6112 Setting and Tire/Wheel Combo Thread.
Discussion in 'Suspension' started by Rngr188, Apr 4, 2018.
  1. Sep 30, 2020 at 3:02 PM
    #1351
    Hartsy8
    Hartsy8 Resident Hockey Guy
    Max
    2020 MGM 1794
    ... is the vote to throw it all on at once and live with tiny tires for a bit?...
  2. Sep 30, 2020 at 3:12 PM
    #1352
    RobertD
    Robert
    DFW, Texas
    @Hartsy8 I missed how much lift you are wanting to do. If you are lifting the front 2" or less, I doubt anyone besides you will really notice. If you are lifting about 3"+ I think it would look a little funny. Also, what is a bit?
    Either way, I'd say do the suspension all at once and live with your current tires until you can put on the new ones.
  3. Sep 30, 2020 at 3:16 PM
    #1353
    Hartsy8
    Max
    2020 MGM 1794
    I’m thinking that is probably the way to do it. Thanks, Robert!
    RobertD[QUOTED] likes this.
  4. Oct 1, 2020 at 11:04 AM
    #1354
    Tortuga83
    Tortuga83 New Member
    Tortuga
    I ordered mine from shocksurplus.com . You can get the assembled from settings 1 - 4. I did this set up with stock TSS off road rims and tires and added JBA UCA.
  5. Oct 5, 2020 at 4:44 PM
    #1355
    Cpa757va
    Cpa757va New Member
    Chad
    Hampton roads VA
    2019 Tundra limited TRD off road
    See build thread below.
    Bilsteins 6112 up front at max setting (2.5”) with a 1/2” shim on each side for a total of 3” lift in front. Bilstein 5100s in rear with 1.5” Toytec shackles in rear. Delta joint UCAs. 285/70/18 nitto ridge grapplers with SCS ray 10’s.
  6. Oct 8, 2020 at 7:31 PM
    #1356
    Hartsy8
    Max
    2020 MGM 1794
    Hey all still struggling deciding what to do. I have a buddy helping me throw in my 6112s and 5160s tomorrow... I am struggling deciding between:
    1) setting the front at 1.9s and putting in the 1.5 Camburg shackles in the rear
    2) setting the front at 2.5 and putting the 1.5 shackles in the rear
    Or
    3) just setting the front at 1.9 and leaving the shackles off until it’s time for bigger tires...
    Advice? Thoughts? Inputs?
    Thanks!
  7. Oct 8, 2020 at 7:39 PM
    #1357
    Heatjay
    Heatjay New Member
    2018 TUNDRA PLATNIUM MG
    I am getting the same set installed next week. just going to do the 6112 and 5160, nothing else. Hoping to fit 275/70/18 with no issues.
  8. Oct 8, 2020 at 7:40 PM
    #1358
    Hartsy8
    Max
    2020 MGM 1794
    At what setting though? I am torn!
  9. Oct 10, 2020 at 9:06 AM
    #1359
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, King 2.5's/Bilstein 5160's, Built Right UCA,s, Method 701's, TOYO ATIII 35x12.5x17, TRD LED headlights, Pro Grill
    I would go 1.9 and stand by on rear lift until they settle- maybe a few weeks. I went from an 08 Tacoma with spacers, blocks and add a leaf and 35s to a new 2017 Tundra. The Tacoma looked bad ass and was fine on the beach but that lift was definitely not performance focused. The Tundra wasn't cheap and I plan on driving it until the wheels fall off so performance is a priority. I researched the best to my ability and ended linking up with Keith Carty as a buddy. Keith provided guidance and explained the why's and how's. There are many factors that influence overall ride/performance, breaking, geometry...
    Here is my story: I first wanted Kings (still do) but decided that for my use as a daily driver with a very small percentage of offroad use that Bilstein 6112s/51160s was the way to start. I planned on setting at 1.9 with 2 sims DS and 1 shim PS with a CB +2 shackle in rear. I linked up with David Ekstrom and purchased the shackle and shims- also picked up a diff drop kit from big box store.
    After Keith imparted his knowledge on me I decided to go 1.3 with no shims. Once the 6112s settled I got the lean- it was noticeable. Instead of adding a shim to the DS I had he DS set to 1.9 setting (PS remains at 1.3 setting). Truck is level in front and has .25" rake. Stock rear height with 5160s. So this was based off of theory and "experimentation" and worked out for me however, most go with shims to increase height and counter the lean.
    This is how she currently sits
    Front DS 23.4" Front PS 23.5"
    Rear DS 24.2" Rear PS 24"
    *crazy how the geometry works.
    *stock was just about 21.5" in front so right around 2" increase in front.
    I went with Method 701s (17 x 8.5) and 295/70r17 Mickey Thompson ATZs (33.2 x 12). I and happy with the offset and width of tires. Just did the front wheel-well liner trim and push.
    5766FD31-6BDB-4444-95BF-6A48C3E2E17E.jpg 5766FD31-6BDB-4444-95BF-6A48C3E2E17E.jpg
    My )* Tacoma I had (miss it). Body lift add a leaf, Mickey T 35s, pro comp wheels, manual.
    J&ATundra and drobb like this.
  10. Oct 10, 2020 at 9:11 AM
    #1360
    Hartsy8
    Max
    2020 MGM 1794
    Very nice! Just got mine on at 1.9 and have some lean so I will likely throw in a single shim down the road
  11. Oct 10, 2020 at 12:56 PM
    #1361
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    Nice. Post some pics sometime.
  12. Oct 10, 2020 at 4:25 PM
    #1362
    Hartsy8
    Max
    2020 MGM 1794
    Little preview of the busy Saturday I had!got front and rears on
    RobertD, drobb and AZBoatHauler like this.
  13. Oct 11, 2020 at 5:51 AM
    #1363
    dpast88
    dpast88 New Member
    Dennis
    Furlong, PA
    2015 Tree
    Is it safe to say your settings are the same as 6112 on the 1.3” setting with one shim on the drivers side?
  14. Oct 11, 2020 at 7:11 AM
    #1364
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    Looks good!
  15. Oct 11, 2020 at 7:30 AM
    #1365
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    I ended up with pretty close to a 2" height increase in front- went from 21.8ish to 23.5". I took measurement from center bore to fender on "level" surface with full tank. Its not much at all and I think the Tundra should come stock like that, but it allowed me to fit a tire size that doesn't impact performance too much and looks good - no regear (although anything bigger than stock will benefit from regearing).
    Im a novice with all this but this is how I see it- if I went with like a 3/2 lift I would need 35s and would optimally need to regear and deal with CV angles, drive shaft angles and more.
    - The settings on the 6112's are not an exact measurement so 1.9 could be higher or lower...also need to take into account additional weight such as steel skids, aftermarket bumper/winch.... I don't have any of those- yet.
  16. Oct 16, 2020 at 9:27 PM
    #1366
    SnowB0und
    SnowB0und New Member
    2013 SR5
    Anyone buy new top hats (strut mount) for the Bilstein's? Any experiences with Moog vs factory? I'm debating buying new ones before I install the 6112's.
  17. Oct 24, 2020 at 4:24 AM
    #1367
    HammockYota
    HammockYota New Member
    2015 Tundra TRD OR
    After being tortured by this thread for a few weeks, I Ordered the 6112s and 5160s from @BOSS4x4s yesterday, and they are great to work with!
    Is it a given I need a CB shim for the driver side? Just trying to decide if I’m going to go ahead and install one in the first place, or should I wait for any settling/lean to declare itself?
    Thank you all for being enablers.
    AZBoatHauler likes this.
  18. Oct 24, 2020 at 5:27 AM
    #1368
    AZBoatHauler
    So.Arizona
    Take a tape measure and compare measurements from the ground to the top of the fender well going through the middle of each front wheel. If your drivers side is at least a half inch lower then order a shim. Try to do this on level ground with a mostly full tank of gas.
    HammockYota[QUOTED] likes this.
  19. Oct 24, 2020 at 6:23 AM
    #1369
    HammockYota
    2015 Tundra TRD OR
    You think the lean should be consistent between the stock suspension (TRD Bilsteins) and the new set up? I’ll go with that. Thanks.
  20. Oct 24, 2020 at 6:34 AM
    #1370
    AZBoatHauler
    So.Arizona
    That’s what I’ve see. I had about 3/4” lean with TRD OR suspension before and lean is down to 1/8-1/4” after installing 1 CB shim drivers side with 6112 set at 1.9”.
    Trucks that don’t have a lean before install seem to stay level.
  21. Oct 24, 2020 at 6:37 AM
    #1371
    Hartsy8
    Max
    2020 MGM 1794
    I went from level to a pretty significant lean. I’d just throw it in
    HammockYota likes this.
  22. Oct 24, 2020 at 7:11 AM
    #1372
    TelemarkTumalo
    TelemarkTumalo New Member
    Mark
    Bend, OR
    Great looking truck and I dig those wheels
    Rica25 likes this.
  23. Oct 24, 2020 at 8:31 AM
    #1373
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    I did not have a lean with stock suspension but had noticeable lean after 6112s installed.
    Rica25 and HammockYota like this.
  24. Oct 25, 2020 at 7:47 PM
    #1374
    Quicksand_Tundra
    Quicksand_Tundra New Member
    Jon
    2019 Quicksand Tundra CM 4x4
    -Color keyed grill & bumper -Diode Dynamic SAE LED Foglights -Headlight Revolution LED Light upgrade -SCS SR8 18x9 with 295/70/18 Toyo Open Country AT3 -Go Rhino Dominator D6 Steps -TRD OEM Intake & Dual exhaust -Bilstein 6112 front and 5160 in rear -JL Audio C2 6.5" speakers upgrade powered by JL Audio RD 400/4 amp -Pair of AudioFrog GS25 speakers front dash -10” Kicker Hideaway subwoofer under driver seat -All doors covered with Soundskins deadening mat (inside/outside) -Front window tinted at 35% -Paint protection film full front -30” Rigid Industries SAE light bar -Body Mount Chop -Diode Dynamics SS2 (red) setup for brake light & turn signal -Katzskin Custom leather upgrade (Black/Bamboo) -Amber led running lights (Hood bulge) -AJT Design: Black vent rings, steering wheel trim, shift gate trim, emblem overlay -AJT Design: Quicksand door handle cover -Carbon fiber wrap (silver part on door panel) -Air Design tailgate applique (Line-X in smooth gloss finish) -Air Design tailgate spoiler (Line-X in smooth gloss finish) -Smittybilt beaver step (Line-X) -Valhalla Cat Shield (Line-X) -Coachbuilder Shackles kit +2 -Coachbuilder Strut/Coilover shim (0.5" for driver side) -Sumosprings (rear bumpstop) -Meso Custom Led front and rear cab lights -Teton shop shift knob -TRD Seat belt shoulder pad -Husky floor liner front/back -LED courtesy door/step light -LED bed light kit w/ outside switch
    Washed, waxed, spray waxed, and tire shine.
  25. Oct 25, 2020 at 7:53 PM
    #1375
    grichg
    grichg New Member
    rich
    Westcott Designs and Installed
  26. Oct 28, 2020 at 8:27 AM
    #1376
    Tundra_Protege1128
    Tundra_Protege1128 New Member
    Anthony
    Just got her back. Had 6112s installed at top setting with 5100s. Tires are NR Grapplers 295/70/18. Measuring .5in lower in rear. Hoping the front settles to make it perfectly level. May add 1in shackles to help with weight in the bed. Anyone have this same set up and had the front settle out to meet the rear? I know it will settle some, but not sure about a 1/2 inch.
  27. Oct 29, 2020 at 7:12 AM
    #1377
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    Your Tundra looks bitch'n! I'd probably go with a Coach Builder +1 (.625" lift) shackle for level or +2 (1.25" lift) to maintain some rake. I believe the 5100s only allow for for 1" lift in rear...
    Rica25 likes this.
  28. Oct 29, 2020 at 7:41 AM
    #1378
    Nickj619
    Nickj619 New Member
    San Jose, ca
    2014 tundra trd crew max
    When I did my lift I did top setting with (2) .25” shims on the driver side and (1) .25” shims on the passenger side with a coach builder +3 shackle and it’s perfectly level
  29. Oct 31, 2020 at 2:42 PM
    #1379
    Mr. White
    Mr. White Poco Loco
    San Antonio
    2020 Family 4x4
    Just installed my 6112's and 5160's.
    Third notch (1.9"). Stock 18" TRD wheels with 275/65R18 Nitto Ridge Grappler's.
  30. Oct 31, 2020 at 2:45 PM
    #1380
    Damie Street
    Damie Street New Member
    Edsel
    2016 MGM CrewMax SR5 TRD OffRoad
    Looks good!!
    Rica25 likes this.
