02 Tundra rear end
Discussion in '1st Gen Tundras (2000-2006)' started by Mdovey86, Sep 30, 2020.
  1. Sep 30, 2020 at 10:24 AM
    Mdovey86
    Mdovey86 [OP] New Member
    2002 Tundra SR5
    Hello, first time post.
    I recently picked up a 02 SR5
    V6 2WD.
    The rear diff cover is leaking. I tried cleaning and using POR15, to no avail.
    So I was wondering what rear end I can swap with? Does it hVe to be a 3.4l 2WD rear end? Or can I use a rear end from a 4 wheel drive TundrA? Thanks.
    YardBird likes this.
  2. Sep 30, 2020 at 10:30 AM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
    Welcome aboard from SoCal.
  3. Sep 30, 2020 at 10:56 AM
  4. Oct 1, 2020 at 9:00 PM
    Mdovey86
    2002 Tundra SR5
    Thanks for the replies. Iam looking to replace the rear end. Iam not getting any definitive answers from the other thread.
    I was wondering if anyone knew what rear ends were compatible with the 3.4l 2 wheel drive model? Can I use one from a v8 model or a 4wheel drive tundra?
  5. Oct 2, 2020 at 5:45 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    you need to check your rear end ratio if you want the gear ratio to match. In theory, since you're 2wd, you can use any rear end you want. but you might not want to throw a 3.91 rear end from a v8 4x4 into your v6 if it came with 4.30s.
