TRD Rear Sway Bar with 6" Lift
Discussion in 'Suspension' started by stealth09, Oct 17, 2018.
  1. May 5, 2020 at 5:13 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Helwig comes with adjustable links
  2. Oct 29, 2020 at 12:51 PM
    Mattco808
    Mattco808 New Member
    Mtt
    103F4B5B-6058-4C09-9CE2-082B536609D6.jpg 7B617D8E-A381-4B80-9E38-C300872A7E8F.jpg I came here months ago looking for info on extended rear links, I wanted to contribute what I found to this thread.
    Hellwig does make extended adjustable links, #7963 for 6” lift. It’s Pricey and in my experience, it’s always on backorder. I wasted a few months waiting just to cancel my orders.
    It ended up working out better as I found BDS makes extend links, 2 sizes and at good prices. Arrived a few days after ordering. Painted them up and installed.
    https://blog.bds-suspension.com/?p=21587
    BluFoxx82, rothmigo and diablodalton like this.
  3. Jun 20, 2024 at 3:49 PM
    WhiteDevil1978
    WhiteDevil1978 Ye Olde White Devil
    Dustin
    North Carolina, 'Murica
    2023 Tundra SR5 TRD Off-Road
    6 inch lift, 37 inch tires, Badlands Apex 12,000 lb winch, Fab Fours concealed winch mount with 30 inch LED, Prinsu roof rack with RC 40 inch LED and 10 inch RC LED's on sides, Auxbeam 12 switch controller, Heretic ditch lights, RetraxPro XR bed cover, Elevate bed crossbars with additional bar that connects them, Pedal Commander throttle control, overlanding solar array (2) LiTime 230ah batteries, Renogy 40 amp DC to DC charger, LiTime 60 amp MPPT, LiTime 40 amp LiFePO4 AC to DC charger, Renogy 400 watt suitcase panels
    I've seen some people say that you need no extended sway bar end links on a 6" lift. I have a Superlift #K1026 on a 2023 Tundra TRD Off-Road. I have had the lift for a little over a month and snapped one of the sway bar end links. I have never even taken the truck off road yet! My advice.... buy adjustable sway bar links that will accomodate your 6" lift. Yes, the factory end links will fit, but it is pre-loaded with an excessive amount of pressure and the sway bar links can, and in my case, DID break.
  4. Jun 20, 2024 at 3:55 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    BDS makes extended links cheaper than Hellwig.
