CB Radio coax cable routing?
Discussion in '2.5 Gen Tundras (2014-2021)' started by awq735, Apr 23, 2020.
  1. Apr 23, 2020 at 5:35 PM
    awq735
    awq735 [OP] New Member
    Anthony
    Ohio
    2019 Tundra Sport, MGM
    For those of you who have installed a CB radio in your gen 3 Tundra, where did you have your coax cable enter the cab? I pulled off the rocker panel trim on the drivers side front door and rear door (double cab) and couldnt find any plugged/grommeted holes. The best I could find was routing it through the firewall, but I have the radio in my center console, and would like to go under the carpet if possible.
  2. Apr 23, 2020 at 6:29 PM
    There is a plug on the passenger side front door , look at the frame rail from the middle of the truck. It is right ontop of the frame rail. Hope this makes sense.
    Keegan C and awq735[QUOTED][OP] like this.
  3. Apr 23, 2020 at 6:32 PM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    Are you running the antenna at the rear or front of the truck?
  4. Apr 23, 2020 at 8:39 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Depends on where your antenna is...
    Mine are mounted to my truck box so I pulled one of the bed caps and cab caps then ran it up along the edge of my headliner. My radio is overhead.
  5. Apr 23, 2020 at 9:37 PM
    Hillbilly Taz
    Hillbilly Taz New Member
    Glenn
    AL
    2011 Tundra SR5 DC, Silver Sky, 4.6 L V8
    Westin Steps, Tonneau Cover, Vent Visors, Go Rhino Dominator Step, Husky X-act mats
    Have any pictures?
  6. Apr 23, 2020 at 9:45 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    There's a grommet under the truck, behind the front passenger seat. For some reason it's very difficult to see but it's bigger than a silver dollar.
    Sunnier likes this.
  7. Apr 24, 2020 at 1:10 AM
    awq735
    Anthony
    Ohio
    On the back eventually, most likely it will be mounted in the driver's side front stake pocket. Currently I have a magnetic one on the roof but am not a fan.
  8. Apr 24, 2020 at 1:12 AM
    awq735
    Anthony
    Ohio
    It does, thanks for the info.
  9. Apr 24, 2020 at 5:10 AM
    :hattip:
  10. Aug 22, 2021 at 10:39 AM
    Kgfit85
    Kgfit85 MR MRPH
    Kevin
    Jacksonville, TX
    2018 Tundra TRD Sport 4x4
    4” RC lift 35” Toyo 18” KMC Air ride bags for towing
    Once you remove that grommet, potentially with water crossing, won’t the water get into the truck with that grommet missing?
    831Tun likes this.
  11. Aug 22, 2021 at 11:39 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I drilled a hole then sliced the grommet and reinstalled with a silicone sealant.
    Kgfit85[QUOTED] likes this.
  12. Aug 22, 2021 at 11:42 AM
    Kgfit85
    Kgfit85 MR MRPH
    Kevin
    Jacksonville, TX
    Makes sense. I thankfully I have some of that! Thank you
    831Tun[QUOTED] likes this.
