Let’s see your front lawn skills
Discussion in 'Home Improvement' started by Mountun Goat, Jun 25, 2018.
  1. Sep 17, 2020 at 8:04 PM
    #181
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    DAP Tune ESP Storage RCI Skids Icon Rebound ABS Guards AVS Vent Visor FRAC Harness 50 Cal/Antenna X BFG KO2 HID Extra Light Bar White Knuckle Off Road Sliders BAK Industries Revolver X2 Oh Shit Handles Pop and Lock LED Internal and Reverse Lights LED Footwell lights Tuffy Storage Console organizers Viper Alarm and Remote Start
    silver cymbal on YouTube has a good formula
    Baja Mike[QUOTED] likes this.
  2. Sep 17, 2020 at 8:16 PM
    #182
    Trooper2
    JR
    Houston, TX (Suburban South)
    Sometimes a kill and re-sod is the quickest solution.
    Mountun Goat[OP] and Dalandshark like this.
  3. Sep 17, 2020 at 8:40 PM
    #183
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    Sure hope it's this one because I just ordered all of it. lol
    porkitt[QUOTED] and jewsNbrews like this.
  4. Sep 17, 2020 at 8:43 PM
    #184
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level LIft
    PBI Gordon Q4.
  5. Sep 18, 2020 at 3:34 AM
    #185
    PermaFrostTRD
    Northern NY
    about 8 acres w/ a 52” gravely zero turn that’s 18 years old. Will be upgrading this spring to at least a 72” with some suspension. Due for a good dethatching too.
    Nice lawns everyone.
    saybng, CCLJ03, Dag3 and 15 others like this.
  6. Sep 18, 2020 at 5:42 AM
    #186
    Charvonia Design
    Charvonia Design Enthusiast-Owned Small Business Vendor
    Keith
    Huntersville, NC
    2024 Tacoma TRD OffRoad Bronze Oxide
    Oh it works, the question is if it will come back. I used generic Tenacity called Meso 4SC last year, only one application, and it killed the crabgrass. Then I let the crabgrass get out of control over the summer again, huge mistake. I just sprayed the Meso again, and am really wondering if I can get a healthy fescue lawn this Fall that will not allow enough space for the crabgrass to come back again. Also I skipped pre-emergent last year, and will definitely not make that same mistake twice!
    My neighbor who has a beautiful lawn is recommending I rent a sod cutter and pull the entire front yard up then sod it. Well, it's not his money to spend and it would be over $1000 to do that so I'm really not sure I want to go down that path even though it would give immediate results.
    Local experts at SuperSod say to let the crabgrass go dormant, plant Fescue seed now, and use a pre-emergent in the spring. This would be much easier on the wallet, and is likely the path I'll take.
  7. Sep 18, 2020 at 8:46 AM
    #187
    Mountun Goat
    Mountun Goat [OP] She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    I notice some crab grass coming into my yes too, I’m just gunna sell haha
    jewsNbrews likes this.
  8. Sep 18, 2020 at 6:32 PM
    #188
    Baja Mike
    South Bay, Ca.
    So here is my “lawn”. Other that the one piece of sod near the wood chips and porch, and the odd spot where I put some seed down, everything is crabgrass. 4B993028-7247-4DFF-B98E-12FD6FA65568.jpg
    long story short, I thought is was regular grass. How wrong I was. I want to go scorched earth and dig it all up, but as you can see in the lower left of the pic there is a sprinkler system, which doesn’t work and I have no idea where it’s plumbed. So chemical death is my (laziest) option. Probably won’t even plant grass for another year or two to see how bad this stuff comes back after I hit it with the Tenacity. The crabgrass has infiltrated the wood chip planter up against the garage and porch. So after discussing with the gf we decided to pull all that up too. It’s jasmine and kangaroos paw/ cats paw (???) and they just fight each other. So death to them as well.
  9. Sep 18, 2020 at 6:43 PM
    #189
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    I try to understand those who enjoy yardwork, but I guess I did so much of it growing up I get no pleasure whatsoever from it. So when I found someone I could pay $60 per cutting (and trimming and edging and blowing) I jumped on it. They do the whole thing in less than an hour. I took me four hours, not including cleanup, when I was doing it myself. My personal belief is that my time is worth more than $15/hr at this stage in my life. All that said, there are some very nice looking yards in this thread!
  10. Sep 18, 2020 at 6:44 PM
    #190
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Rent a slit seeder aka overseeder, blue bird is the common brand name. Use a good seed blend for your area and seed now with some starter fertilizer. Then do pre-emergent 2 treatments spring about a month apart. The only way to get rid of crabgrass is to prevent the seeds to germinating. Once you apply the pre emergent do not touch your lawn with a rake shovel or anything that will scratch the surface of the soil for a few weeks.
  11. Sep 18, 2020 at 7:02 PM
    #191
    MS22
    MS22 New Member
    02 Tundra 4x4
    Maybe try a good power rake on the lawn and drop a sh%t load of grass seed down.
  12. Sep 21, 2020 at 8:47 AM
    #192
    Charvonia Design
    Keith
    Huntersville, NC
    I like the idea of a slit seeder, have not tried one before. I just seeded my back and side yards over the weekend, but haven't done the front yet. I did use a power dethatcher so the soil is clear and visible, and it lightly opened up the surface of the soil. I rented a roller that you fill with water and towed it behind my mower to ensure good seed to soil contact. Guess we will see if that was enough! I also weighed the seed this year as I put it down and came to the conclusion that I did not use nearly enough seed last year. I applied 4 lbs/1000 sq ft in the overseed areas and 7-8lbs/1000 sq ft in the bare areas where I killed the crabgrass.
    The front yard still needs to be done, I used Roundup on Friday to finish off any crabgrass that was still green and get all the weeds. Need to make up my mind this week about what approach to take for the front yard....
  13. Sep 21, 2020 at 1:37 PM
    #193
    Pudge
    CT
    Needed to dethatch. Rented a machine for 4 hours. Was able to do the whole yard in 2 different directions. Came out great, so much dead shit under there that will now let the lawn breath and spread. I may throw some seed in some spots.
  14. Sep 22, 2020 at 4:48 AM
    #194
    Charvonia Design
    Keith
    Huntersville, NC
    Isn't it satisfying to dethatch your yard? haha
    Pudge[QUOTED] and jewsNbrews like this.
  15. Sep 22, 2020 at 5:01 AM
    #195
    MKKnuds
    MKKnuds God, Truck, Guns, Beer
    Matthias
    Arvada, CO
    2012 Silver Tundra
    Tonneau cover, PlastiDip emblems
    I need to do this. Broke my back last spring doing it with a rake. The previous owner of my house trashed the lawn and I've been working on getting it nice for 2+ years. That looks like a life saver.
    TokerJoker and Pudge[QUOTED] like this.
  16. Sep 22, 2020 at 7:33 AM
    #196
    Fiesta346
    Fiesta346 New Member
    PA
    2013 Rock Warrior
    Before/After of some recent front yard landscaping.
  17. Sep 22, 2020 at 8:35 AM
    #197
    Pudge
    CT
    It works great. Its not self propelled but if you get the blades set right it'll pull itself along very nicely.
  18. Sep 22, 2020 at 10:22 AM
    #198
    drobb
    drobb The Feral Snail
    2013 Tundra CrewMax 4x4
    CD54F4B8-CCE2-4253-B528-04FA5F730347.jpg My lawn skills are great in the demo department :)
  19. Sep 22, 2020 at 10:22 AM
    #199
    TokerJoker
    TokerJoker ΜΟΛΩΝ ΛΑΒΕ
    Travis
    Nowhere, Specific
    2014 Black SR5 4.6 Dbl Cab
    None.....yet
    :thumbsup:Noice
  20. Sep 22, 2020 at 10:47 AM
    #200
    TundraLaw
    TundraLaw New Member
    Northern Nevada
  21. Sep 22, 2020 at 1:30 PM
    #201
    Charvonia Design
    Keith
    Huntersville, NC
    You can buy them online for under $150. Sunjoe brand or similar, probably good for a couple seasons. Mine is about half used up after a lot of use this year trying to get rid of dead crabgrass.
  22. Sep 22, 2020 at 7:42 PM
    #202
    Baja Mike
    South Bay, Ca.
    Received the Tenacity in the mail yesterday as well as everything else to use it. So today I sprayed my entire front yard, my side yard/walkway between mine and my neighbors house which was nothing but weeds and crabgrass, and did some of my backyard. Sprayed about 3 gallons total. I'll find out in a week how much is dead and what I missed.
    Top tip: if you guys and gals ever use this stuff, wear rubber gloves. That blue dye is very powerful long lasting stuff.
  23. Sep 22, 2020 at 8:12 PM
    #203
    My lawn care skills still need improvement...
    I suck.
  24. Sep 23, 2020 at 2:41 AM
    #204
    Good looking dog at least.
  25. Sep 24, 2020 at 7:48 AM
    #205
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Decent excuse too :)
  26. Sep 24, 2020 at 8:41 AM
    #206
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    I'm just now getting to a point where I'm watching YouTube videos and reading a bit more on how to properly take care of it. We built the house almost 5 years ago. This all used to be rice fields until they developed the subdivision on it. I have a 54" Kubota ZTR I use and I'm thinking of a way to add a DIY striping kit since I usually cut on about 3.75". I change my cuts from vertical to horizontal to diagonal left to diagonal right then start over again....to avoid any ruts forming. Mostly st. augustine grass, but front yard has mostly weeds with a blend of some st augustine/bermuda/weed blend lol. Got some good motivation on here for me! Most recent pics I have are from a few weeks ago after the hurricane hit, aside from the close up of front of house.
    Here is a hyperlapse of me cutting the backyard before the playset was destroyed in the storm. haha
    https://www.youtube.com/watch?v=OxmNZgTFIDI
  27. Apr 20, 2021 at 10:47 AM
    #207
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    How's the yards/yard prep coming along guys? This is the first year i'm going to start working on my yard like weed & feed/fertilizer/etc. Front yard is about 25k sqft....and that's all I'm going to try transform a bit. Went to store to buy a small spreader and round up and ended up buying a lot bigger spreader, weed & feed, and round up haha. Some of y'all got some bada$$ yards and I wanna see/hear about y'alls work!
  28. Apr 20, 2021 at 11:32 AM
    #208
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
    I hate cutting grass !!!!!
    sask3m likes this.
  29. Apr 20, 2021 at 11:57 AM
    #209
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    Lawn care is a real catch 22. If you want a nice weed free lawn regular fertilzer is your friend but if you hate cutting grass it's your enemy. Generally after a few years most people opt for the shittier lawn with less mowing.
    PermaFrostTRD likes this.
  30. Apr 20, 2021 at 12:03 PM
    #210
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    I'm falling into the happy medium as of now. I'm doing a little bit to get my lawn looking better, but not so much that it's taking up a bunch of my time. cutting grass and washing the vehicles is my stress reliever. put on some music and get to work!
    sask3m[QUOTED] likes this.
