  1. Sep 24, 2020 at 5:53 PM
    DID SOMEONE SAY REACHAROUND!?
    bmf4069 and bassman417 like this.
  2. Sep 24, 2020 at 7:06 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    im only 5'6" :anonymous:
    lsaami[QUOTED] and jImmegart like this.
  3. Sep 24, 2020 at 7:42 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    What??? But you sound like you’re 6’4”!
  4. Sep 24, 2020 at 8:26 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    My sister calls that "vertically efficient".
    Guess I shouldn't have said her basement ceiling was too low.
    bmf4069 and empty_lord[QUOTED] like this.
  5. Sep 24, 2020 at 8:31 PM
    BS. You're 5' 10 1/2".
  6. Sep 24, 2020 at 8:39 PM
    empty_lord
    05 rollover special
    I’m sorry. But I’m much more dashing than my voice-a-like
    NUDRAT, Darkness and bmf4069[QUOTED] like this.
  7. Sep 24, 2020 at 8:50 PM
    empty_lord
    05 rollover special
    things stop growing once they've reached perfection.
    im just better earlier than all yall!
  8. Sep 25, 2020 at 6:22 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I always think of this when I see shorter people, especially one of the directors at my office because he fits this description so well.
    "He was short but he didn't seem short, you know those people who are so confident its as if they chose to grow low" :D
    artsr2002, bmf4069, CodyP and 2 others like this.
  9. Sep 25, 2020 at 8:11 AM
    Kongap
    Kongap New Member
    2004 SR5 DC
    “Today,” I :censored: a brake line fitting.
    Darkness likes this.
  10. Sep 25, 2020 at 8:13 AM
    ktundra
    ktundra rust be damned
    Lex
    NJ
    06 Tundra DC Limited 4WD
    Bilstein 5100
    Easy peasy to replace... I just did this over last weekend. Lemme look up the part, that's the passenger side front, correct?
  11. Sep 25, 2020 at 8:15 AM
    Easy to replace....once he gets it out of that caliper. He's gonna need heat, kroil, and a prayer.
    bmf4069, Darkness and Kongap like this.
  12. Sep 25, 2020 at 8:16 AM
    Kongap
    Kongap New Member
    2004 SR5 DC
    473150C020
    Thanks! Ordered one already! It really helps if you use the right tool, right? :lol:
  13. Sep 25, 2020 at 8:16 AM
    Professional Hand Model
    Fred
    Hand Protectors
    We call this... ‘Mangling’ around here. Family friendly.
    bmf4069 and Kongap[QUOTED] like this.
  14. Sep 25, 2020 at 8:17 AM
    empty_lord
    05 rollover special
    Cut the line at the fitting (clamp the rubber like to prevent leakage) and they come right out with an impact 90% of the time. The one on the flexible line you need to be a bit more careful but also usually comes off easily with an impact if you grab hold of the metal to keep it from spinning
    NUDRAT, bmf4069, Darkness and 3 others like this.
  15. Sep 25, 2020 at 8:18 AM
    Kongap
    Kongap New Member
    2004 SR5 DC
    I was tempted to cut it off multiple times
    Eventually got it out with liquid wrench and a good grip with my vice grips
  16. Sep 25, 2020 at 8:34 AM
    ktundra
    Lex
    NJ
    Bilstein 5100
    Amazinlgy cheap factory part, $10.57 list price, $7.xx from Roman.
    NUDRAT and Kongap[QUOTED] like this.
  17. Sep 25, 2020 at 8:35 AM
    ktundra
    Lex
    NJ
    Bilstein 5100
    Would you clamp high performance SS braided hoses?
  18. Sep 25, 2020 at 8:40 AM
    Kongap
    Kongap New Member
    2004 SR5 DC
    When I ordered it over the phone, the parts guy said $20something for whatever reason. Thank goodness for the internet: $10.04 at that stealership.
    who is this Roman fellow and where can I get cheap OEM parts?!
  19. Sep 25, 2020 at 8:54 AM
    ktundra
    Lex
    NJ
    Bilstein 5100
    He's with Toyota of Cool Springs, which is a supporter of this forum.
    https://www.tundras.com/forums/toyota-of-cool-springs-parts.87/
    Kongap[QUOTED] likes this.
  20. Sep 25, 2020 at 9:08 AM
    empty_lord
    05 rollover special
    Oh... well if their stainless no. Rubber yes. Stainless the best bet is having the brake pedal pinned to the floor and nothing will dribble out
    Darkness and ktundra[QUOTED] like this.
  21. Sep 25, 2020 at 9:15 AM
    ktundra
    Lex
    NJ
    Bilstein 5100
    Hmm, I would think the fluid would come blasting out if you push the pedal all the way down. How does that work?
  22. Sep 25, 2020 at 9:17 AM
    empty_lord
    05 rollover special
    You pop the bleeder. Get a stick or something and hold the pedal to the floor. Fluid will come out when you hit it so use a hose to direct it. Then just leave the pedal to the floor. It will not allow more fluid to dribble out of the lines. This is actually how Toyota tells us to do it.
    NUDRAT, oscardog86, bmf4069 and 2 others like this.
  23. Sep 25, 2020 at 9:21 AM
    ktundra
    Lex
    NJ
    Bilstein 5100
    Thanks @empty_lord! Another tip to add to our ever expanding bag of tricks. :D
  24. Sep 25, 2020 at 9:23 AM
    empty_lord
    05 rollover special
    When I get a chance I’ll see if I can find the PDF of the exact procedure
  25. Sep 25, 2020 at 9:27 AM
    ktundra
    Lex
    NJ
    Bilstein 5100
    I was always careful not to put the pedal all the way to the floor with a helper pumping the brakes for bleeding, to avoid breaking the master cylinder.
  26. Sep 25, 2020 at 9:41 AM
    empty_lord
    05 rollover special
    That is one issue that can arise. But it’s also pretty rare to actually happen.
    ktundra[QUOTED] likes this.
  27. Sep 25, 2020 at 10:32 AM
    Fred
    Hand Protectors
    Seal Packing arrived. Looks to be supplied by ThreeBond whom I called last week and they never returned my call inquiring about their products. Glad I didn’t hold my breath.
    FrenchToasty, bmf4069 and ktundra like this.
  28. Sep 25, 2020 at 11:11 AM
    Fred
    Hand Protectors
    Pre-game on tomorrows next moves. 2nd Flush from yesterday and 3rd Distilled Water Only Fill look good today. This pour is from the overflow as a sample. I’ll drain it one more time and fill with distilled tomorrow. Put a sample dab of the Seal Packing on the old thermostat for grins and threw it in the water. :D Half in and half air exposed.
    @empty_lord how long before you can drive after using the 1282B on the water pump flange?
    hammeron and shifty` like this.
  29. Sep 25, 2020 at 11:14 AM
    Why do I feel like I'm waiting on a major sporting event or something with this upcoming TB change out? Anyone else?
    06yotamike, Lil Steve, CodyP and 2 others like this.
  30. Sep 25, 2020 at 11:17 AM
    What's the ETA on completion? Looks like you're about to the point of reassembly?
