  1. Sep 20, 2020 at 4:07 PM
    #8041
    Maybe I'll remove them then.
    NUDRAT[OP] likes this.
  2. Sep 20, 2020 at 4:24 PM
    #8042
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Those are self resetting circuit breakers.
  3. Sep 20, 2020 at 4:33 PM
    #8043
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    Trolling the tundra reddit page
    Outbound, Darkness, jImmegart and 2 others like this.
  4. Sep 20, 2020 at 4:53 PM
    #8044
    Do you think my theory is right? Most likely from the brake controller under my dash? If not, what else would they be for?
  5. Sep 20, 2020 at 4:54 PM
    #8045
    Festerw
    Festerw New Member
    04 Tundra DC
    Could be, only real way to tell would be to trace the wires or disconnect and see if anything stops working.
  6. Sep 20, 2020 at 5:07 PM
    #8046
    Casper421
    In the woods
    06 DC
  7. Sep 20, 2020 at 5:47 PM
    #8047
    You and me both. The last few weeks have been utter shit. Just this weekend alone, put in a straight 15 hours Saturday, and another 10 today. Not supposed to work weekends, but some emergency crap came up for someone that's out on vacation, and the guy on vacation isn't around to give me the right stuff to make things a 4-6 hour job instead of 24-26 hour job. Ugh.
    I've had my replacement leather-wrapped OEM steering wheel and right-hand controls for weeks and haven't had a spare hour or two for install.
  8. Sep 20, 2020 at 5:53 PM
    #8048
    Low voltage breakers. You know where one end goes, where does the other go? Likely culprit could be brake controller, you wouldn't want something like that to be a fusible link, eh? This type of breaker self-resets instead of blowing. If you arc one out, it'll click rhythmically. as the circuit opens and closes.
  9. Sep 20, 2020 at 5:57 PM
    #8049
    JessiJane06Tundra
    JessiJane06Tundra New Member
    Jessica
    San Antonio
    06 Tundra crew cab
    Small lift
    Cost to install at dealership 1,000,000 dollars
  10. Sep 20, 2020 at 6:03 PM
    #8050
    They don't call 'em stealerships for nothin!
  11. Sep 20, 2020 at 7:43 PM
    #8051
    ktundra
    ktundra rust be damned
    Lex
    NJ
    06 Tundra DC Limited 4WD
    Bilstein 5100
    I didn't realize how beefy these brakes are. Most cars have a single piston, the later model year 1st gens come with 4-piston calipers.
    No wonder all those Taco guys are upgrading their trucks with Tundra brakes!
  12. Sep 20, 2020 at 8:52 PM
    #8052
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    toyotas used 4 piston calipers on 4x4 pickups, 4runners, tacomas and tundras since the first IFS pickups. so 86? maybe even older. might of been since 79, the tundra brakes are just larger than the taco brakes
  13. Sep 21, 2020 at 6:43 AM
    #8053
    ktundra
    Lex
    NJ
    Bilstein 5100
    Ahhh, I stand corrected. I'm pleasantly surprised to see the 4-piston caliper design on our trucks. Even standard calipers on most M model Bimmers are single piston.
    IIRC, were you looking to upgrade your Tundra brakes to 4Runner calipers and rotors?
  14. Sep 21, 2020 at 7:25 AM
    #8054
    empty_lord
    05 rollover special
    I plan on doing the newer 4runner calipers when I go to 17” wheels yes.
    speedtre likes this.
  15. Sep 21, 2020 at 7:25 AM
    #8055
    empty_lord
    05 rollover special
    [​IMG] And this is a must for me to add to my truck because I need all the lights
    Outbound, artsr2002 and ktundra like this.
  16. Sep 21, 2020 at 8:18 AM
    #8056
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Every time my wife leaves my house in the truck I get the chills.
    shifty`, bmf4069 and Pucks18 like this.
  17. Sep 21, 2020 at 8:45 AM
    #8057
    Pucks18
    Lolol why?
    Darkness[QUOTED] likes this.
  18. Sep 21, 2020 at 9:56 AM
    #8058
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I wonder if they'll both come back the same way they left :rofl:
    I get as happy as our puppy when I hear my exhaust coming back home. My puppy runs to see her, I run to check my truck!
    bmf4069, TX-TRD1stGEN, saybng and 5 others like this.
  19. Sep 21, 2020 at 3:02 PM
    #8059
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I've been meaning to ask for a few weeks now, but keep forgetting or getting side tracked (ooh shiny, runs off...)
    What is everyone using sway bar links?
    I know there's a vendor here on the forum, but can't seem to find the link in marketplace.
    Main question is "What's a good option with about 2 inches of lift?"
    I figure mine will go ka-blooey when I get off work and have time to tear into the front end.
  20. Sep 21, 2020 at 3:25 PM
    #8060
    empty_lord
    05 rollover special
    I just have Napa ones for a trd offroad. No complaints. Limits flex a bit but meh.
    Pucks18 likes this.
  21. Sep 21, 2020 at 3:27 PM
    #8061
    Message @Mstudt for more info. I run no front sway bar
    ktundra likes this.
  22. Sep 21, 2020 at 3:40 PM
    #8062
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    https://suspensionmaxx.com/product/SMX-122270T
    I used these, the nut is a little wonky to tighten, but worked fine.
  23. Sep 21, 2020 at 4:38 PM
    #8063
    ktundra
    Lex
    NJ
    Bilstein 5100
    I was saying to myself... self: why does @empty_lord need a switch that doesn't fit on our 1st gens? After driving to pick up dinner, I saw that the switch buttons seem to be identical. Ripe for disassembly and Frankenstein over to a 1st gen switch.
  24. Sep 21, 2020 at 4:46 PM
    #8064
    I also run these but think they might be overkill. Noah, I'd just get the Napa ones Dan mentioned
  25. Sep 21, 2020 at 5:00 PM
    #8065
    empty_lord
    05 rollover special
    Double cab has different switches than mine too. This is a direct fit. All I have to do is run the illumination wire
    ktundra[QUOTED] and FrenchToasty like this.
  26. Sep 21, 2020 at 5:34 PM
    #8066
    ktundra
    Lex
    NJ
    Bilstein 5100
    Found a potential deal on the List by Craig, out in Long Island, NY.
    I asked seller for more info, and of course what we all want... more pics! Alas, he said it was gone in 60 seconds, er... 2 hours.
  27. Sep 21, 2020 at 7:51 PM
    #8067
    JessiJane06Tundra
    Jessica
    San Antonio
    06 Tundra crew cab
    Small lift
    Alright folks its time to play what order do I work in now. Had a mechanic replace my fuel tank 2 months ago during which time my check engine light was already on. I installed bypass kit for the SAIS which cleared one of them. I replaced the PCV valve and the purge valve located under the hood. I'm still getting P0441 and P0445 for large leak and small leak/incorrect purge. I know there is another vent solenoid for about 60$ from parts geek. But because I don't know which came first the error code or the new gas tank there is 4 more possibilities under there. Vent solenoid, charcoal canister leak, incorrectly loosely connected hoses to the newly installed gas tank, or even a leak in the tank itself as it was a used fuel tank. Would you drop everything back out a check the shitty mechanics work,inspect and reline the used gas tank, check all the hoses, and test the vapor canister for leaks and be really complete... or work backword...buy the vent solenoid and check the vapor canister first before dropping out the tank. Im already way past the point of hoping this would be an easy fix like a new gas cap because yes of course I did that already.
  28. Sep 21, 2020 at 9:02 PM
    #8068
    empty_lord
    05 rollover special
    @Tundra2 there is a build thread for the 09 corolla now on TW. just because you asked a few weeks ago lol
    ktundra likes this.
  29. Sep 22, 2020 at 5:41 AM
    #8069
    When dealing with EVAP stuff, you're basically just throwing parts at the problem unless you have some way to monitor pressure readings from the sensors via ODBII. You really need to know (at minimum) whether there is/isn't vacuum in the fuel system first and foremost, then need to know if all sensors are reading, and reporting back valid ranges.
    You may find this thread helpful: https://www.tundras.com/threads/solved-p0441-p0446-p0455.73467/
  30. Sep 22, 2020 at 5:56 AM
    #8070
    I've never seen anyone discuss the oil pumps on our trucks. Anyone ever seen one fail on the 4.7?
