Is pro comp 6" lift not level?
Discussion in 'Suspension' started by Tundrasr5, Nov 9, 2018.
  1. Nov 9, 2018 at 9:47 AM
    Tundrasr5
    Tundrasr5 [OP] New Member
    2017 tundra sr5 4x2
    None yet.
    Hello all,
    I search and couldn't find anything on pro comp. I was thinking of getting a 6" pro comp lift on my tundra but don't like the front end to be high and rear sagging. Is it a pro comp thing? I like it to be more level. I was thinking about the readylift kit too any thoughts?
    Thanks,
  2. Nov 12, 2018 at 8:30 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    A 3/1 is level. You can figure it out from there.
  3. Nov 12, 2018 at 8:34 PM
    Tundrasr5
    2017 tundra sr5 4x2
    None yet.
    What does a 3/1 level means?
  4. Nov 12, 2018 at 8:37 PM
    BlackRose
    BlackRose I deserve a participation ribbon
    Max
    2017 Black Tundra Sr 4.6
    Parts Incoming!!!
    @Tundrasr5 The front of our trucks sit lower than the bed. This is so when we tow or have stuff in the bed it will make up for it. They call it a "leveling kit" because it makes the truck sit level with the front and back. 3/1 means 3 inches of lift in the front and 1 inch in the rear. Hope this helps!
  5. Nov 12, 2018 at 8:48 PM
    Juanjoolio007
    Juanjoolio007 New Member
    Oregon
    2019 Silver Sky Platinum Crew Max
    Bed Rug, Tonneau cover, Window visors, Console organizer, Weather Tech's
    The pro comp will be level. Depending on the stage you choose it’s either a spacer for on top of your front coil or if you get stage 2 it’s an entirely new adjustable coil over. The rear is lifted by blocks. They are 3”.
  6. Nov 12, 2018 at 8:50 PM
    Juanjoolio007
    Oregon
    Here is a pic with that lift and 35’s.
  7. Nov 12, 2018 at 8:51 PM
    BlackRose
    Max
    Parts Incoming!!!
    Have to save this for um research? Yeah research:anonymous: Freaking beauty man nice truck
    Juanjoolio007[QUOTED] likes this.
  8. Nov 12, 2018 at 8:56 PM
    Juanjoolio007
    Oregon
    I’m pretty sure I still have a link to a Tacoma I was “researching” from years ago.:rofl:
    BlackRose[QUOTED] likes this.
  9. Nov 12, 2018 at 8:59 PM
    Juanjoolio007
    Oregon
    Ahhh just realized your 2wd.... that may change things. Maybe one of those guys will chime in.
    Also welcome.
  10. Nov 12, 2018 at 9:01 PM
    BlackRose
    Max
    Parts Incoming!!!
    My phone has 22 tabs worth of "research" because of this damn forum. Paydays are especially hard:spending:
    Inquiringone and Blueknights75 like this.
  11. Nov 12, 2018 at 9:03 PM
    Guhner123
    Guhner123 New Member
    Gunner
    2017 Tundra SR5 MGM
    Toytec/Eibach 3/1 lift kit 295/70/18 TOYO AT 18 Inch Method NVs
    If I was 2wd I would go with a spindle lift. MaxTrac preferably!
    jeremyd likes this.
  12. Nov 13, 2018 at 6:12 AM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    It's not the Procomp, It's the soft Toyota springs in the rear. Within 6 months I had to install a 1 inch shackle to get it back to level. I also tow regularly.
    Tundra_Dawg likes this.
  13. Nov 19, 2018 at 12:45 PM
    t3chnical
    t3chnical New Member
    Chula Vista (Eastlake), California
    2017 Tundra SR5 CrewMax
    7” Pro Comp Lift 20” LRG on 37s
    This! I thought the same thing as well but realized quickly once I loaded the bed. All that will change when I add RideRite bags. Still researching (here) how my lift will affect my towing capabilities.
  14. Nov 19, 2018 at 1:53 PM
    Coachbuilder1
    Coachbuilder1 Industry Leader Vendor
    Salt Lake City UT
    2007 SR5 5.7 Katzkin, LED lighting through out, LED door handles, Color Matched handles & grill surround, CST 3.5" Spindles OME 614 Full Suspension, Coachbuilder +3" Shackles by Ekstrom Design, BHLM,35"/12.5"/20 Nitto Trail Grapplers,BMF SOTA death metal black finish 20"x10" -19 offset.
    Most 6"-7" lifts use the same ratio.. 6"-7" up front and 4" in the rear. The Procomp kit uses a 3" block and a 1" add a leaf. over time the AAL ends up settling and will notice the truck react a bit different. You'll also notice a different stance if your truck has a 38 Gal fuel tank. When setting this lift up we normally add 1.25" to the Stage I via +2" Coachbuilder shackles or 1.75" to the Stage II via +3" Coachbuilder Shackles, Not only does your traction control appreciate it but if your truck is a 2018-2019 the Proximity sensors need it.
    ** You will also need to add a larger carrier bearing drop kit in order to correct the opinion angle, I'll list it.
    https://shop-coachbuilder.myshopify...ilder-2-shackles-provides-1-25-of-actual-lift
    https://shop-coachbuilder.myshopify...ilder-3-shackles-provides-1-75-of-actual-lift
    https://shop-coachbuilder.myshopify...uilder-carrier-bearing-drop-kit-rear-lift-3-5
  15. Nov 21, 2018 at 4:37 PM
    Tundrasr5
    2017 tundra sr5 4x2
    None yet.
    Im still a newbie, Thanks to you all. Lots of good info here.
    I was about to purchase the pro comp but now leaning towards the superlift kit 6".
    Does anyone have any experience with the superlift kit? Yes my tundra is a 2wd and that's why I'm having a hard time looking for lift kits. I have already made a appointment to a shop next week for this superlift kit.
    Any pros and cons are welcome, please let me know. Don't want to spend $ on something I will regret later. Btw, I'm just looking for a budget lift kit, nothing crazy.
    Thanks.
  16. Nov 21, 2018 at 4:42 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Just curious about something I was told before. I asked a shop about putting a shackle on my tundra. They said no, not on a full size pickup. Why would they say that?
    Coachbuilder1[QUOTED] likes this.
  17. Nov 22, 2018 at 9:40 AM
    Coachbuilder1
    Salt Lake City UT
    They are mostly likely not familiar with the benefit of properly sized shackles. Especially when it comes to the Tundra.. We work with installers daily, While most have the experience and knowledge to recommend parts that will complement
    the vehicles suspension we still run into shops that think of shackles as being a way to lifting a old 70"s muscle car. Technology has come a long way :)
    if you or your installer have any questions please feel free to reach out.
    801-635-4872
    Inquiringone and 15Yota like this.
  18. Nov 22, 2018 at 11:21 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Sending a pm
  19. Jan 28, 2019 at 8:39 PM
    Big J
    Big J New Member
    2020 4x4 crewmax
    Since allot of lift kits only go 3" in the rear, if we add lift with shackles will that require different carrier bearings as well? Curious cause I wasnt sure what shackles +blocks do to all the angles.
    Also what is your opinion on just getting different leaf springs? I saw skyjacker makes a 4-4.5" lifted rear spring. Could we use something like that and just kill off the blocks altogether?
  20. Jan 28, 2019 at 8:51 PM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    Air bag it for 1000 bucks that should be a barebones system, had one on another truck worked great for towing to.
    Or go to coach builder
    Coachbuilder1 likes this.
  21. Jan 28, 2019 at 9:27 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I agree spindle is the best way to lift a 2wd.
    Check out cst spindles. Stronger than maxtrac, yes more $ though but higher quality
  22. Jun 13, 2019 at 7:58 PM
    Dell
    Dell New Member
    I had a 7in put on my truck with the pro Comp tires and rims and It does not sit Leve pluss have a vibration at 50 to 60 miles an HR and keep taking it back to the lift shop and all I get is excuses and to spend more money to try to fix the problem, never had that with my other lift kits, even called pro Comp direct and same thing nothing but excuses, $7000.00 in lift and tires and rims and have to hear excuses, they say 5year 60,000 mile warranty not so once out the door your done. I even asked them before it was done about the guarantie and they gave me the paper work. Not so big joke. Once they have your money you are done, they even charged me $40.00 to rotate the tires they said might be the problem
  23. Jun 13, 2019 at 8:30 PM
    Tundrasr5
    2017 tundra sr5 4x2
    None yet.
    Dell,
    Sorry to hear about your situation. So far so good with my super lift kit. hopefully you get your issue straighten out.
  24. Sep 16, 2020 at 2:43 PM
    buda_d24
    buda_d24 New Member
    Ron
    17 tundra sr5
  25. Sep 16, 2020 at 2:45 PM
    buda_d24
    buda_d24 New Member
    Ron
    17 tundra sr5
    I have pro computer stage 2 6” lift and the rear sit 1.5” - 1.75” lower than front. If i install these shackles it will raise rear and pretty much level or higher in the back? Do I need to get truck realigned after install?
  26. Sep 16, 2020 at 3:21 PM
    Coachbuilder1
    Salt Lake City UT
    No alignment needed after installing the shackles. You'll also want to increase the size of the carrier bearing drop kit. I'll include links.
    https://shop-coachbuilder.myshopify...kit-rear-lift-3-5?_pos=1&_sid=bc3bfcd92&_ss=r
  27. Sep 16, 2020 at 3:33 PM
    buda_d24
    buda_d24 New Member
    Ron
    17 tundra sr5
    Great! Do I need to take to shop to install or can I do it myself?
  28. Sep 16, 2020 at 3:38 PM
    Coachbuilder1
    Salt Lake City UT
    I doesn't require anything special, floor jack, jack stands, basic metric wrench and socket set, torque wrench and will need to borrow a ball joint press tool from your local auto parts store.
  29. Sep 17, 2020 at 5:56 AM
    buda_d24
    buda_d24 New Member
    Ron
    17 tundra sr5
    Ok cool. Thank you!
