What does these indicators and levels mean?
Discussion in '1st Gen Tundras (2000-2006)' started by 1kTyy_1, Oct 16, 2020.
  1. Oct 16, 2020 at 1:17 PM
    1kTyy_1
    1kTyy_1 [OP] New Member
    2001 Toyota Tundra SR5 V8 4.7L 2WD
    What does the symbols and levels mean?
  2. Oct 16, 2020 at 1:31 PM
    The top one is oil pressure and it's normal for it to be low when the engine is idling. The bottom one is engine temperature and that does not look normal. It should be in the middle.
    If you're asking about the light, that's your seatbelt indicator.
  3. Oct 16, 2020 at 1:32 PM
  4. Oct 16, 2020 at 1:50 PM
    Piney
    Piney New Member
    South Jersey Pine Barrens
    2020 MGM TRD Pro
    The bottom one is off scale high coolant temp......danger zone.
  5. Oct 16, 2020 at 2:14 PM
    Metoobutilikedit
    Metoobutilikedit New Member
    2002 V6 SR5
    All stock except for the hitch, a purest. Original owner
    Your oil pressure is fine. Mine bounces up and down as I stop and go. The link posted by FirstGenVol is really good, there's good info in there.
    Now your temperature gauge says you're burning up, I wouldn't run the truck like that. Could be all kinds of things from a thermostat to a head gasket, maybe even air in the line. You need to get that checked out before you blow the engine
  6. Oct 16, 2020 at 2:29 PM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    Holy cheet.
    I wouldn’t drive your truck another minute until you figure out why it’s overheating.
  7. Oct 16, 2020 at 3:05 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    well. i see your coolant gauge is working the opposite of mine. can be an electrical issue, OR your engine is not running if its up that high.. seriously. over red is engine seized territory
  8. Oct 16, 2020 at 3:17 PM
    Is this going to be one of those where we never hear from the OP again?
  9. Oct 16, 2020 at 3:18 PM
    13igtymer
    13igtymer New Member
    2016 toyota tundra crewmax limited
    Check your coolant once your engine cools down. Also check for a broken hoses.
  10. Oct 16, 2020 at 3:29 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Bottom Gauge Hot AF.
    bmf4069 and TXRailRoadBandit73 like this.
  11. Oct 16, 2020 at 4:09 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Pain.
  12. Oct 16, 2020 at 4:37 PM
    peanut
    peanut making uneconomical choices about my truck
    2001 Tundra 4x4 V8 Access cab 222k miles
    For the temp gauge it could also show that the coolant temp sensor wire is grounded. So check the wire and sensor once the engine is cool. Once the engine is cool turn the key on and if the gauge goes from 0 to that high then the wire is grounded somewhere between the sensor and the ecu.
    Darkness and Stumplifter like this.
  13. Oct 16, 2020 at 5:51 PM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    .....And as quickly as he rode into town, he was gone...
  14. Oct 17, 2020 at 5:57 PM
    smokey0810
    smokey0810 New Member
    '03 Tundra SR5 AC 4WD
    He could’ve saved some bandwidth and just opened his owners manual if he has one.
  15. Oct 17, 2020 at 6:12 PM
    fbingha
    fbingha New Member
    Bakersfield, CA
    After posting from his truck, it caught fire and that was all she wrote.
  16. Oct 17, 2020 at 6:25 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    This got an officially licensed guffaw from me.
    GODZILLA, bmf4069, smokey0810 and 2 others like this.
  17. Oct 17, 2020 at 7:13 PM
    tmac58star
    tmac58star New Member
    Black 1st generation Tundra SR5 Access Cab
    More likely he stopped, posted...waited, then took off again but passed out from coolant poisoning/steam inhalation and went off into the ditch in high weeds/grass and won't be seen/found until the highway mowing crews work that road. So much for early deer season this year...
    Pucks18, smokey0810 and Schcoman like this.
  18. Oct 19, 2020 at 8:27 AM
    Jerry311SD
    Jerry311SD New Member
    Jerry
    Ramona San Diego CA
    05 Tundra
    Oil is low
    Coolant is full
    bmf4069 likes this.
  19. Oct 20, 2020 at 5:13 AM
    Uhhhh.....yeah. is this a troll post?
    Darkness and Cpl_Punishment like this.
  20. Oct 20, 2020 at 5:31 AM
    bmf4069[QUOTED] likes this.
  21. Oct 20, 2020 at 7:00 AM
    SouthPaw
    2000 Limited 4x4 AC
    How the OP looked when they got home typing this thread.
  22. Oct 20, 2020 at 8:06 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
  23. Oct 20, 2020 at 8:18 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Probably some turd gen guy who you banished and is now seeking revenge.
  24. Oct 20, 2020 at 8:21 AM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Those gauges mean everyone in this thread is a sucka! Including me :pout:
    Darkness likes this.
  25. Oct 20, 2020 at 9:58 AM
    Fred
    Hand Protectors
    Yeah. I’ve noticed Turd Gen angst as of late. Couple of them coming over on purpose to stir the pot. :rofl:
  26. Oct 20, 2020 at 10:17 AM
    18" TRD Off Road Wheels
    :anonymous:
  27. Oct 20, 2020 at 10:56 AM
  28. Oct 20, 2020 at 10:57 AM
  29. Oct 20, 2020 at 11:34 AM
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
