accessories Fuse/relay box. (Identified) Dirty Deeds 8" Cat back exhaust with DD resonator delete/axel over converted into dump. Coming soon:
    @preacher35 Turn the sensors on roll down the front windows , walk to the front sensor and see were it goes off at you should be able to find the dead/safe zones enless these systems don't beep like the sonar on 2nd Gens.
    An take measurements.
  10. Nov 6, 2020 at 6:16 PM
    Danman34
    Danman34 New Member
    Danny
    This is referring to the Pre collision sensor in the front grill of 18+ trucks. You’re thinking of the proximity sensors in the bumpers.
  11. Nov 6, 2020 at 6:34 PM
    You will be fine.
  12. Nov 6, 2020 at 6:35 PM
    With the limited grill you might be okay. Not with a PRO grill.
  13. Nov 7, 2020 at 1:48 AM
    preacher35
    Thank you, sir!
