CB Anteena cable routing?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Yangins, Sep 24, 2020.
  1. Sep 24, 2020 at 9:23 PM
    Yangins
    Yangins [OP] New Member
    Lue
    2015 crew max
    What ways are there to routing the CB antenna cable from the bed into the cabin?
    Search I couldn’t fine anything.
    SC_TRD likes this.
  2. Sep 24, 2020 at 9:39 PM
    SC_TRD
    SC_TRD Big BASTRD 4x4 Enthusiast
    Colin
    Round Rock, Tx
    2012 CrewMax & 2008 Sequoia
    https://www.tundras.com/threads/cb-radio-coax-cable-routing.65921/
    Here’s how the gromet looks as mentioned in the thread I posted above. I cut a little “pizza” slice out of it for my Coax to enter into the truck, as seen in my picture.
    EDIT:
    More pics
    I routed the cable inside the bed, above the bedside rail system. Looks really clean because I have a retractable tonneau that has rails above that as well.
    You need to remove this black plastic trim piece to get under the carpet in the backseat and then fish the cable out with your hands.
    I then pushed my cable out here at the base of the driver side chair and routed to where I needed it.
  3. Sep 24, 2020 at 9:43 PM
    BOBONTUESDAY
    BOBONTUESDAY Grocery Getter
    2016 Limited Trd
    I went through the back window just let it pinch in there super professional lol. Really helps with those swrs.
    betotundra and awq735 like this.
  4. Sep 28, 2020 at 2:38 PM
    Tundragrappler
    Tundragrappler New Member
    northeast
    2020 Tundra TRD Pro
    stock
    I used a homemade bracket for my 2m/440 ham antenna and routed the coax down the crack between the tailgate and the body. There was a small hole there that I could fit the cable and the reapplied connector through.
    Then I snaked it over the frame and cut a slit in the grommet/plug under the rear passenger floor behind the driver. Worked pretty well. Used cable ties to secure it underneath.
    24604B7A-2DBA-432C-9BA6-AAE2F83829F6.jpg 576A364B-5F6D-4B67-9479-4435D17FF551.jpg
  5. Sep 28, 2020 at 2:50 PM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    That’s where I brought mine into the cab, I just made an X cut in the middle of the plug and ran with it. Not the prettiest but it doesn’t leak!
    SC_TRD[QUOTED] likes this.
