Intermittent Cruise Control Issue
Discussion in '2nd Gen Tundras (2007-2013)' started by Drewb5, Oct 10, 2020.
  1. Oct 10, 2020 at 5:59 PM
    Drewb5
    Drewb5 [OP] New Member
    2008 Toyota Tundra Limited 5.7
    57CC27FC-5898-44C3-B6E1-A1479388BF82.jpg If you can tell from my threads I have quite a few small electrical issues I’m trying to fix. The last one being my cruise control. Couple weeks ago it began only working part of the time. I’ll click it 50 times without a minute and it won’t turn on, and then 15 minutes later I’ll click it once and it is working fine. It’s like this all the time. The only function that doesn’t work is the on/off on the lever. All the other functions work when it is turned on. Anyone else have a similar issue? Did you end up having to replace the entire cruise control stem? I’d like to not have to do that if possible, since it is only the one button not functioning correctly. Thanks for the help!
  2. Oct 12, 2020 at 9:03 PM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level LIft
    @Drewb5 Do you still have other CEL codes as shown on other thread? Maybe ABS problem/code is affecting the CC?
  3. Oct 12, 2020 at 9:17 PM
    Drewb5
    C56A64FD-EE9E-4B34-8386-4E1108C85666.jpg These are the codes I have remaining from my repair spree.
  4. Oct 12, 2020 at 9:24 PM
    Dalandshark
    Northwest
    Eibach Level LIft
