Sequoia rear swap?
Discussion in '1st Gen Tundras (2000-2006)' started by evilrb, Sep 16, 2020.
  1. Sep 18, 2020 at 12:50 AM
    evilrb
    evilrb [OP] New Member
    Jeremy
    awesome, thanks for the info, looks like I have more on my plate now...
  2. Sep 18, 2020 at 12:54 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    thats how it always goes! honestly the easiest way (Assuming you have the means to do this) is get the sequoia axle stripped of all the suspension stuff and weld on the correct tundra perches and shock mounts. as for the parking brake cable stuff, SOS makes their own cables for their kit. might be someone to call about having some made for sequoia backing plates.
  3. Sep 18, 2020 at 1:29 AM
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    Thanks for the info and pic. :thumbsup: Tagging @robabeatle in case this helps his installation
    ktundra and robabeatle like this.
  4. Sep 18, 2020 at 5:07 AM
    @evilrb can you post a pic of the back side of the hub/backing plate piece on the sequoia axle? The part where the axle bolts in? Kinda for clarification of what Mr. Lord is talking about.
    evilrb[OP] and Tundra2 like this.
  5. Sep 18, 2020 at 7:40 AM
    robabeatle
    robabeatle New Member
    AZ
    2002 Tundra 4x4 LTD AC
    Bilstein 6112 & 5160, Katskinz, audio upgrades
    I just received this sway bar yesterday and ran into an issue of the abs line and mounting tab on the passengers side axle sitting right where the bracket for the SB goes. So I was advised to basically bend it out of the way.
    Also, I read that you didn't have to drill. There is a location on the passenger's side where I can fit the bolt through but the drivers side, at the same location, has some other mounting tab there in the corresponding hole. I removed the bracket only to find that there is a nut welded on the other side of the frame making the hole just a bit too small to fit the bolt. In your pic above, is that the drivers side? It looks like it and that mounting tab is just what I was talking about. I have to go out and look at the location where you mounted that bolt.
    ktundra likes this.
  6. Sep 18, 2020 at 8:03 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Easy fix, just use 2 bolts per side :D
    bmf4069 likes this.
  7. Sep 18, 2020 at 8:38 AM
    empty_lord
    05 rollover special
    I can picture someone trying that and an axle shaft flying out on the highway. Lol
    bmf4069 and Darkness[QUOTED] like this.
  8. Sep 18, 2020 at 8:42 AM
    robabeatle
    AZ
    Here is the drivers side frame where the sway bar mounting bolt should be fitted to the frame. The removed bracket is the location I thought I would use to mount but there is a nut welded on the other side. I am thinking I need to drill a new hole. no?
  9. Sep 18, 2020 at 8:42 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Yeah don't do that move :D
  10. Sep 18, 2020 at 8:57 AM
    Professional Hand Model
    Fred
    Hand Protectors
    If thats where your new mounts are suppose to be, then wallow out (make bigger) that hole with a Unibit or Regular Drill Bit. Make it happen!
    robabeatle[QUOTED] likes this.
  11. Sep 18, 2020 at 9:15 AM
    robabeatle
    AZ
    This will cause the drivers side of the sway bar to be mounted slightly (the thickness of the nut) higher.
    No problem?
  12. Sep 18, 2020 at 9:54 AM
    Fred
    Hand Protectors
    This is something you’ll need to determine, as I’ve never installed your model sway bar. I’d need to see and feel the components to assess the Mojo. Any way to tap that nut off with a chisel and little sister sledge? Or, Tap the hole larger and try a dry fit with the nut prior to remove? Might need that surface flat for accessory washer?
  13. Sep 20, 2020 at 2:57 AM
    evilrb
    Jeremy
    OK midnight thoughts...
    Been thinking since I have the sequoia diff and it comes with the 4.10 gears will the front diff with matching gears just drop right in?
    I found a set of 4.56 that I'm looking at but if it's cheaper and easier than I'm fine with the 4.10's.
    I'm running 285-70-17 so it's not that big of a deal.
    (Yes, I just realized they're 32.7)
    I would like to run 33's but not a big deal if it saves me money.
    What do you guys think?
    Remember that I drive mostly freeways around here.
  14. Sep 20, 2020 at 8:16 AM
    empty_lord
    05 rollover special
    Front sequoia diff will be drop in. Same as 3rd gen 4runner and 1st gen taco
    lsaami and evilrb[QUOTED][OP] like this.
  15. Sep 20, 2020 at 3:49 PM
    delz05
    delz05 Old relic... Living and Loving Life!!!
    BOSTON
    2005 Tundra Limited
    Work in progress...
    If you do not use the Tundra backing plates... i am in need of a pair...
    evilrb[OP] likes this.
  16. Dec 11, 2020 at 1:27 AM
    DaWhiteTundra
    DaWhiteTundra New Member
    Anthonee
    Sacramento, Ca
    White 2002 sr5 v6 Rwd
    Lsd, 5100’s all around, lift springs, 1inch rear block, extra leaf, 13wl caliper swap, slotted drilled rotors, ss brake lines, 27mm sway bar, rear addco sway bar,
    did your addco rear sway come with that ubolt to mount it above your rear axle or did you buy that separate?
    finally bought it and getting ready for install.
  17. Dec 11, 2020 at 2:30 AM
    evilrb
    Jeremy
    Came with it, but I had to buy ubolts for the add-a-leaf.
    Might as well update cause, really I forgot:rolleyes:
    I've been researching and measuring and a buddy needed the axle so I hooked him up with it.
    And the Sequoia backing plate is different than my Tundra.
    But can't confirm if it's because I have non-ABS vs ABS or just in general.
    Thought about just welding the brackets and making the Sequoia axle fit bu in the end, I talked to SOS and told him what I had in mind.
    So after eating ramen to save the money and some shipping delays I got a SOS kit from them with the specific parts I needed since I have all the sequoia brake parts and lines.
    So I'm doing their backing plate and parking cable kit.
    Wa half the cost and only got the parts in yesterday after a delay on their end.
    I'll be doing a full write up when I install it.
    I only have one more thing that I'm waiting on and it should be go time!
    DaWhiteTundra[QUOTED] and jpink like this.
  18. Dec 11, 2020 at 6:37 AM
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    And bam, before you know it you have a "practically " brand new truck!
    evilrb[QUOTED][OP] likes this.
  19. Dec 11, 2020 at 1:07 PM
    evilrb
    Jeremy
    :rofl:Already accepted that fact months ago... :rofl:
    Doing paint and interior too so you're not wrong!:rolleyes::D:D:D:D
  20. Dec 11, 2020 at 1:17 PM
    #50
    evilrb
    Jeremy
    I already got rid of the axle but here are the pictures I have
    As empty_lord said, the plates are not the same and the Sequoia ones are off-center while my non- ABS plate bolts are squared.
    The pictures aren't the best but if you look at the b olts you can tell.
  21. Dec 11, 2020 at 1:47 PM
    #51
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    I just swapped out my driver's side rear axle on my sequoia last night and have the old one sitting in the bed of the tundra. What do you want me to take pics of?
  22. Dec 18, 2020 at 7:05 PM
    #52
    evilrb
    Jeremy
    Just in case anyone is interested in the ADDCO 2181 1’ rear sway bar kit, here is the PDF of the install sent to me.
    Thought it might help for the future
  23. Oct 4, 2023 at 5:38 AM
    #53
    Roni344
    Roni344 New Member
    Tnx to u . i install addco on my tundra 2001 easy to install
