New lower ball joints, now this...
Discussion in '1st Gen Tundras (2000-2006)' started by Baller, Sep 19, 2020.
  1. Sep 22, 2020 at 4:37 PM
    Baller
    Baller [OP] New Member
    '05 Tundra SR5 DC
    This is the unit bearing I was talking about. A completely painless swap. These bearings, on the other hand, are a PITA.
    Darkness[QUOTED] likes this.
  2. Sep 22, 2020 at 5:19 PM
    Baller
    '05 Tundra SR5 DC
    Alright, I'm going to take the spindles in and have someone else do the pressing. I may get roasted here, but I'm going to ask anyways. Any reason I shouldn't reuse the hub? I'm thinking of going with OE Toyota bearings, new seals and reuse everything else.
    Go ahead. Roast away. :cheers:
  3. Sep 22, 2020 at 5:25 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I reused my hubs. I got new bearings, dust covers, the weird nut they need for 2wd (might not need for 4wd) and I think there was a seal.
    YardBird likes this.
  4. Sep 22, 2020 at 6:03 PM
    SouthWestGA
    SouthWestGA New Member
    2007 Tundra CrewMAX and 2014 Nissan NV3500 Passenger
    Yes get new weird nuts
    it might be coincidence or not but my dad didn’t do that and his replacement bearings went bad a few thousand miles later
  5. Sep 23, 2020 at 4:04 AM
    I got the hub/bearing kit off RA, but I don't drive mine much. It comes with new axle nuts for 4wd, and all the dust seals. I also have over 300k so I figured it wouldn't hurt to change the hub, but I don't think it's necessarily a wear item.
  6. Sep 23, 2020 at 11:33 AM
    Baller
    '05 Tundra SR5 DC
    What's RA?
  7. Sep 23, 2020 at 11:35 AM
    Baller
    '05 Tundra SR5 DC
    Just called a local shop and they quoted me $45 per upper ball joint and $75 per bearing and hub. If I'm going to have the spindle out, I might as well do the upper ball joint also.
    912, bmf4069, Darkness and 1 other person like this.
  8. Sep 23, 2020 at 1:37 PM
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    Rock Auto
    bmf4069 likes this.
  9. Sep 23, 2020 at 1:56 PM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    Looks like you have a game plan.. :cheers:
  10. Sep 23, 2020 at 2:15 PM
    Baller
    '05 Tundra SR5 DC
    Thanks. Just ordered my stuff from A1 Auto. I've found quite a few of their youtube "how to" videos quite helpful, so I feel good about sending some money their way.
  11. Sep 23, 2020 at 2:19 PM
    N84434
    Milwaukee WI.
    2001 Limited TRD
    Ive done the same thing... Good company
  12. Sep 23, 2020 at 3:12 PM
    Baller
    '05 Tundra SR5 DC
    Called a local-ish 4x4 shop and he quoted me $80 a side. Owner is a pretty good friend of a dude I work with. I'll be driving a bit further to have the job done. It'll save a little cash, but I know it will be done right. I didn't name drop the dude I work with. Maybe I will when I get to the shop to drop off the spindles. Could end up in a little more savings. If not, it's still a win.
    Darkness and Lil Steve like this.
  13. Sep 23, 2020 at 5:10 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    The upper ball joints really aren't bad if you have the right tool, but for that price, it's not a bad deal.
  14. Sep 23, 2020 at 6:17 PM
    What's the right tool?
  15. Sep 23, 2020 at 8:03 PM
    N84434
    Milwaukee WI.
    2001 Limited TRD
    bmf4069 likes this.
  16. Sep 23, 2020 at 8:05 PM
    Lil Steve
    Gilbert, AZ
    A ball joint press. When I replaced my Ford van ball joints I was able to get rent/borrow it from my local Auto Zone. You leave a deposit and upon returning the tool you get your deposit back.
  17. Sep 23, 2020 at 10:00 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Rent a ball joint press and get the right adapter. The biggest problem is having very little room to work with the fender in your way, no room to turn a long wrench. With the spindle off and in a vise it should be easy.
    Then again for a little cash, have it done and spend that time drinking a beer instead of chasing tools.
  18. Sep 23, 2020 at 10:06 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    I typically reused the hub unless damaged by a failed bearing (or someone’s botched removal of the inner race.)
  19. Sep 24, 2020 at 5:26 AM
    I tried that one last year. In the past someone linked a tool made specifically for Toyota ball joints that was supposed to work well.
    That is exactly the issue I had. The tool was too big for the job(that's what she said?). Someone said they were able to disconnect the brakes and swing the spindle out of the wheel well. But you're right about it being much easier with the spindle completely out of the truck.
  20. Sep 24, 2020 at 10:02 AM
    #50
    rock climber
    This is what I used. Made it so much easier I disconnected the ABS line to move it out far enough to get the ball joint press in
  21. Sep 24, 2020 at 11:14 AM
    #51
    That was me. Maybe. I used the kit @N84434 showed to pop the UBJ and spindle apart since a sledge wouldn't break it. You have to swing the caliper to the other side, the hold the clamp upside down with a split cup straddling the spindle, and one of the plates on top. Then you hit the draw stud with your impact. Boom, spindle pops loose.
    N84434 likes this.
