IOS14 dropping calls on 2019
Discussion in 'Audio & Video' started by Jsnake89, Sep 28, 2020.
  1. Sep 28, 2020 at 10:45 AM
    Jsnake89
    Jsnake89 [OP] New Member
    Dane
    2019 Tundra TSS SR5 8W2
    Bilstein 5100 3/1 Pro Comp 1" Blocks, 12Volt Remote start.
    So I recently updated my iPhone XR to iOS 14. Ever since then now my truck 2019 tundra keeps dropping calls and losing connection with the Bluetooth. Can’t find anything in the forms about this yet seen if anybody else is having these problems also
    Devo816 likes this.
  2. Sep 28, 2020 at 12:36 PM
    Oats87
    Oats87 Dirt Rider
    Sunnyvale, CA
    A Non-Toyota
    Curious, do you have contact syncing enabled? I found huge reliability issues with the bluetooth on my truck when I had contact syncing enabled.
  3. Sep 28, 2020 at 12:37 PM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    I haven’t had an issue with 14, I’ve had it a couple weeks now.
    FWIW my phone updated to 14.01 last night, and I’ve been in the truck all day on the phone.
  4. Sep 28, 2020 at 12:45 PM
    Doctor Flex
    Doctor Flex Just browsing...
    Utah
    2020 White 1794 TRD
    TRD Pro skid, Line-X, Tonneau, drivers grab handle, wireless charger, RB 20's, TRD Pro wheels, Gator Liners.
    So I have a 2020, with the new head unit (so different than yours), and an iphone 11 on 14.0.1. I haven't had the issue thus far. However, if you haven't tried yet, delete your truck from blu tooth (disconnect) and disconnect phone from truck, reboot the phone, and try re-pairing to the truck and see. You may have done that already. If so, try also resetting network settings. Otherwise, you could try resetting the head unit in truck as well.
    Tchase and Clemsonman14 like this.
  5. Sep 28, 2020 at 2:37 PM
    Kung
    KG, VA
    All of this. I've had iOS14 literally since the public beta came out; and if anything it's been more stable than usual. The only time I've had disconnects is due to zero signal strength in the middle of nowhere in the Ozarks. LOL
  6. Sep 28, 2020 at 3:08 PM
    Clemsonman14
    Clemsonman14 New Member
    2020 SR5 Crewmax 4x2
    I got the old 6s creeping along on iOS 14 and haven’t had any issues since the update
    As one poster mentioned maybe try forgetting the device on both your phone and truck
  7. Sep 30, 2020 at 9:14 PM
    Jsnake89
    Dane
    Tired all these and still drops and hangs up on my caller. Called my dealer and the service depot was No help at all. Guess I’m rolling back my phone.
  8. Oct 1, 2020 at 2:02 AM
    RocknRoll
    RocknRoll I’ll make you famous
    DFW, TX
    2019 MGM TRD Sport 4x4
    5” lift, 37” Toyo R/T’s 20” Fuel AMP steps, Ceramic 20% Tint
    Another thing id suggest, if you use iCloud backup, is to back your phone up(make sure you've selected all your apps) then delete the phone and restore from backup. Apart from what's already been suggested, anytime I have an obvious issue, I will backup, delete, then restore from backup, and rarely do I find that doesn't fix my issue. I can't necessarily explain why its worked, but it has for me at least. I also have an iPhone 11 with the most recent software and have not had an issue. Good luck...
    Kung likes this.
  9. Oct 1, 2020 at 7:22 AM
    PeakIT
    PeakIT Old Member
    Utah
    2019 OR Tundra Double cab
    Coachbuilder 3” shackles, King extended travel, SPC upper arms, 5:29 gears, FN FX rims,35"tires, leer shell, grill
    Ive heard of tacomas radios locking up because of contact syncing. Turn it off. My 20Raptor did weird shit like turn the volume all the way up if I used it. My Tundra has the lowest version SR5 radio it works normally even with sync on with the newest iphone pro with newest ios update.
  10. Oct 1, 2020 at 8:27 AM
    idAg9010
    idAg9010 New Member
    2018 black cm TSS SR5 5.7
    Center console storage
    I think I am having a similar issue. All calls connected to truck Bluetooth seem to cut off after 2 min or so.
    Got new iPhone XS about two months ago. I didn’t notice an issue at first. I’ve since updated to iOS 13.7 and have not done the 14 update.
    anyone else having calls work fine initially and then drop after a little while?
    Tchase likes this.
  11. Oct 1, 2020 at 8:51 AM
    WellWater
    WellWater New Member
    2020 Tundra CM
    Slightly off topic, but I have a 2020 CM...have XR IOS 14. No issues at all, but I use carplay. In fact my bluetooth is not even synced.
  12. Oct 1, 2020 at 4:42 PM
    Cm2288
    Cm2288 New Member
    Ohio
    2021 TRD off-road crew max
    I had the same issues. I’ve actually found a fix for it. I deleted all Bluetooth profiles from my phone except the tundra and it hasn’t done it since.
  13. Oct 1, 2020 at 4:51 PM
    CaptainGrumpus
    CaptainGrumpus The Mailman
    Maine
    2018 Inferno Tundra TRD
    It has nothing to do with the truck. iOS 14 is having issues with bluetooth and wifi connectivity. I think you are just going to have to wait till 14.1 comes out in the coming weeks.
    https://www.forbes.com/sites/gordon...-you-upgrade-free-iphone-update/#62b2dcbd2d0c
  14. Oct 2, 2020 at 8:43 PM
    Thumper_6119
    Thumper_6119 I've seen things you people wouldn't believe.
    2011 Toyota Tundra SR5 Texas Edition (Crewmax) 4x4
    I was having connectivity issues between my Kenwood HU and my iPhone 11 after updating to 14. I removed the iPhone and HU from each others’ respective bluetooth profiles, re-paired them, made sure to not allow contacts to sync, and I’ve had no problems since. YMMV.
  15. Apr 1, 2021 at 12:01 PM
    kamurray5
    kamurray5 New Member
    2019 tundra
  16. Apr 1, 2021 at 12:05 PM
    kamurray5
    2019 tundra
    I’m having the exact same problem with same iPhone and dealer says it’s a compatibility issue with my phone. I’ve tried everything that i can think of other than back up phone and try erasing phone.
  17. Jan 25, 2022 at 8:33 PM
    Tchase
    Tchase MostlyLurk
    Buckley WA
    2019 White Tundra Limited
    In work
    I had an iPhone prior to the purchasing my 2019 limited. I always up date as soon as they are available. All the sudden for the last month (there have been two updates during that time) the Bluetooth disconnects call continues to show on display and it will stay like that for a while, then drop off the display. Mean time I’m fiddling with the phone trying to get speaker phone, feels dangerous .
    The last update did mention drop calls with CarPlay. And I swear it’s worse…
    anyways I just found your post so I’m going to start reading.
    PS I never had this problem prior, just started last month.
  18. Jan 25, 2022 at 8:37 PM
    Tchase
    Tchase MostlyLurk
    Buckley WA
    In work
    Being techie ‍♂️ I should of already tried this I will post back results in the morning
