Rough Country 3.5” lift?
Discussion in '2.5 Gen Tundras (2014-2021)' started by PaulROahu, Sep 14, 2020.
  1. Sep 14, 2020 at 11:28 AM
    PaulROahu
    PaulROahu [OP] New Member
    Paul
    Kaneohe, Hawaii
    2017 5.7 Tundra Platinum 4x4 MGM
    Any Tundra owners installed the RC 3.5” suspension lift? Please post pics with tire/rim combo and your reviews. I upgraded to 3.5” front coil overs and V2 rear shocks.Need to see how it will look and decide to keep my new 275/65/20 (33.1x10.8x20)tires and 20/9/+12 rims or Would you guys go up to 34/35” & 20/10rims if so what OFFSET works without rubbing?thanks in advance.
  2. Oct 13, 2020 at 11:16 AM
    JGG10
    JGG10 New Member
    Minnesota
    2024 Lunar Rock Tundra Limited TRD Off-Road w/3" TRD Lift Kit
    TRD 3" Lift Kit, Method NV Double Black, Falken Wildpeak A/T4W 35x11.5r18
    I don't have the RC lift, but I have a 3" lift and fit 295/70/18 tires (34.3") with only a little rubbing in reverse - I did no trimming.
  3. Oct 13, 2020 at 12:19 PM
    PaulROahu
    Paul
    Kaneohe, Hawaii
    Thanks I’m installing my lift next week Tuesday. Hope my 33.1x10.8x20 tires will clear.
  4. Oct 13, 2020 at 9:16 PM
    TrucksRCool
    TrucksRCool New Member
    Jordan
    UT
    2021 CM Limited Nightshade
    I just put on a 3/1 and running 275/65R20 (34" diameter) with no rubbing issues. No trimming was needed in my case. But I'm also running stock offset wheels (+58 I think).
  5. Oct 13, 2020 at 10:10 PM
    PaulROahu
    Paul
    Kaneohe, Hawaii
    Thanks was thinking of getting 285/65/20,(34.6x11.2x20). My 3.5”lift should be enough to clear
  6. Oct 14, 2020 at 1:58 AM
    Blazing Blue
    Blazing Blue New Member
    I’m running the 3.5 rc lift on 35x12.5x22 -51 offset. Only a bit of rub at full turns.
    PaulROahu[OP] and Skew12 like this.
  7. Oct 14, 2020 at 4:13 AM
    PaulROahu
    Paul
    Kaneohe, Hawaii
    Nice set up with rims/tires. Probably I’ll do -19 as I need to be legal and have tires under fenders
  8. Oct 14, 2020 at 7:39 AM
    TrucksRCool
    Jordan
    UT
    That looks amazing.
  9. Oct 15, 2020 at 6:03 PM
    jDaGr8
    jDaGr8 New Member
    nice build, any issues with the rc lift?
  10. Nov 10, 2020 at 9:18 AM
    QKoehler
    QKoehler New Member
    Quinn
    19 TRD Sport CM
    Hows she ride? Any complaints with the RC lift?
  11. Nov 10, 2020 at 10:04 AM
    PaulROahu
    Paul
    Kaneohe, Hawaii
    After instal pics of RC3.5” lift with Camburg rear 1.5” shackle lift, both TRD sway bars
