Seafoam a fix for the dirty fuel sensor?
Discussion in '1st Gen Tundras (2000-2006)' started by Bobfest, Oct 19, 2020.
  1. Oct 19, 2020 at 11:51 AM
    Bobfest
    Bobfest [OP] New Member
    Kind of as the title states.
    I have the "stuck at 1/4 tank" fuel gauge issue. If the same holds true for me, I have a dirty fuel sensor in the tank.
    Has anyone tried Seafoam in the fuel tank to try and fix the sensor issue? The theory adds up, as the Seafoam is meant to clean off carbon deposits in the systems you use it in.
    Just curious, I don't want pulling the bed to acess the tank being option #1.
    Many thanks!
    YardBird likes this.
  2. Oct 19, 2020 at 12:00 PM
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    I doubt you have a dirty fuel sensor/sending unit since gasoline is a pretty effective solvent. The carbon deposits Seafoam is meant to clean are in your combustion chamber, not your fuel tank. Give this a try, hopefully this will do the trick.
    https://www.tundras.com/threads/stuck-fuel-gauge.66843/
  3. Oct 19, 2020 at 12:34 PM
    Berkdawg
    Berkdawg New Member
    2013 Rock Warrior
    Clazzio Seat Covers, Eibach/Toytec Coil Overs (3"), Toytec Boss Rear Shocks, Firestone Airbags
    I had this issue in a Ford Freestyle and I read to use Chevron Techron Fuel Treatment. It worked and the issue has not returned. Good Luck.
  4. Oct 19, 2020 at 12:40 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  5. Oct 19, 2020 at 1:30 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Another member had this problem after off roading. He banged on the tank and fixed it. True story.
  6. Oct 19, 2020 at 2:36 PM
    Elk Hunter drove his off a cliff. Fixed it. Tru Story......
  7. Oct 19, 2020 at 6:24 PM
    Wallygator
    Never had this issue but I use Amsoil P.I. every oil change. I use it in everything. I'm not affiliated...May be worth a try for you?
    I put it in and beat the truck for a whole tank full....meaning full throttle starts. Random full throttle times, etc...
  8. Oct 20, 2020 at 8:57 AM
    Bobfest
    Haha!
    Gave the tank a good kick, that didn't work. I am going to try and take it off road a little today, see if that shakes it up a bit.
    Possibly an additive...
    it doesn't bother me too much, I will try a few recommendations here before tearing into the tank.
  9. Oct 20, 2020 at 8:58 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    The cleaning agent in Seafoam is naphtha, commonly sold as white gas for Coleman stoves. You can get a gallon of it pretty cheap at the hardware store or anyplace you find camping supplies (Walmart).
    Add few ounces of that and a dash of TC-W3 2 stroke oil and you have a good fuel system cleaner/lubricant.
  10. Oct 20, 2020 at 9:53 AM
    BassBlaster
    BassBlaster New Member
    Jay
    2016 silver 1794
    Bilsteins front and rear
    Sea Foam is not just for carbon deposits! It's also to get rid of gum and varnish from fuel and fuel-burning. I am not a mechanic, it's just what they say on their website, and since I do some work for them I hear it all the time. My 2c recommendation is to use Sea Foam High Mileage -- seems a little "stronger" to me, but then again I only drive higher-mileage stuff!
  11. Oct 22, 2020 at 6:34 PM
    tmac58star
    tmac58star New Member
    Black 1st generation Tundra SR5 Access Cab
    Double up the recommended dose of Sea Foam in a couple of tanks of high-test gasoline of your favorite brand...Chevron and Shell both have high-test and advertise their clean qualities.
    If that doesn't work, loosen the bed bolts and raise the bed and service the in-tank fuel level sender. Did this years ago on a full-sized F150 with dual tanks under the bed and two fuel pumps with bad return line shutoffs...you could fill the front tank, take off down the road, look in the rearview mirror and see gas dripping/oozing out of the rear tank filler neck because the return line valve was faulty. Went to my fav shop and paid them $10 to break the bed bolts loose with their air impact...drove it home, pulled the bolts and disconnected the lights and tank filler hoses and pushed the bed back to replace the front pump. Pushed the bed back forward, jacked it up from one side and replaced the rear pump. Took all of about 3 hours in the driveway...just me, myself and I.
    Can't imagine getting to a Tundra tank would be more difficult...or you could just drop the tank.
