Would you be dissapointed at these BMC welds
Discussion in '2.5 Gen Tundras (2014-2021)' started by HingleMcringleberry, Sep 10, 2020.
  1. Sep 10, 2020 at 8:38 PM
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    I’ve always been told, grinding doesn’t make you a good welder, it makes you a good grinder.
    SomeGuy4, berto40, rockmup and 2 others like this.
  2. Sep 10, 2020 at 10:39 PM
    Zero One Actual
    Isn’t that a quote from J lo or Beyoncé?
    I highly suggest the op shows them pictures from this forum and then asks how it is going to be corrected. Obviously the easiest answer is to go elsewhere and have that shop refund your money. Sadly easier said then done sometimes.
  3. Sep 10, 2020 at 10:45 PM
    Hightide
    Abalama
    Magic School Bus
    :cookiemonster:
    Pretty sure that was, Bea.
  4. Sep 11, 2020 at 12:01 AM
    Elduder
    Elduder New Member
    I'd contact Nick on instagram, @adventurefab . Hes in Vancouver Wa, has done my last two trucks and they look great.
  5. Sep 11, 2020 at 8:26 AM
    HingleMcringleberry
    HingleMcringleberry [OP] New Member
    Portland, OR
    2019 Tundra Dbl Cab SR5 Offroad
    BP51 Shocks, Dakar Leafs, Icon Delta Joint UCA's, Falken WP 315/70 R17 w/ Method 703's.
    Thanks for the tip, I'll get a hold of him today and see what his thoughts are. I'm a fan of tundras.com recommendations and like that he's a smaller outfit.
    Elduder[QUOTED] likes this.
  6. Sep 11, 2020 at 8:39 AM
    War Machine
    War Machine SSEM # 5 3MW
    Mine from a couple of weeks ago. I’ve seen better but good enough for me.
  7. Sep 11, 2020 at 8:40 AM
    War Machine
    That’s just awful.
    Hightide likes this.
  8. Sep 11, 2020 at 9:32 AM
    J's 4x4
    J's 4x4 New Member
    Juan
    Los Angeles County
    2020 Tundra Cement Grey TRD 4x4
    King lift,Leather seats,3m film wrap around,35's KO2 on FUEL Wheels,Line-X, backflip,Bam 10" exhaust with Toyota Black Chrome Exhaust tip,Amp research step,K&N air Filter,TRD air flow Accelerator
    Wow looking at these BMC I'm glad I went to 88. Looks factory and can't even tell something was cut on my truck. Good luck fixing that.
  9. Sep 11, 2020 at 10:04 AM
    Outbound
    Outbound SSEM #2.5, Token AmeriCanadian
    Aaron
    Northern Alberta
    Yup. Grinding down a weld is called putting on a "Makita Cap". There's a time and place to grind down welds, but even if you're grinding down welds at least take pride in your work. It's like integrity. It's measured when only you see it.
    Nevermind that a crap weld won't be as structurally sound as a good weld, ground down or not.
    Hightide[QUOTED] and Trooper2 like this.
  10. Sep 11, 2020 at 11:09 AM
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    Yes that’s terrible, this is professional
  11. Sep 11, 2020 at 11:35 AM
    dMO
    dMO New Member
    2010 Black Tundra
    Toytec 3/1 leveling kit 18x9 VE37 35x12.50 Toyo RT
    heres mine and good enough for me.
  12. Sep 11, 2020 at 12:02 PM
    Those beads look like trash
  13. Sep 11, 2020 at 1:09 PM
    HingleMcringleberry
    Portland, OR
    Update 11SEP2020:
    I spoke to the shop owner. I politely made clear my dissatisfaction with the fabrication. He did comment that they were having difficulties with the welder that day, and also seemed to downplay how concerned I was about how they looked. Regardless, we agreed on splitting the cost; I was refunded 137.50. Not an ideal situation but I think that's about as good as a refund as I could get. I also just hate dragging things out and would rather move on from this headache.
    I plan on taking my rig elsewhere for the fix, and have since reached out to @adventurefab and am waiting to hear back on whether he wants the work. If anyone else has suggestions in the PDX area I'd love to hear them.
    Also, thanks to all for input in helping this along. Definitely inspired by the quality of some of these BMC's!
  14. Sep 11, 2020 at 1:27 PM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
    I'm not a good welder and I know I could have done a better job. I would have asked them to pay to get it done right.
    Outbound, Hightide and berto40 like this.
  15. Sep 11, 2020 at 2:47 PM
    berto40
    berto40 Always a noob.
    Dude..brings back memories. My dad and grandfather were both precision welders for oil field valves..."If you have to involve a grinder, it's not a good weld!" is what i used to hear ALL the time. I never did it for a living but it was a good experience!
    Hightide[QUOTED] likes this.
  16. Sep 11, 2020 at 4:23 PM
    Hightide
    Abalama
    Magic School Bus
    I’ve known ironworkers and boilermakers that would literally fight you if you showed up to weld and had a grinder.
    You don’t grind a damn thing when you’re 20-1200 feet in the air.
    I believe some oil field guys would do the same.
  17. Sep 11, 2020 at 4:25 PM
    Hightide
    Abalama
    Magic School Bus
    The bad part is, it’ll cost you more to get it corrected.
    Always ask to see some work when getting welds done.
    If they’re good they’ll typically show you something anyway.
    Outbound likes this.
  18. Sep 11, 2020 at 4:34 PM
    HingleMcringleberry
    Portland, OR
    Agreed. I honestly thought the task was straightforward enough that it wouldn't warrant a thorough investigation. Hell, there are at least 4 youtube clips that show exactly how to do it well!
    I've cut my losses on this one. Honestly more upset to have booger welds on a 2019 truck than anything else. Hope to get it all resolved next week.
  19. Sep 11, 2020 at 4:37 PM
    Hightide
    Abalama
    Magic School Bus
    Well actually, you’re correct. It’s pretty straight forward and your new truck was not deserving.
    You owe her a wash and wax or something. Mods always make them happy.
    Hope you get it worked out.
  20. Sep 11, 2020 at 4:45 PM
    #50
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    YardBird, Bob_Wiley, KENNY and 6 others like this.
  21. Sep 11, 2020 at 7:35 PM
    #51
    Vector W8
    Vector W8 Old guy with a lot of expensive habits.
    2015 Platinum Super White Crewmax 4X4
    FFV, TRD Supercharger, Bullydog FFV Tune, 2014 Fit Kit, TRD Dual Exhaust, Sequoia Front Sway Bar, TRD Rear Sway Bar, TRD Skid Plate, TRD Pro Grill, 040 White Mirror Covers, 040 White Door Handles, Ready Lift 3"/2", Anzo 3rd Brake Light, Winjet LED Tail Lights, LED Fog Lights, LED Rock Lights, Axle Vent Mod, SDHQ Hidden Winch Mount, 12,000lb Winch. Storm Trooper Shift Knob. BMF BATL Wheels.
    Wow, Hack job. I would recommend anyone run like heck from that shop. That is butcher central. Sorry OP, But that is not good.
  22. Sep 13, 2020 at 2:43 PM
    #52
    KENNY
    KENNY New Member
    Nothing wrong with a lesson learned, atleast you got half back..
    You could even cut a little cost off your next install by cutting that hackjob off if you wanted. Angle grinders are cheap and it won't hurt to ride around with it off till then
  23. Sep 13, 2020 at 3:29 PM
    #53
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Just sand the welds down and slap a coat of paint and you’re done. You don’t need to redo it.
    dMO and rockmup like this.
  24. Sep 13, 2020 at 3:36 PM
    #54
    BTBAKER
    BTBAKER DIFFERENT NAME. SAME JUNK.
    Brad
    Castle Rock
    2023 Ram Rebel
    Whoever did it needed meth money.
    Zero One Actual likes this.
  25. Sep 13, 2020 at 5:14 PM
    #55
    berto40
    Just got around to snapping some pics and now posting. Mine are mediocre looking, but they'll do the job.
  26. Sep 13, 2020 at 5:16 PM
    #56
    berto40
    Bottom view
  27. Sep 13, 2020 at 8:25 PM
    #57
    ionnaeus
    ionnaeus New Member
    Jon
    Chattanooga, Tennessee
    2018 TSS CM SR5 4.7
    That's not a stack of nickles! No one will see it but you'll know it's there.
    YardBird likes this.
  28. Sep 14, 2020 at 9:53 AM
    #58
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    A good prank for shitty welders. :D
    berto40 and Hightide like this.
  29. Sep 14, 2020 at 2:08 PM
    #59
    kevine0001
    kevine0001 New Member
    Kevin
    I would be very concerned about the lack of penetration and durability of those welds. It's not like it's a direct structural point, but it is the frame. Very poor welding there.
    Randy Morton likes this.
  30. Sep 14, 2020 at 2:17 PM
    #60
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab, Beta Variant (I call it my Land Yacht)
    Them's some pretty welds. I should elaborate. The pretty welds are in this post, the original welds are painful to look at.
