Leveling kit problems
Discussion in 'Suspension' started by Randoo254, Oct 2, 2019.
  1. Oct 2, 2019 at 6:51 AM
    Randoo254
    Randoo254 [OP] Addicted to Upgrades
    Randy
    2020 TSS 4x4 SR5
    3 in leveling Kit
    Hey guys I wanted to see if anyone else has run into this issue after installing a leveling/lift kit. After installation I noticed a popping noise when I start my truck and start to drive off. It doesn’t ever do it any other time even if I put it into park and drive off only when I turn the truck off and then back on and then start to drive off. It’s not loud but I can feel it in the accelerator pedal. Let me know if anyone has run into this, thanks.
  2. Oct 2, 2019 at 6:55 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    It is the ABS doing a self-check. It's normal and you probably just didn't notice it before the leveling . But it has nothing to do with the leveling - all good.
    15whtrd likes this.
  3. Oct 2, 2019 at 7:24 AM
    Randoo254
    Randy
    2020 TSS 4x4 SR5
    3 in leveling Kit
    Ok thanks for the feedback. I can’t imagine missing that initially it’s so obvious. Weird but thanks for the info.
  4. Oct 2, 2019 at 7:55 AM
    What leveling kit is installed? Alignment done? I have seen where the spring pop during settling.
  5. Oct 2, 2019 at 7:57 AM
    Randoo254
    Randy
    2020 TSS 4x4 SR5
    3 in leveling Kit
    High country leveling kit. They did do an alignment afterwards. I dunno it’s weird.
  6. Oct 2, 2019 at 7:58 AM
    Randoo254
    Randy
    2020 TSS 4x4 SR5
    3 in leveling Kit
    spring going to what?
  7. Oct 2, 2019 at 8:19 AM
    15whtrd
    15whtrd Mr. Blonde
    If it’s only doing it the once after starting the truck and driving off, it’s the ABS for sure. It’s just a self check that the system does. If you can get it to do it more than the once after taking off, something else is going on. In response to what George was telling you, the spring can pop during settling in the cradles. I would assume because they’re trying to find a spot they want to be in LOL
  8. Oct 2, 2019 at 8:35 AM
    MAGDADDY
    MAGDADDY TTC #280
    JON
    Houston TX
    18 Platinum CM MGM
    Leer 100XL, Bedrug, Go Rhino running boards, LED int/ext lighting, Bilstein 6112/5100 1/2”shims up front, Coachbuilder +3 shackles, CB drop, TRD front/rear sway bar, 275/65/20 Michelin LTX M/S 2, sequoia painted mirror cap/door handles, Rago Fab low pro ditch brackets, Baja Designs S2 sports ditch lights. Baja Designs S2 sport rear flush mount pod
    Yep ABS mine does the same thing. Usually right at 12mph I’ll hear like a metallic pop and you feel it in the truck. My wife every time “did something just fall off the truck” :rofl:
  9. Oct 2, 2019 at 9:00 AM
    Randoo254
    Randy
    2020 TSS 4x4 SR5
    3 in leveling Kit
    Yeah it's only one time after I start the truck. I can't believe I've never noticed that before lol. I feel dumb...
    15whtrd[QUOTED] likes this.
  10. Oct 2, 2019 at 9:03 AM
    CCLJ03
    CCLJ03 Tundra forever
    Craig
    2018 TRD Off-Road - Cement
    Literally ALL of us have been there man.
    Let’s see pictures of your truck with your leveling kit!
    Boerseun and 15whtrd like this.
  11. Oct 2, 2019 at 1:02 PM
    Randoo254
    Randy
    2020 TSS 4x4 SR5
    3 in leveling Kit
    Just odd though.. I had 2008 and 2013 tundras and never noticed this ever.. I do believe you guys tho there’s a ton of people saying the same now that I know what to search for lol.
  12. Oct 2, 2019 at 1:03 PM
    Randoo254
    Randy
    2020 TSS 4x4 SR5
    3 in leveling Kit
  13. Sep 16, 2020 at 9:58 AM
    Tundratss512
    Tundratss512 New Member
    2020 Tundra Crewmax TSS
    @Randoo254 I just bought an identical truck and want to level it. Can you tell me about the lift you chose? Did you get an alignment done after? Does it effect the factory warranty at all? And most importantly: did it give you any issues with the front facing camera for lane departure/cruise control etc??
  14. Sep 19, 2020 at 8:21 AM
    This is the way
    This is the way New Member
    Rthur
    275-60-20.jpg new here, reading the forums and this caught my attention.. this is my first truck, 2019, leveled it out, put on 275-60-20 bfg's.. thought i was doing everything right until i heard the little clank noise. this really took the pressure of me.. thanks for the info guys,,,
    JimboSlice413 likes this.
