What happened to my brakes?
Discussion in '1st Gen Tundras (2000-2006)' started by craftypaws, Mar 5, 2017.
  1. Mar 5, 2017 at 9:47 AM
    craftypaws
    craftypaws [OP] New Member
    syl
    2006 Tundra
    I was hauling a utility trailer just turned off hwy and breaks went to floor but did pump up, made it to friend home unhooked trailer with electric breaks and had no more break problem, drove to mechanic shop asked him what that could be ,he said must be coming from trailer, so how could that be , never had that happen before? so drove 3 miles just pulled into a driveway real slow no bumps in road and left wheel fall off lower ball joint so my question is could that be why I lost my breaks ? from loose ball joint or other problem? I just had a bad feeling some thing was going to happen, But love my tundra anyways
    T-Rex266 likes this.
  2. Mar 5, 2017 at 10:10 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Sorry to hear about your brake problem. Brakes are no joke. Anyways, welcome to the forum from Las Vegas!!
  3. Mar 5, 2017 at 10:17 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome from Colorado. Sorry about the brakes, but glad you had no issues stopping.
  4. Mar 5, 2017 at 10:21 AM
    Welcome from CO! Master cylinder fail?
    Bob likes this.
  5. Mar 5, 2017 at 10:24 AM
    :worthless:Bienvenidos! Your truck is a him???
    gosolo likes this.
  6. Mar 5, 2017 at 10:24 AM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    My guess is the trailer had nothing to do with your brake problem. The brake problem and the wheel problem, could be related, but I wouldn't make that assumption. Just tackle one problem at a time, and any such connection will become self evident.
    TheBeast, ColoradoTJ and gosolo like this.
  7. Mar 5, 2017 at 11:20 AM
    Motor71
    Motor71 teufel hunden
    Rob
    New Jersey
    2016 tundra platinum
    TRD sway bar, matching mirror cover, 20% tint, esp aluminum box, Line-X premium, Undercover Flex tonneau cover, led interior lights, winjet smoked tail lights. Road armor rear bumper w/ road armor shackles, go rhino front bumper.
    Welcome!
  8. Mar 5, 2017 at 11:33 AM
    craftypaws
    syl
    2006 Tundra
    Thank you all for your comments master cylinder is fine no lost fluid but i feel it was a goat break thing like a warning from above to get checked out now! so strange I think its just so strange how could the breaks work just fine, after unhooking trailer ? it should have nothing to do with the trailer unless you had air or a leak
  9. Mar 5, 2017 at 11:37 AM
    thumper7799
    thumper7799 Bad Girls Drive Bad Toys!
    Erika
    2007 Nautical blue Tundra SR5 duel exhaust
    Welcome from Texas!
  10. Mar 5, 2017 at 11:42 AM
    Thegr8punkin
    Thegr8punkin A G.D.M/Sofa King Cool/COTJ's dreamboat
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
  11. Mar 5, 2017 at 11:42 AM
    thumper7799
    Erika
    lol right! When you don't have a man to help you...
  12. Mar 5, 2017 at 11:46 AM
    craftypaws
    syl
    2006 Tundra
    yes I just asked my mechanic a few days ago to check the front end guess I need a new mechanic I always keep up on maintenance but what are you to do when he did not check my truck out real good and tells me nothing wrong with my truck . I guess when you get that gut feeling try try again
    thumper7799 likes this.
  13. Mar 5, 2017 at 11:46 AM
    Thegr8punkin
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
    Master cylinders can also leak internally. The sign for that is it'll be wet near where I'd goes in the cab.
    And I'm spit balling hear, but possibly something with the break booster?
    GNTundra likes this.
  14. Mar 5, 2017 at 11:48 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Welcome. Gino's got some good advice there, start looking for fluid leaks as he indicated. I don't think the ball joint was separate issue from the brakes.
    GNTundra and Bob like this.
  15. Mar 5, 2017 at 11:51 AM
    craftypaws
    syl
    2006 Tundra
    see no leaks why are breaks working fine now that I unhooked my utility trailer with electric breaks
  16. Mar 5, 2017 at 11:52 AM
    craftypaws
    syl
    2006 Tundra
    if wheel was loose would that make the break booster act up?
  17. Mar 5, 2017 at 11:55 AM
    Thegr8punkin
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
    No not really. I'd start by fixing that ball joint and the do some test drives and go from there. It's very possible that you just got crappy luck that day and every thing went out at the same time
  18. Mar 5, 2017 at 12:03 PM
    craftypaws
    syl
    2006 Tundra
    no dash lights on
  19. Mar 5, 2017 at 12:06 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    There is no connection between your truck's hydraulic brake system problem and the electric trailer brake system. Are you certain it was the lower ball joint that failed, and not the wheel bearing? A wheel bearing with play in it will cause the braking symptoms you describe, but rear shoes out of adjustment, or an internally bypassing master cylinder could be the cause too. You could have two separate issues, or it could be related.
    ColoradoTJ and GNTundra like this.
  20. Mar 5, 2017 at 12:07 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    A picture or two of the offending area could clear things up nicely.
    Thegr8punkin likes this.
  21. Mar 5, 2017 at 12:09 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    And yes, find a different mechanic. The guy you are dealing with sounds clueless.
  22. Mar 5, 2017 at 12:12 PM
    craftypaws
    syl
    2006 Tundra
    the wheel fell off ball joint got both fronts done, thank you all for your help
  23. Mar 5, 2017 at 12:12 PM
    thumper7799
    Erika
    I completely agree @craftypaws . I rely on what a mechanic tells me too. When you don't know; you don't know....I pay a bit extra and take it to a dealership because I don't have a choice. Some people on here may think that's ridiculous and a waste of money but shit; as far as I know, everything has always been diagnosed and fixed correctly.
    blue16, GNTundra and Thegr8punkin like this.
  24. Mar 5, 2017 at 12:14 PM
    Like you need one....
    thumper7799[QUOTED] likes this.
  25. Mar 5, 2017 at 12:16 PM
    thumper7799
    Erika
    lol...well...:crapstorm:
  26. Mar 5, 2017 at 12:22 PM
    craftypaws
    syl
    2006 Tundra
    I was thinking maybe the wight I had on the trailer put pressure on front end and tugged at the break connection when the wheel was loose , anyway tomorrow I take it in for allignment I will have them ch the rear breaks, Thank you all
  27. Mar 5, 2017 at 12:22 PM
    I would say master cylinder as well. What you discribed are symptoms of one starting to fail. Like @landphil suggested, make sure the rear shoes are adjusted properly. The brake system on a first gen is already taxed, and anything not adjusted properly or failing really is noticeable.
    The utility trailer made your brake system show you something is wrong. Hope you had trailer brakes.
  28. Mar 5, 2017 at 12:23 PM
    thumper7799
    Erika
    lmao! I'm down with that!
    ColoradoTJ likes this.
  29. Mar 5, 2017 at 12:24 PM
    Thegr8punkin
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
    No problem bud, and welcome to the forum. Fair warning though. There is a good chance that this will turn into a bs thread here soon. We got 3 of the heavy hitters here now so this will probably go off the rails quick. Lol
    GNTundra and thumper7799 like this.
  30. Mar 5, 2017 at 12:24 PM
    You ready in 7 years?
    Hell, I just talked to a commercial camper hauler today and I could see my ass doing that for a bit.
