Starting suspension work...
Discussion in '1st Gen Tundras (2000-2006)' started by Voss, Oct 10, 2020.
  1. Oct 30, 2020 at 2:01 PM
    #61
    Voss
    Voss [OP] Not a new member
    2003 AC TRD 4x4
    Only Toyota parts my dude
  2. Oct 30, 2020 at 2:03 PM
    #62
    Voss
    2003 AC TRD 4x4
    One question, do I keep this metal plate thing under my leaf springs or everything comes out for new Deaver Springs?
  3. Oct 30, 2020 at 2:08 PM
    #63
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    deaver AAL? technically you remove it. but if your going to be hauling weight, youd want to keep it. i did the Icon 3 leaf add a leaf and kept it. that is the stock overload spring
    Voss[QUOTED][OP] likes this.
  4. Oct 30, 2020 at 2:12 PM
    #64
    Voss
    2003 AC TRD 4x4
    entire new leaf pack
  5. Oct 30, 2020 at 2:20 PM
    #65
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    New leaf pack comes with it
  6. Oct 30, 2020 at 2:27 PM
    #66
    empty_lord
    05 rollover special
    Yea then you don’t need it
  7. Oct 30, 2020 at 2:28 PM
    #67
    Voss
    2003 AC TRD 4x4
    As a part of the springs themselves? Cause...
  8. Oct 30, 2020 at 2:29 PM
    #68
    Voss
    2003 AC TRD 4x4
    Cool thanks
  9. Oct 30, 2020 at 2:29 PM
    #69
    empty_lord
    05 rollover special
    The Deaver packs do not have overload springs, this is because they’re designed to flex more. You do lose some capacity but likely not much being it’s a 10 leaf setup
  10. Oct 30, 2020 at 2:52 PM
    #70
    Voss
    2003 AC TRD 4x4
    I asked Deaver to make these medium duty vs their reg light duty so should be decent.
    empty_lord[QUOTED] likes this.
  11. Nov 1, 2020 at 6:13 PM
    #71
    Voss
    2003 AC TRD 4x4
    One of the most physically demanding things I’ve ever done. Wow But feels good man
  12. Nov 1, 2020 at 6:30 PM
    #72
    Voss
    2003 AC TRD 4x4
    Rear end is lower than the front now by half an inch. Gotta remove the total chaos shackles or figure something else out. I don’t get it, I was expecting to be much higher in the rear
  13. Nov 2, 2020 at 8:44 AM
    #73
    rock climber
    How much lift did Deaver say you were supposed to get? What's your measurement from the center of the hub to the fender?
  14. Nov 2, 2020 at 10:21 AM
    #74
    Voss
    2003 AC TRD 4x4
    1 1/2” lift but the total chaos shackles lower the lift by 3/4”. Only measured ground to fender which is 36”. It was 36 1/2” before.
    Good thing to come out of this is my front is more level now. Went from about 1” difference to 3/4”. Looking forward to seeing how the truck sits once I get the driver side leaf springs installed as well. Ive come to realize I need to stop panicking at ever turn till the entire suspension is in
    Darkness likes this.
  15. Nov 2, 2020 at 6:37 PM
    #75
    Voss
    2003 AC TRD 4x4
    Think the shackles are what is throwing my rear end lift off. Comparing stock vs the total chaos shackles which are supposed to lower the rear 3/4”.... the holes are 2” apart. The leafs have a 1 1/2” lift and I lost half an inch after install. Maybe they sent me the wrong shackles?...
  16. Nov 3, 2020 at 5:14 AM
    #76
    Professional Hand Model
    Fred
    Hand Protectors
    Any way to put the old ones back on? Your new leafs will probably settle a little bit from what I’ve read from the really cool suspension guys threads.
  17. Nov 3, 2020 at 6:13 AM
    #77
    Voss
    2003 AC TRD 4x4
    Im planning to. Want to call total chaos just to double check I have the correct shackles. I’ll install the driver side tonight to see if both sides are same. Then I’ll replace with stock shackles and see what lift I get.
  18. Nov 3, 2020 at 6:33 AM
    #78
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Probably the right shackles, they're quite a bit longer than stock but they sit at an angle so the length isn't the total of what your truck is lowered. The math is too hard for me, I slept through geometry class.
    Good progress
    FirstGenVol and Voss[OP] like this.
  19. Nov 3, 2020 at 6:17 PM
    #79
    Voss
    2003 AC TRD 4x4
    Everything in.
    Rear;
    Driver: 35 7/8“
    Passenger: 35 3/4”
    Front;
    Driver: 36 1/4”
    Passenger: 36 1/2”
    If removing the total chaos shackles nets me 3/4” Lift in the rear... I couldn’t ask for more. Pretty perfect
  20. Nov 4, 2020 at 4:45 AM
    #80
    Fred
    Hand Protectors
    Survey says... old shackles back on!
  21. Nov 6, 2020 at 12:12 PM
    #81
    Voss
    2003 AC TRD 4x4
    Installed stock shackles and the rear lifted up to 37” both sides. Nice and even, gained over an inch.
    And.... 285/75R16 KO2’s are here. Sweet
  22. Nov 6, 2020 at 12:47 PM
    #82
    rock climber
    Nice! I'd love to see pics of the whole setup once you get the tires on.
    Voss[OP] likes this.
  23. Nov 6, 2020 at 3:12 PM
    #83
    Voss
    2003 AC TRD 4x4
    Will do
  24. Nov 7, 2020 at 1:58 PM
    #84
    Voss
    2003 AC TRD 4x4
    Tires on, pics below. Thanks again to everyone for all your help!
    alb1k, jpink, bmf4069 and 5 others like this.
  25. Nov 7, 2020 at 2:04 PM
    #85
    torino69
    torino69 The old guy
    West Fargo, North Dakota
    2004 Toyota Tundra Limited
    None worth mentioning
    Nice looking Tundra.
  26. Nov 7, 2020 at 2:06 PM
    #86
    Looks great!
  27. Nov 7, 2020 at 2:12 PM
    #87
    Fred
    Hand Protectors
    Post up your measurements from fender to center of wheel hub over in @Darkness ’How Big is Yours’ thread.
    FrenchToasty and Voss[OP] like this.
  28. Nov 7, 2020 at 2:54 PM
    #88
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Looking DAMN good! Those are my favorite Toyota wheels, great choice.
  29. Nov 7, 2020 at 3:14 PM
    #89
    torino69
    That is a nice looking Tundra
  30. Nov 7, 2020 at 3:22 PM
    #90
    torino69
    Are you located in Southern Cal. I worked in the San Fernando Valley from 1962 to 1998 when I retired and moved back to where we
    grew up in (Wifes idea) NW Minnesota area. Sure miss the winter weather in CA. My wife passed away in May of this year and I miss her a lot. My Brother retired from the LAPD and is in Mesquite, NV
