What the hell is this???
Discussion in '2nd Gen Tundras (2007-2013)' started by ccress83, Oct 6, 2020.
  1. Oct 6, 2020 at 4:32 AM
    ccress83
    ccress83 [OP] Be A Good Human
    Colin
    Cleveland Ohio
    2011 Tundra CM TRD Off-Road Limited
    AFE Dry Drop in Filter, Morimoto XB LED Fogs , LED Taillights, Morimoto D2S retro w/profile HI-Lens LED Brights, 3/1 LRO Level, Dirty Deeds 8', TRD Rear Sway Bar,
    Anyone know the purpose of this pedal/switch? I have an idea after i hit it accidently a couple years ago not realizing it was really there and freaking out when my truck wouldnt start. I know older vehicles this would be the brights but from what I understand its a kill switch. Anyone know exactly what it does would be helpful. Thank you have a good day. Stay safe.
  2. Oct 6, 2020 at 4:35 AM
    cnoyes72
    cnoyes72 New Member
    CT
    2018 Tundra SR5 DoubleCab 4x4
    Driver-side assist handle, extang trifect 2.0 tonneau cover
    On some really older vehicles that floor switch could also be the starter.
    Black Wolf likes this.
  3. Oct 6, 2020 at 4:41 AM
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    12volt remote start, weathertec accessories, Trd Pro decals, Toyota console safe,VLEDS Puddle Lights,Frac Harness,TRD PRO front and Rear Sway Bar,NSV Hood Light Bar,ESP long box,AJT accessories,Thinkware U1000 dashcam, coachbuilder 1/3 Lift, HR LED’s,Pro comp Traction bars, JL complete System wit 2 10” subs, Kenwood DDX9907XR HU
    Cnoyes72 is right that was a high beam switch on old cars if I remember correctly possibly in the 70s popular with GM vehicles
    GODZILLA and Beesta like this.
  4. Oct 6, 2020 at 5:04 AM
    Ericbike6
    Ericbike6 So we're doing this shit today?
    Eric
    Austin, TX
    2019 Tundra TRD 4X4 sport
    Air bags, ARK liners, misc bullshit added also
    Some police departments will install them as a kill switch. Keeps people from borrowing their cars.
    West Texas Tundra likes this.
  5. Oct 6, 2020 at 5:30 AM
    Jerry311SD
    Jerry311SD New Member
    Jerry
    Ramona San Diego CA
    05 Tundra
    Looks like the switch for the high beams on my Nova
    GODZILLA likes this.
  6. Oct 6, 2020 at 5:49 AM
    It definitely looks like a old school high beam on off foot switch.
    If it is a kill switch it either breaks the positive or negative contact.
  7. Oct 6, 2020 at 5:52 AM
  8. Oct 6, 2020 at 5:53 AM
    Old school high beam switch, had that on my '80 Ford truck
  9. Oct 6, 2020 at 5:53 AM
    Yep 85 f150 I drove, had it there
  10. Oct 6, 2020 at 5:56 AM
    This truck I drove was a full size Ford, but it was a Ranger, single cab, rear sliding window, dual tanks, small block V8
    YardBird likes this.
  11. Oct 6, 2020 at 6:02 AM
    tech1208
    tech1208 Old Salt, New truck
    Orlando, FL
    2023 Tundra Platinum 4X4 Blueprint Blue
    Just like in my 68' GTO.
    YardBird, GODZILLA, bleach and 3 others like this.
  12. Oct 6, 2020 at 6:13 AM
    ndg2e
    ndg2e New Member
    Mt. Juliet, TN
    2017 Tundra 1794 4x4 CM SW
    4-Inch Lift, Fuel 20” Wheels, Nitro Ridge Grappler 35” Tires, Fender Flares, Rigid Fog Lights, LED Headlights, Spyder Taillights, VLED LED Interior/Exterior, TRD PRO Grille, Hood Bulge, Grille Surround, Black Out Emblems/Door Handles/Mirror Caps, Robin .50 Antenna, AJT Interior Blackout Kit, Bullydog BDX Tuner, Smittybuilt Tactical Seat Cover, Tuffy Safe, ARB Rear Differential Breather, Husky Floor Liners,Line X Spray-In Bed Liner, TRD Dual Exhaust, TRD Rear Sway Bar, Remote Start, TRD Front Skid Plate, Hood/Fender Paint Protection Film, and TRD Shift Knob
    Should be High Beams switch
  13. Oct 6, 2020 at 6:14 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Star, Idaho
    TRD Lowered and Supercharged
    Prior owner most likely added the high beam headlight switch as an ignition kill switch.
  14. Oct 6, 2020 at 6:22 AM
    ccress83
    Colin
    Cleveland Ohio
    Its definitely a kill switch of some kind. If I push my emergency brake in I hit it. And when I try to start truck again all my electric turn on it just doesnt turn the engine. But like why is it in my truck. I have a 2011. Im not that old at 37 so I never drove a vehicle with it but I remember my parents vehicles having them on their cars and usually it was brights. Ill have to check my dads 64 mustang and see if he has it on his. Thanks for the input, I just want to know if anyone else has this in their tundra.
  15. Oct 6, 2020 at 6:33 AM
    ezdog
    ezdog New Member
    Gateway To The West
    2001 RCLB V8,4WD 2015 RCLB 5.7,4WD
    Because some goofball who had the truck before you thought they needed it there?
    You know it is a Kill Switch it sounds like and if you dont like it or want it there then just move it or remove it!
  16. Oct 6, 2020 at 7:13 AM
    greghoro
    greghoro New Member
    Greg
    2012 Sequoia Limited
    Not factory. From the way the carpet is cut, obviously a one-off customization.
    As to why, only the installer knows for sure.
  17. Oct 6, 2020 at 11:37 AM
    MilesToEmpty
    MilesToEmpty New Member
    Charles
    2007 DC 4x4 Linited
    If the parking brake hits it, maybe they installed it as a kill switch for the ignition for security. Someone looking to steal a Tundra would probably have the means to do so, then be deterred when it wouldnt start.
    Adjust your parking brake so it doesnt go down as far? I keep might tights to it only presses down 2-3"
  18. Oct 6, 2020 at 12:31 PM
    spn4125
    spn4125 New Member
    If the parking brake triggers it maybe the previous owner's wife had the habit of not disengaging the parking brake before speeding away and he got tired of replacing pads. If the brake is engaged truck no start.
    RainMan_PNW likes this.
