Radio has no power...what fuses?
Discussion in 'Audio & Video' started by Tundra234, Oct 12, 2020.
  1. Oct 12, 2020 at 1:56 PM
    Tundra234 [OP] New Member
    I checked that one yesterday when it (radio) went out. I'm getting frustrated :(
  2. Oct 12, 2020 at 1:58 PM
    Yes I checked it too.
  3. Oct 12, 2020 at 2:07 PM
    Time to get a test light and check the plug that goes into the radio for power. All fuses are good, radio could be bad now.
    AZBoatHauler likes this.
  4. Oct 12, 2020 at 2:12 PM
    I would think that it would take alot to fry it. It was working initially when I hooked the battery back up. There was a power and ground wire for the camera that I hooked up to the camera switch and thats when it stopped working.
  5. Oct 12, 2020 at 2:16 PM
    If the pins weren't sitting straight.
    I can't understand either. If all the fuses are good then there should be power at the plug that's why I said check the plug. I don't have anymore ideas.
    :notsure: Sorry.
  6. Oct 12, 2020 at 2:30 PM
    CaptainGrumpus
    CaptainGrumpus The Mailman
    Maine
    2018 Inferno Tundra TRD
    I wish I had a spare HU to send you to give it a test. Maybe someone has one kicking around that they wouldn’t mind loaning out.
  7. Oct 12, 2020 at 3:01 PM
    One option would be to buy a harness for my Pioneer that I took out of my 2013 and see if I have power or not. If not, that would rule out the radio being bad.
  8. Oct 12, 2020 at 3:06 PM
    So would a test light or meter.
    Black Wolf and 1lowlife like this.
  9. Oct 12, 2020 at 3:12 PM
    I'm wondering if the 2nd and 3rd gen plugs are the same.
  10. Oct 12, 2020 at 3:15 PM
    I'm wondering if you have a test light.
    Black Wolf, TRDFerguson and 1lowlife like this.
  11. Oct 12, 2020 at 3:19 PM
    Lol. Somewhere....but I do know where my meter is.
  12. Oct 12, 2020 at 3:20 PM
    Long ride to work tomm without music.
  13. Oct 12, 2020 at 3:21 PM
    Meter would work.
  14. Oct 12, 2020 at 3:22 PM
    AZBoatHauler
    So.Arizona
    Test light should be in the glovebox!! :boink:
    Kung and Black Wolf like this.
  15. Oct 12, 2020 at 4:03 PM
    Grumpy Uncle
    Pat
    CO
    I would get a test light.
    Black Wolf and Jim LE 1301 like this.
  16. Oct 12, 2020 at 4:12 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Geezus, for the love of GOD @Tundra234 turn on the key, take your meter, test your acc and constant power pins on your connector (to a good ground), and see if the radio is getting power as @Jim LE 1301 suggested.
    That way you'll know if it is a fuse or and internal issue with the Entune HU..
    If the Entune is bad, reconnect everything back to stock and take it to the dealership for warranty work,
  17. Oct 12, 2020 at 4:22 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Kung, Black Wolf, Patch999 and 2 others like this.
  18. Oct 12, 2020 at 7:51 PM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    There are two power sources for the 2020 HU. The 15A "RADIO" fuse from the battery and the 10A "ECU-IG1 NO. 4" fuse. They should be in the driver's side kick panel fuse block. I haven't looked at the 2020 Fuse data but that's where it was on the 2017-2019 trucks.
    Both power signals go to J202. The left side Gray 28-pin connector of the head unit. The 15A battery voltage is on Pin 4 (Lavender/Sky Blue wire) and the 10A IG power is on Pin 19 (beige wire). Here's the connector diagram. Hope this helps.
  19. Oct 13, 2020 at 4:37 AM
    Thank you for the input. I will take a look at it today. Hopefully it is the ECU-IG1 fuse, the radio fuse was good. I cant see frying the radio that easily.
  20. Oct 13, 2020 at 5:38 AM
    #50
    Rotaryphoneuser
    Rotaryphoneuser New Member
    Ontario. Canada
    2018 Cement CrewMax
    Hehehehee....he don't want to touch test light...lol.
    Kung, 1lowlife and Jim LE 1301 like this.
  21. Oct 13, 2020 at 5:40 AM
    #51
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    Is there a fuse on the back of the radio? Have you checked that one? Seems like if everything else is working it should be isolated to one of those three....
  22. Oct 13, 2020 at 5:42 AM
    #52
    There is not on the OEM radio.
  23. Oct 13, 2020 at 5:43 AM
    #53
    shawn474
    MoCo, Maryland
    Damn, well hopefully it will be the one you haven’t checked yet. If not, I gues it is safe to assume the radio is fried. I sold mine awhile back - otherwise I would have sent to you.
  24. Oct 13, 2020 at 5:51 AM
    #54
    blackoutt
    blackoutt YEAH BUDDY!
    Indy
    07 DC Long Bed - Old Man Tan
    OEM+
    This happened to me when testing to use the anytime backup camera harness on my wife's rav4 with the 360 view cameras. It's not compatible due to the multiple cameras and when flipping the switch it blew a fuse, whole radio was a no power up. The fuse was located in the kick panel although I don't remember which one, I do recall it not being what I thought it should be and hard to find. Start pulling more of them.
    Black Wolf likes this.
  25. Oct 13, 2020 at 5:57 AM
    #55
    Both of those fuses are good.
  26. Oct 13, 2020 at 5:58 AM
    #56
    Yeah I will have to pull all of them. The 2 that TundraTex mentioned are good.
  27. Oct 13, 2020 at 6:15 AM
    #57
    :rofl::rofl:
    jewsNbrews likes this.
  28. Oct 13, 2020 at 6:41 AM
    #58
    Problem solved. It was the 5 amp ECU ACC fuse. I did not turn the camera on to see if it blows or not. 20201013_085152.jpg :thumbsup:
    AZBoatHauler and blackoutt like this.
  29. Oct 13, 2020 at 6:47 AM
    #59
    :yes::bananadance::dancingbacon::broccoli::jellydance::kona::locked::taco::yay::woot:
    Now turn on the camera!
    blackoutt and jewsNbrews like this.
  30. Oct 13, 2020 at 8:36 AM
    #60
    blackoutt
    Indy
    OEM+
    Does the 2020 system have more than one camera? I'm assuming you stole this off your other truck. Curious to see what happens when you hit the switch now...
