  1. Oct 18, 2020 at 10:17 AM
    Hcreager
    Hcreager New Member
    Glendale, AZ and Vail, CO
    2017 Black Tundra Platinum
    Winjet Tail Lights, TRD Intake, Magnaflo exhaust, Morimoto Head/Fog Lights, Upgraded LED's interior/exterior, Chrome delete interior, plati-dipped grill and hood bulge grill....hopefully many more to come
    I did my reverse lights and cargo/3rd brake lights with replacements from headlight revolution, LOVE THEM...also did the Morimoto head lights and fog lights and interior kit.
    Fotnot[QUOTED] likes this.
  2. Oct 18, 2020 at 10:36 AM
    2020Platinum
    2020Platinum www.youtube.com/NitroZ18Fishing
    Patrick
    Northeast PA
    2022 TRD Pro (Lunar Rock)
    A lot. See my channel for all installs/mods!
    Thank you!!...heres everything I used, ran me about $400 total and honestly if I didn’t do three full coats on the entire truck you can easily get two vehicles from this kit… I have some of everything left over even after the three coats
    Ceramic Kit- https://dura-coating.com/products/professional-ceramic-package
    Foam Pads- https://www.amazon.com/SPTA-Backing-Compound-Polishing-Polisher/dp/B07STT35FF
    Applicators- https://www.amazon.com/Applicator-Microfiber-Sponge-Plastic-Barrier/dp/B07H4SNLPF
    Iron X- https://www.amazon.com/CarPro-Lemon-Scent-Liter-Sprayer/dp/B00FEL30R0
    jpod, GAknight and Hightide like this.
  3. Oct 18, 2020 at 11:10 AM
    00PS
    00PS New Member
    2016 Barcelona Red Limited Crewmax TRD 4x4
    I doesn't really matter since you have adjustable collars...check the height after you put them on and adjust as necessary.
    CorsoTundra[QUOTED] likes this.
  4. Oct 18, 2020 at 11:16 AM
    Funnyguy713
    Funnyguy713 I can't get Jiggy with this Sh!t
    Houston TX
    2017 Tundra 1794 4x4
    35s on 20s with 6" Pro Comp
    Replace the rotors and brake pads with Genuine Toyota parts cost $288 for Rotors and $99 for the pads and shims. Took me 4 hours to do the front and 2 hours for the rear. Quiet as a mouse now, no more noise at 49K miles.
    Cosmoblu, GAknight, GELCW and 2 others like this.
  5. Oct 18, 2020 at 11:53 AM
    Damn! Come do mine. I installed Autolocs today....the wire colors were definitely different than yours.
    2020Platinum[QUOTED] likes this.
  6. Oct 18, 2020 at 12:58 PM
    CorsoTundra
    CorsoTundra This is the way
    North GA
    2021 Cement Trail Edition
    Toytec Aluma 3/1.5, Pro headlights, OEM LED fog lights, AJT chrome delete, interior/exterior LEDs, front TRD sway, 18x9 Method Roosts, 285/75/18 Toyo A/T 3, RCI engine skid,
    Yeah, I just didn't want to mess with them. Just want to put them on and be done.
  7. Oct 18, 2020 at 1:28 PM
    WVUTrdPro
    WVUTrdPro New Member
    Joe
    2020 Toyota Tundra Trd Pro
    Significantly more annoying sound. Not embarrassed to lay on the horn anymore.
    TheyCallMeBruce84 likes this.
  8. Oct 18, 2020 at 3:04 PM
    2020Platinum
    Patrick
    Northeast PA
    Nice!...yea I’m thinking because my Platinum already has the auto up/down on the passenger door the wiring may be different on other trims...how about the back 2 doors, they different???...I would think they would be the same
  9. Oct 18, 2020 at 3:19 PM
  10. Oct 18, 2020 at 3:21 PM
    2020Platinum
    Patrick
    Northeast PA
  11. Oct 18, 2020 at 3:42 PM
    Saab95v6
    Saab95v6 New Member
    I have 1325 miles , did my first oil change , swapped over to the metal oil filter housing , installed the stahlbus in place of the oils drain nut for easy future oil changes . I have been using stahlbus on my 2012 Toyota Highlander, ever since it new , no issues whatsoever, and I have 100k miles on it. The skid plate on my 2020 Platinum is a PIA , may have to look for TRD skid plate, with reasonable shipping charges.
    GELCW and HulkSmurf14 like this.
  12. Oct 18, 2020 at 4:02 PM
    :thumbsup:. Its all good. Can't complain for $100 shipped for all 4.
  13. Oct 18, 2020 at 4:07 PM
    Long Duck Dink
    Long Duck Dink Nope
    North Salt Lake, UT
    2019 Super White 1794 Edition Tundra CrewMax 4x4
    3/2" Readylift, TRD Dual Exhaust, TRD Sway Bar, Line-X Bedliner, ArmorFlex Tonneau, ESP 3 bin storage, Amp Power-Steps, Driver Side Grab Handle, Ronin Antenna, Window Tint, ClearBra. Coming Soon: 20" Method MR305NV. BF Goodrich KO2 275/60/20
    @CorsoTundra are you lifting the back at all? If so, how much?
    Please post pics when you're done!
  14. Oct 18, 2020 at 4:12 PM
    Are you looking to lift? I have the same coilovers and 2 inches of lift in the rear.
  15. Oct 18, 2020 at 4:15 PM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    Bak Revolver, BedRug, Undercover Swingcase, PopLock, Bilstein 5160(rear), Firestone RideRite, TRD rear sway bar, Coachbuilder +2 rear shackles, Andersen 5” aluminum adjustable hitch, TRD dual exhaust, VLEDS interior leds including the footwell kit, TundraTex FRAC mod, VLEDS LPR backup tag mount led, Husky X-Act mats, Color matched cup holder bezel (silver), Ceramic 20% tint all around, 50% Ceramic windshield, Color Matched door handles & mirror caps, The “Stubby” antenna, AMP Research steps, VLEDS 6”step lights, ToyTec/5100 Bilstein coil overs, 700lbs red ToyTec springs (2.75” lift), 20x9 +18 Method 306 custom painted and custom fit center caps, Gorilla spline lugs, Bridgestone Revo 3s 285/60R20, TRD skid plate, RaptorLiner “Red” tow hooks, 19 Pro black LED headlights, VLEDS Triton V6 turns, Rigid SAE D series fog lamps, 19 TRD hood scoop, 2019 TRD Pro grille, Coachbuilder bumper shims, X-Pel protect under mud guards, Opti Coat Ceramic, Opti Coat Sealed. And some snakes and sparklers, because they are my favorite!
    Ditched the plastic oil filter housing for the aluminum counterpart along with an oil change. Gave it a much needed clean up, and removed the X-Pel from the sides. X-Pel held up great (2 years 30k), replacement should be here by the end of the week. I have new transmission fluid here but I’m out of steam for the day. I also need to do a little research on how exactly to service the transmission. Any help there would be appreciated.
    2CBAEB15-0F16-4A2F-BCEB-0942C8F8C464.jpg 078E6076-C489-49CE-9689-87596DD94446.jpg
    Before, notice the small black spots or would be chips.
    After, not a spot on it.
    Even cleaned the engine bay.
  16. Oct 18, 2020 at 4:22 PM
    bsktball55
    bsktball55 New Member
    Missouri
    16 Tundra TRD Pro
    Bakflip MX4 Toneau cover Esp storage Audio system (Helix speakers, JL audio amp and sub) Front windows and windshield tinted LED interior and bed lights
    Replaced the motor on my driver's side door lock actuator. The lock would stop working every once in a while. Same thing happened on my Tacoma when I had it. Spent 5 dollars on an electric motor for it and replaced it. Saved a lot of money. While I had the door panel off, I went ahead and put some sound deadening on the door as well.
  17. Oct 18, 2020 at 4:24 PM
    Great job Patrick.
  18. Oct 18, 2020 at 5:09 PM
    RobertD
    Robert
    DFW, Texas
    Thanks @BlueRibbon4x4 for posting this mod info and answering all my questions. Pretty straight forward process. No mod pictures taken. See BlueRibbons build thread for that stuff :rofl:
    Really happy with light placement and illumination.
    Edit to add picture later in the night. Really happy with this in person.
  19. Oct 18, 2020 at 5:32 PM
    dspilot
    dspilot Professional Nomad
    North Mississippi
    2019 SR5 4X4 Silver Sky Metallic
    I'd guess not. Not looking at it right now, but what I can recall from memory, I don't think they come out that far.
  20. Oct 18, 2020 at 5:48 PM
    Nice garage too!
  21. Oct 18, 2020 at 5:50 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    That blue on blue!! :headbang:
  22. Oct 18, 2020 at 6:25 PM
    Jonnynewton909
    Jonnynewton909 Jonnys_Tundra
    Jonny
    East Texas
    2017 Tundra CrewMax
    Accutune Fox DSC 2.5 front w/ SPC UCAs, Alcan custom spring pack and Accutune Fox DSC 2.5 rear. 37 Toyo RT Trails on Method 312s. SOB Fab F&R high clearance bumpers. AT Overland Atlas.
    Swapped the silver interior door handles out for OEM black ones. Silver ones are for sale if anyone is interested btw.
  23. Oct 18, 2020 at 6:50 PM
    BrianH4x4
    BrianH4x4 New Member
    Shelby, North Carolina
    2015 silver sky metallic
    USB plug added for backseat 6 circuit fuse holder added Amp power steps Bed lights Bumper led ( anytime) lights Amp reasearch bed step Focal three way components up front Focal 165 in rear Jl xd200 amp for front stage Jl xd 300 amp for 10 W3 -D4 sub Maestro rr for steering wheel control
    Have this ole girl a bath today!! She was dirty. 75ED8603-1AC7-4419-ABAD-AA7BFE2FCE07.jpg
  24. Oct 18, 2020 at 7:10 PM
    DCB500
    DCB500 New Member
    Oklahoma City
    2019 Tundra SR5 TSS Double Cab
    Wheels, sound system, antenna, tailgate letter inserts, Grill/Hood Bulge, Exhaust, Leather
    i asked for mine to be set at 2” initially from Toytec because I wasn’t doing anything to the rear at that moment, but mine were the boss 2.0 and the adjust from the bottom. It’s supposed to be a 2/1 ratio (1/2” of threads = 1” of lift) but when I put mine on they were set to 4” of lift so I had to back them way off....so they might have just adjusted mine in the wrong direction or something.
  25. Oct 18, 2020 at 7:37 PM
    rockjockey
    rockjockey Per ardua ad astra!
    Spring, TX
    2016 White Tundra TSS
    Always interesting to see what other folks carry in their door pockets. Looks like you’re well prepared for a number of activities. I have that same tape measure - it’s worked great for 10 years.
    TelemarkTumalo likes this.
  26. Oct 18, 2020 at 8:06 PM
    Jonnynewton909
    Jonny
    East Texas
    2017 Tundra CrewMax
    I keep a little bit of it all in there! Those are great tapes, to bad they quit making them!
  27. Oct 18, 2020 at 8:11 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    The better half and I ventured out for an impromptu trek through Bulldog Canyon, where Mother Nature decided to leave its mark on the truck with some pinstripe action. The better half had a blast but she was not amused with the scrapes from tip to tail on both sides of the truck, to which I laughed and said...
    :itllbuffout:
    Woke up and assessed Mother Nature's handiwork, she left some really good ones, a full wash and single step paint correction removed 95% of the pinstripes and resealed with paint sealant. In my haste to revive the paint, forgot to take before pictures but here is an after shot of the worst panel.
    and a front quarter view of clean truck.
    Realization, full stock platinum can do these types of trips, but really needs some upgrades to make it a bit less nerve racking...factory 20s with no sidewalls, stock suspension and no real undercarriage protection needs to be addressed...:monocle:
    -Jason
  28. Oct 18, 2020 at 8:43 PM
    CorsoTundra
    North GA
    Got the Toytec shackles to lift the rear 1.5"
  29. Oct 18, 2020 at 8:49 PM
    TelemarkTumalo
    TelemarkTumalo New Member
    Mark
    Bend, OR
    Sounds like an adventure
    GODZILLA likes this.
  30. Oct 18, 2020 at 8:51 PM
    Pillslinger
    Pillslinger New Member
    Rollin
    SWMO
    2018 Cement TRD CrewMax
    Bed light kit Jerry can mount Badge overlays (removed 2021) Pin stripe / TRD decal / pillar vinyl removal Raised tailgate lettering Center console badge/tray/divider Interior/exterior LED upgrade VLED footwells TVD Vinyl TRD Offroad wheels Icon 17x8 rebound titanium Bubbas Garage grab handles WeatherTech floor mats (Eagle Klaw added) Rough country front shackles (removed 2021) DD SS3 yellow fogs MESO map light replacement Softopper MESO Chrome delete
    My god is that an old lever lock stanley? If so I've got one of those that stretches back to the mid 90's! One of my favorites.
    snarkscarbine likes this.
