Shake Dat Laffy Taffy (Bed Shake)
Discussion in 'General Tundra Discussion' started by kanger328, Jun 23, 2020.
  1. Jun 23, 2020 at 4:38 PM
    kanger328
    kanger328 [OP] New Member
    Anchorage, Alaska
    2012 DC 4x4
    Not sure if I'm not using the right keywords, but I haven't found anything on this topic.
    I was out on a dirt road the other day with some 1-2 inch deep ruts and noticed that the truck bed seems to shake a lot (2nd gen DC) when going over rough roads. I know the tail section of the Tundra is c-channel and is "designed to flex", but was wondering if this is an issue over time.
    I did see some posts about bed stiffeners, but seems to mainly be for people running shells or racks. I might run a topper one day, but even if I don't should I be concerned at all about this over time? My theory is, in a cold place like where I live (Alaska) could the shaking decrease the integrity of the frame or truck bed? I'm prob being paranoid, but any input would be appreciated. Thanks.
  2. Jun 23, 2020 at 4:40 PM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
  3. Jun 23, 2020 at 4:42 PM
    kanger328
    Anchorage, Alaska
    2012 DC 4x4
    Lol, yup. I just remembered seeing that video when I bought a Nissan Titan back in '08.
  4. Jun 23, 2020 at 4:52 PM
    Vizsla
    Vizsla 2 = 2.5
    :anonymous:Mine doesn’t do that.
  5. Jun 23, 2020 at 5:55 PM
    sf319
    sf319 New Member
    Utah
    2014 CM Barcelona Red SR5 5.7
    Dash Cam|PowerStop Z36|DIY bed rails|DIY Pop-n-Lock|LED interior
    My '07 DC was having having the same issue. I read that Toyota did this to increase the payload that the Tundra can haul and tow. With a stiff frame it risks breaking the frame under load and twist. The video @fisherman951 posted is a "Ford" commercial from '09 where they were trying to say their truck was stable under torture testing. I have talked to Toytec and they have some options to address the issue by replacing the rear springs and shocks all around, call or email them they will answer all your questions. @Coachbuilder1 also referenced this as a suspension problem, see his post below.
    For Reference this has been discussed frequently, just search "bed bounce":
    https://www.tundras.com/threads/bed-bounce-complaint-to-toyota.4376/page-3#post-64987
    Read Post #70 from @Coachbuilder1 he explains in detail some of the suspension components of the Tundra and why shackles help.
    https://www.tundras.com/threads/bed-bounce-fix.21924/
    Ford commercial: View at your own risk.
    https://www.youtube.com/watch?v=GJZVUnOduH4
    kanger328[OP] likes this.
  6. Jun 23, 2020 at 8:19 PM
    kanger328
    Anchorage, Alaska
    2012 DC 4x4
    Wow, that was very informative. Thanks a bunch. I was looking to upgrade suspension anyway. Guess I’ll start with that.
    sf319[QUOTED] likes this.
  7. Sep 8, 2020 at 1:32 PM
    doct21
    doct21 New Member
    Scott
    Utah
    2008 Tundra SR5 2UZ!!
    Stock..not for long
    Did this get rid of it? any trade-offs? I was actually already planning on boxing it in. This is my biggest complaint with Tundra, coming from Sequoia, I am not used to this, and not sure if I'll be able to get used to it. Its outright ridiculous at times.
    Mountun Goat likes this.
  8. Sep 10, 2020 at 8:25 AM
    BigdaddyII
    BigdaddyII New Member
    South Louisiana
    2019 Ram 1500
    The Tundra twerk!
  9. Sep 10, 2020 at 9:28 AM
    406Michael
    406Michael New Member
    2014 Limited CM
    I am also interested in the answer to Doct21 question....sub'd
    Curious if a stiffer rear frame helps the suspension articulate more evenly and efficiently, therefore improving ride quality.
    doct21 likes this.
  10. Sep 10, 2020 at 12:17 PM
    art64
    art64 New Member
    You guys can try bed stiffer by Total Chaos. I have them on my 2010 Crewmax 4x4. The bed has small cracks on the bottom corners caused by loading motor bikes and driven off roads in uneven terrain. The ride will feel a bit stiffer as the bed and frame won't flex anymore.
    Of course, if you have the dough, you can go for frame mod. You will also need a suspension mod as the frame will be so rigid it will drive like a forklift on a bumpy surface.
    406Michael likes this.
  11. Sep 10, 2020 at 12:25 PM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
