Blackstone ATF Report!!!
Discussion in '2.5 Gen Tundras (2014-2021)' started by Greg Marmalard, Oct 1, 2020.
Thread Status:
Not open for further replies.
  1. Oct 2, 2020 at 8:09 AM
    Tundrafan23
    Tundrafan23 New Member
    Because in 2019 when Toyota was forced to change to new AC refrigerant they were also forced to change to a new condenser. The atf cooler and ac condenser were integrated on the 10-18 Tundras, in 2019 when the change was made to new refrigerant and condenser Toyota further tested the need for a stand alone atf cooler. They found that with the advances made in ATF fluid since 2010 that a stand alone cooler was no longer needed. So to put it simply, atf fluid has advanced enough in the last 10 years that a cooler is not needed anymore.
  2. Oct 2, 2020 at 8:40 AM
    timsp8
    NY
    Yes I know about the condenser and new refrigerant. Can you provide the documentation that “Toyota further tested the need for a stand alone atf cooler. They found that with the advances made in ATF fluid since 2010 that a stand alone cooler was no longer needed”? I think we would all like to read up on that.
    Also, I mentioned the fluid before and was told it’s the exact same since 07. Can you also provide the documentation that they changed the formula and that it’s more advanced now? My understanding was that they would not release specifics as it’s proprietary. I think we’d all like to read about that too.
    Check posts 96 and 97 in the below thread. There’s more to it than just the fluid.
    https://www.tundras.com/threads/transmission-temperatures.43046/page-4#post-1927848
  3. Oct 2, 2020 at 8:44 AM
    19crewmaxTRD
    19crewmaxTRD Tundra Enthusiast
    Seth
    2019 white tundra crewmax
    If that was the case wouldn’t Toyota spec different transmission fluid for the new truck as compared to what they spec’d for the old trucks? I don’t know what Toyota considers normal practice when updating fluids but I think if they made that big of a change in the transmission fluid I would think it would have been noted our called WS2 or something.
  4. Oct 2, 2020 at 8:56 AM
    19crewmaxTRD
    Seth
    Another observation, I’ve been driving my dads 2013 tundra around the last 3 days while my truck was in the shop and they definitely changed the shifting behavior of the trucks. My truck definitely seems to favor lock up a lot more than his truck does. For instance when passing on the freeway under moderate throttle my truck holds lock up his truck doesn’t.
    Example- I’m cruising at 75 and push to 85 at around 25% throttle my truck stays in 6th locked his truck would stay in 6th but unlock.
    Another observation- my truck would downshift to 5th and lock up over moderate hills his truck would stay in 6th and unlock.
    this might just be from different learning done by the transmission computer, or it might. Be a strategy by Toyota to manage temps. Idk so take that for what it’s worth
    Coffee*8), GODZILLA, TTund16 and 2 others like this.
  5. Oct 2, 2020 at 9:03 AM
    blanchard7684
    blanchard7684 New Member
    toyota is on record saying shift mapping changes supported removing the additional cooler.
    your experience matches mine.
    my 19 chases lock up line a fiend.
  6. Oct 2, 2020 at 9:15 AM
    Blue Thunder
    Washington
    Don’t forget this is the factory fill, so the wear metals will be higher than average just from the break-in cycle. Plus, it is just an average. By definition some counts will be higher, yet normal.
    Yes, lots of people thought the fluid was toast. Quite a few chicken littles on this topic
  7. Oct 2, 2020 at 9:20 AM
    4WDWalrus
    4WDWalrus New Member
    The Silver Walrus
    TRD shift knob OEM Fender Flares Truxedo Pro X15
    Question remains, was the OP fluid the same fluid done in the analysis. More to come...
  8. Oct 2, 2020 at 9:21 AM
    19crewmaxTRD
    Seth
    That makes me happy I installed a cooler. I work in automation (Mostly plc programming of machinery) and I’m always asked to make poor quality equipment work better, my response is “I can make bad equipment work better with a good program, but I can never make it work as good as good equipment”
  9. Oct 2, 2020 at 10:05 AM
    Great base results! I want to tell you personally thank you for taking the time and effort to research/test this cooler issue and probably put plenty of people’s worries to rest.
    18k miles is not a lot, and the weight was decent. Hopefully if you keep going with the testing, the results stay the same.
    I did my 2012 Tundra at 60k, and that made we question if I should have done it sooner.
    Thinking about making this thread a sticky so everyone can see this easily. What do you think?
  10. Oct 2, 2020 at 10:10 AM
    knoxville36
    knoxville36 New Member
    Knoxville, TN
    2024 GMC Sierra 1500 Elevation w/3.0 Duramax
    I think that would be a great idea!
    2 things that would be important to this:
    1. We need to do an analysis on an unused Toyota ATF WS fluid. I would be curious to see it in unused stock form. Get a baseline of add package, viscosity, flash point, etc....
    If no one volunteers, I would be happy to get a quart and pay to have it shipped to Blackstone.
    2. We need another one ran with more miles. I have 49,500 on my 2019 Platinum but they have been pretty easy miles, rarely pulling a trailer.
  11. Oct 2, 2020 at 10:23 AM
    19crewmaxTRD
    Seth
    My truck has 52,xxx miles on it and I’m going to do a drain and fill at 55, mostly highway with some towing mixed in everything from 1000lbs to north of 8000. I also happen to have a Blackstone sample kit from my land cruiser I never used. It will be around the end of the month before this happens.
    tttrdpro, GODZILLA, TTund16 and 4 others like this.
  12. Oct 2, 2020 at 11:06 AM
    19crewmaxTRD
    Seth
    The only issue is I installed my cooler at 48,000 miles and added 1 1/2 quarts of fresh atf, so that will tant my sample.
    GODZILLA likes this.
  13. Oct 2, 2020 at 11:44 AM
    Tundrafan23
    There is no documentation that I know of, I am just by the word of Mike Sweers who stated that Toyota did extensive testing at Davis Dam after the cooler was removed and found that the temps were still well within spec.
    Jtundra81 likes this.
  14. Oct 2, 2020 at 12:56 PM
    brokeboater
    brokeboater New Member
    North Florida
    2006 Ram 3500
    Thanks to everyone's opinions on both threads. I drive an older 5.9 Cummins Ram and have shopped hard looking for a potential replacement. So far I haven't found anything that makes upgrading to something newer justified, IMO, but the Tundra is the only one that tempts me. My truck is a four speed and it suits me just fine. I like the thought of the 6 speed on a Tundra, more without getting overly complicated. When buying my 5.9 a big draw was that it had been out and proven a long, long time. I feel the same way about the "antiquated" 5.7 Tundra with it's 6 speed tranny. I'm going to wait and see if they don't ad some cargo capacity in 2022 that would tip the scales in favor of upgrading trucks to me. Going from 3,300+#s of payload to sub 2,000 is a hard one to take. Anyway, thanks all, I'm feeling good about the Tundra 6 speed now, as is, no cooler needed for my wants.
    Leo's first likes this.
  15. Oct 3, 2020 at 8:49 AM
    Greg Marmalard
    Greg Marmalard [OP] New Member
    2019 Tundra TRD Off Road Double Cab
    Sure...Sticky away!
    The numbers are pure Greek to me and I'd love to learn more. Still waiting to hear back from Blackstone...I'm sure I included the particulars so not sure how they missed it but they have them again...
    It still amazes me that the auto and ATF industry has been striving to keep temperatures under 200° and all of a sudden Toyota discovers 240°++ is just fine... Plus it's a obvious cost cutting measure with no benefit to the consumer.....
    BTW I know people are joking about Toyota having some hand in the results but note Blackstone "lost" the particulars and has no clue what the sample came from as far as their response indicates....
    Bammer and ColoradoTJ[QUOTED] like this.
  16. Oct 3, 2020 at 9:38 AM
    Stickied:)
    The thinking is from 30+ years ago with 200*...but I still try to keep mine transmission at or under this temperature. Now I have a totally different transmission and cooling system so these should not be compared. Oils have really improved over the years, and it's obvious in your findings.
    Here is a little more homework for you, whether you do it or not. I believe Dave @Vizsla did some research and stated the final lockup isn't until 257*...or something like that. I tagged him so maybe he can clarify. So, by running cooler temps than designed are the people running these aftermarket coolers not allowing the transmission to function as designed? Hummmmmm....
  17. Oct 5, 2020 at 3:36 AM
    Bammer
    Monroe, CT
    After doing a little search and pulling form my limited time with OBD/Fusion app, I have never seen 257° on the highway , most recently a 3 1/2 run to upstate NY. Unless I'm missing something about "final lockup" ?
  18. Oct 6, 2020 at 5:13 PM
    Greg Marmalard
    Here's Blackstone's revised report based on more details about my Tundra... Even better than the original...?
  19. Oct 6, 2020 at 5:46 PM
    glowblue
    glowblue From time to time
    VA
    Damn @Greg Marmalard - Mandy would be proud of your ATF! Excellent report.
    SomeGuy4, panicman, Sumo91 and 2 others like this.
  20. Oct 6, 2020 at 6:55 PM
    #50
    Redcon41318
    Redcon41318 New Member
    I called toyota corp in plano tx, this is what they told me.
    TTund16 likes this.
  21. Oct 6, 2020 at 6:56 PM
    #51
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    It has one.
    Once the ATF is higher temp than the coolant, heat is removed from the ATF into the coolant.
    The puck is dual function based off temp.
    They, the sticker, etc in reality did not lie. Just because you, the user, have a different "view" or definition is not Toyotas fault.
  22. Oct 6, 2020 at 7:07 PM
    #52
    TundraTXTSS
    TundraTXTSS New Member
    Conroe
    2020 White TRD Pro
    Window Breakage add on Alarm,Wireless Charger. Console Safe, Rear Dif Breather Relocation, Rear Under seat Storage, Hard wire for Radar Detector, Tonnneau Cover, Brake Sensor Protection,SABM with TRD Filter, Tailgate lock, BFG's, LED Running lights.D-3 Tuner.
    Thanks for the info, kinda makes you wonder about the head mechanics knowledge. Seems he better re-read his manual.
    glowblue likes this.
  23. Oct 6, 2020 at 8:20 PM
    #53
    Kanobi13
    Kanobi13 New Member
    Flash point is at 410?
  24. Oct 6, 2020 at 8:46 PM
    #54
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    This is great news, thanks OP for submitting your fluid for analysis. Seems we will need a bunch more heavy tows here with higher mileages to do this before we either relax, or continue the panic. Thanks again for the test.
  25. Oct 7, 2020 at 10:07 AM
    #55
    Bammer
    Monroe, CT
    My coolant temp yesterday 195.6° , atf pan 201°, TC 214° , it was 65° out . Held pretty steady for 25 - 30 minutes 35 t0 45 mph .
    Clemsonman14 likes this.
  26. Oct 7, 2020 at 1:02 PM
    #56
    Jtundra81
    Jtundra81 Just a member
    Joe
    2019 cement tundra crewmax
    Wow , I just checked one sticker online for 2021 and they no longer mention engine and transmission coolers.
  27. Oct 8, 2020 at 3:26 AM
    #57
    Bammer
    Monroe, CT
    My cooler should be getting installed in the next 2 weeks, and I'll have @ 18,000 miles and very little towing done. Is there interest if I get a sample sent to Blackstone to compare to Greg's??
    Greg Marmalard[OP] likes this.
  28. Oct 8, 2020 at 3:51 AM
    #58
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    Great test results. Scientific proof the new method of cooling is effective.
    Thanks!
  29. Oct 8, 2020 at 6:39 AM
    #59
    blanchard7684
    agreed on oil temp. The cooler has some fins on it. Otherwise it isn’t much bigger that the trans cooler.
  30. Oct 8, 2020 at 9:34 AM
    #60
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    You say that like Toyota is the only manufacturer nickle and diming us out of features... Take a look at the 2019-2020 Sierras for example.
Thread Status:
